Cars & Trucks Logo
Posted on Feb 09, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I replace the surge tank on 2002 GMC Yukon. Need to check for a leak in tank. Could leak be in hose from surge tank to water puml? Can not see any water leaking except for water on right side in front of tire. Could surge tank cap be bad and force water out over flow hose?
DROPNDEAL
Level 3:
Top Expert:
  • GMC Master 2,931 Answers
  • Posted on Feb 09, 2018
DROPNDEAL
GMC Master
Level 3:
Top Expert:
Answers
2931
Questions
0
Helped
931741
Points
21770
Surge tank?
Are you talking about the coolant reservoir? There should not be any water in the system. Only engine coolant.
Anyway, it is easy to remove the coolant tank. They are typically secured by two or three 10mm screws, and one or two hose clamps.
It is a pretty easy procedure that you can do yourself. Recommend a youtube search if you need video.
5 Related Answers
rwc120
  • 341 Answers
  • Posted on Jun 21, 2009
SOURCE: 94 GMC Yukon (No Spark)
You mentioned that it appeared that you were not getting spark but what process did you use to see if you were getting spark or not?
Anonymous
  • 43 Answers
  • Posted on Jul 19, 2009
SOURCE: 2003 gmc yukon denali xl starts but gas not
if your engine starts up and dies right away the you probably have a fuel pump problem and the service ride control mean that your air ride compressor has gone bad just turn your key to the on position and wait about 30 seconds you will here buzzing from the left rear wheel area if the compressor is working
Anonymous
  • 74 Answers
  • Posted on Aug 17, 2009
SOURCE: 2005 TIRE PROBLEM
no they are the same for both years
leethedeuce
Lee A.
  • 4472 Answers
  • Posted on Sep 08, 2009
SOURCE: changed radiator hoses and cap. changed coolant.
I had a leak on my top on hose on my jeep it was such a small hole I couldnt even recognize it. Almost mistaked it for the metal pipe corroding through. Now anytime your messing with the hoses it is best to just change the thermostat. They are cheap and easy. I would try that and go from there. Also how hot is it getting? 220 degrees is normal for jeeps. Should go a little past the middle line. Then the fans kick in and bring it back down. Also squeeze the hoses once it gets all the way hot and see that they have full pressure in them.
Thanks,
Lee
Anonymous
  • 541 Answers
  • Posted on Jan 03, 2010
SOURCE: replace front left wheel berring on 2002 GMC Yukon
do not replace only the bearing. replace hub assembly. remove rim/tire , remove caliper, mounting plate, rotor. . un bolt hub assembly, unplug abs. remove front axle nut if 4x4. you may need to rent the axle nut remove kit and hub puller. pull out hub. drive axle reward out of hub. install new part. do not torque hub over 90lbs. check with parts sell for spec
Just replaced by fuel pump, and now when I start my engine, my truck is leaking ALOT of gas, in the tank area.
Chances are that the hoses to and from the tank are brittle and the moving around formed a crack in a hose. Double check the connections to the tank.
Could it the water pump
Coolant leaks can be difficult to trace because the leak can migrate away from the source. To start with, dry off all areas that are wet. Then ,with a flash light, inspect the hose and water pump to see where the leak originates. This is done with the engine running so be mindful of all moving parts as you look through the engine compartment. It may be the hose that is leaking.
1helpful
How to check a radiator in a 2003 gmc yukon
it is over heating,thermostat stuck close,water pump weak.
The reserve coolant tank is leaking and the low coolant light keeps coming on
Remove the tank & check it out
Either it has a hole or the hose going to it
leaks
1helpful
2answers
How to remove radiator cover to add antifreeze to radiator
Your vehicle is equipped with a surge tank. There is no opening in the radiator itself. To check or add coolant (antifreeze) to your cooling system, screw the cap off of the surge tank.
CAUTION: Do this only when the engine is cool.
This is covered on page 5-26 of the 2004 GMC Yukon Owners Manual.
To download a free PDF version of the 2004 GMC Yukon Owners Manual click here
2answers
2006 gmc yukon heat will get warm if you gun the engine, but then will go cool at regular speed
Hello: Check the coolant level if the surge tank is not at proper level (threre is a full line on the container) If the container is low then you may have a leak in your cooling system.
2answers
Where can I get solid/detailed instructions for changing out the water pump on my 2001 Yukon SLE 4.8? Something that would include torque specs. and any must does and don'ts would be nice.
Escalade, Suburban, Tahoe, Yukon, Denali, DenaliXL, YukonXL 1999-2005 Water Pump - Removal & Installation 4.8L, 5.3L & 6.0L Engines
  1. Remove or disconnect the following:
    Air outlet duct Coolant Inlet radiator hose from the water pump Upper fan shroud Cooling fan and clutch assembly Drive belt Radiator outlet hose from the coolant pump Surge tank hose Heater hose Water pump
    Fig. Exploded view of the water pump assembly-4.8L, 5.3L and 6.0L engines
To install:
NOTE DO NOT use cooling system seal tabs (or similar compounds) unless otherwise instructed. The use of cooling system seal tabs (or similar compounds) may restrict coolant flow through the passages of the cooling system or the engine components. Restricted coolant flow may cause engine overheating and/or damage to the cooling system or the engine components/assembly.
  1. Install or connect the following:
    Water pump. Install the water pump bolts. Tighten the water pump bolts first pass to 11 ft. lbs. (15 Nm); tighten the bolts final pass to 22 ft. lbs. (30 Nm). Water pump drive belt pulley and bolts (if applicable). Tighten the pulley bolts first pass to 89 inch lbs. (10 Nm); tighten the bolts final pass to 18 ft. lbs. (25 Nm). Surge tank hose Heater hose Outlet radiator hose to the coolant pump Drive belt Cooling fan and clutch assembly Upper fan shroud Inlet radiator hose to the water pump Air inlet duct Coolant
    Air inlet and outlet duct Coolant Inlet radiator hose from the water pump Upper fan shroud Cooling fan and clutch assembly Drive belt Radiator outlet hose from the coolant pump Surge tank hose Heater hose Water pump
To install:
    Water pump. Install the water pump bolts. Tighten the bolts to 11 ft. lbs. (15 Nm) for the first pass; then tighten to 22 ft. lbs. (30 Nm) for the final pass. Water pump drive belt pulley and bolts (if applicable). Tighten the bolts to 89 inch lbs. (10 Nm) for the first pass; then tighten to 18 ft. lbs. (25 Nm) for the final pass. Surge tank hose Heater hose Outlet radiator hose to the coolant pump Drive belt Cooling fan and clutch assembly Upper fan shroud Inlet radiator hose to the water pump Air inlet and outlet duct Coolant
Hope this help to solve it (remember comment and rated this).
10helpful
How to replace a water pump on a 2003 yukon
Water Pump Replacement (4.8L, 5.3L and 6.0L Engines)
Removal Procedure
1. Drain the cooling system.
2. Loosen the air cleaner outlet duct clamps at these locations:
 Throttle body
 Mass Airflow/Intake Air Temperature (MAF/IAT) sensor
3. Remove the radiator inlet hose clip from the outlet duct.
4. Remove the air cleaner outlet duct.
5. If necessary, remove the engine sight shield.
6. Remove the radiator vent inlet hose from the radiator hose clips.
7. Reposition the inlet hose clamp at the water pump.
8. Remove the inlet hose from the water pump.
9. Remove the fan blade.
11. Reposition the outlet hose clamp at the water pump.
12. Remove the outlet hose from the water pump.
13. Reposition the surge tank outlet hose clamp at the water pump.
14. Remove the surge tank outlet hose from the water pump.
15. Reposition the heater inlet hose clamp at the water pump.
16. Remove the heater inlet hose from the water pump.
17. Remove the water pump bolts.
18. Remove the water pump and gaskets.
19. Discard the water pump gaskets
Installation Procedure Important: All gaskets surfaces are to be free of oil or other foreign material
during assembly.
1. Install the water pump and NEW gaskets
2. Install the water pump bolts.
3. Install the heater inlet hose to the water pump.
Zoom Sized for Print
Notice: Refer to Fastener Notice in Service and Precautions.
2.1. Tighten the bolts a first pass to 15 Nm (11 ft. lbs.).
2.2. Tighten the bolts a final pass to 30 Nm (22 ft. lbs.).
4. Position the heater inlet hose clamp at the water pump.
5. Install the surge tank outlet hose to the water pump.
6. Position the surge tank outlet hose clamp at the water pump.
7. Install the outlet hose to the water pump.
8. Position the outlet hose clamp at the water pump.
9. Install the accessory drive belt.
10. Install the fan blade.
11. Install the inlet hose to the water pump.
12. Position the inlet hose clamp at the water pump.
13. Install the engine vent inlet hose to the radiator hose clips.
14. If necessary, install the engine sight shield.
Important: Align the arrow at the throttle body end of the duct with the throttle
body attaching stud.
15. Install the air cleaner outlet duct
16. Install the radiator inlet hose clip to the outlet duct.
17. Tighten the air cleaner outlet duct clamps at these locations:
 Throttle body
 MAF/IAT sensor Tighten the clamps to 7 Nm (62 inch lbs.).
18. Fill the cooling system.
I hope this helps. The numbering is incorrect in the sequence but the instructions are correct.
Roy
1helpful
Antifreeze leak
I assume the vehicle has a heater in the rear. If so, the problem is probably either the heater core leaking, a hose leaking, or a hose connection leaking. If you want to further investigate and possibly fix yourself, let me know.
3helpful
2answers
I have gmc yukon when it rain my sun roof leak
I also have a sunroof that leaks on a 2002 Yukon. It is a factory sunroof with a cracked seal. Where can I get a new seal?
Top GMC Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a GMC Expert? Answer questions, earn points and help others
