Question about Focusrite ISA428 Pre Pack quad microphone preamp (with )
My Focusrite ISA428 has some consistent issues where channel 1 buzzes, and channel 4 is unusable for 2 hours after power up. Channel 4's needle goes right up to the meter and stutters there for an hour, then settles at a high db reading, then after a following hour falls at the 0db position where the channel is only now usable. Makes my ISA428 a usable 2 channel unit most sessions.
  • Focusrite Master
  • 5,603 Answers
Does this happen with no mics AND outputs connected? If it doesn't, you have a severe ground loop problem. Make sure ALL interconnected equipment is powered from teh same receptacle or power source. Use ONLY balanced lines, XLR or TRS cables. A possible problem MIGHT be supersonic feedback that you can't hear but is saturating the amp. Thats is why we disconnect all inouts and outputs and observe if symtoms are still there.
Posted on Apr 06, 2011
  • 2 more comments
  • danodeniel74 Apr 06, 2011
    Well, I did mention that it CONSISTENTLY reproduces these symptoms at every power up, for the same amount of time. It does this with nothing connected. I'm almost a slave to power up 2 hours before a recording session. But I will ensure the other advisories that you gave.
  • Fred Yearian Apr 06, 2011
    OK next test... sometimes it takes several. This MAY be a thermal issue. Thermal issues are fairly easy to resolve as we use hair driers to warm and circuit cooler to vary the temp of suspect chips. If you can, remove the cover of the unit. ALWAYS look for obvious things... common things are bad solder ESPECIALLY at potentiometer leads. Then verify problem exists with the cover off. If it does, from a cold start that would take two hours, instead warm the insides of it using a hair drier... does it come on sooner? Next from a cold start wiggle areas of the board, especially on the side or area that has the pegged meter. If you have the thing immediately coming on when wiggling, you likely have either a bad solder joint OR a crack in the circuit board. Use a bright LED flashlight and "candle" the board looking for cracks. The above are the procedures I would use in my shop. Don't be surprised if removing the cover fixes the problem... it will be back unless you find the smoking gun...
    Now for suspected components assuming there are no cracks or bad soldering, the LIKELY component is one of the can electrolytic caps. If hair drier brings thing on right away, cool each down with circuit cooler. Give at least 5 seconds each after spraying for cold to "soak" in.
    Chips and transistors are next suspects and resistors are far down the list statistically.
  • danodeniel74 Apr 07, 2011
    wow detailed test. I havent been able to go at these lengths as yet, but I should mention that yesterday when for curiosity i tapped the area directly above the troubled channel 4, the meters responded to the very light impact- moth needle and LED's! there's definitely something going on in there. I could reproduce the LED's responding by lightly tapping the area on top, or on the side of the channel 4 everytime!
  • Fred Yearian Apr 07, 2011
    I have confidence you will find something when opening... LIKELY a bad solder joint at least for the channel that pegs the meter. We call these problems "morning sickness" as the devices recover after they warm up. An experienced eye will spot bad solder as a tiny grey crack around where leads come through the board. Overnight these broken joints oxidize and as they warm or slight current flows through teh oxide, the joint re-establishes contact... till it cools down and starts the cycle over.
How to get sound from a nady audio 4130 mpm 4 channel power mixer
First, plug it in. Next connect the speakers. Center all eq controls both master and channel. Turn off any reverb or effects. Turn the master volume 1/2 way up. Plug a sound source into channel 1 wiyj the channel volume all the way off. Turn on the amp. Slowly raise the channel volume until you heat output. If you get nothing, it's broken.
Nov 10, 2016 | Nady Systems Music
How do i connect focusrite to europowered pmp4000
You don't say what item of Focusrite equipment you are trying to connect or for what purpose. Most focusrite stuff has jacks with analog outputs for each channel that can be used into the line ins on the mixer and jack/xlr combos that can be used to take a signal to the focusrite box. Then you get the firewire side for the PC and digital outputs as well which will not be of use with your mixer.
Feb 12, 2014 | Behringer Europower Pmp5000 Powered Mixer...
Buzz across all channels in crate rfx120
I also have this issue. Same crate combo amp. There is a loud buzz emitted only when there is a cable plugged in. Cables and instruments checked good, only possible issue is inside the input of the amp. Popped it open, solders and connections were intact and appeared solid. Anyone have a guess as to why this is happening?
Feb 12, 2012 | Crate Music
Kustom KSC 4080 Just bought - channel 1 is dead, for both 1/4-inch and XLR inputs. By the way, the nut securing the 1/4-inch jack is gone (any wild possibility that creates a grounding issue that cuts out...
The missing nut is not likely to kill the channel. You just bought this so exercise your warranty... unless it is used in which case you bought someone else's problem. Somebody probably blew out the channel by zapping it with high voltage that destroyed the input circuit of the channel. Often there are bypass capcitors right at the input which short out. If this is boiught used, take to a repair shop and if new, exercise your warranty. I suspect they removed the nut from the connector to mark the dead channel.
Aug 18, 2011 | Kustom KPM4080 PA Amplifier/Mixer
We have a pmp6000 mixer hooked up to our ep 4000 and b1800 and b2520,it seems we can only hook up the amp to the mixer into either mono's 1 and 2 or the main 2 however not in main 1 with full...
MAKE SURE the cables you plug into 1/4 inch mains are TRS plugs, and not mono cables (TS). The main output 1/4 inch jacks are TRS balanced outputs and if you plug mono (TS) cables that shorts out the ring connector reducing the power by 6 Db. USE ONLY TRS balanced cables for interconnects !!!! Also read my tip on Fixya regarding PMP mixers. If you use 1/4 inch SPEAKER cables or adapters, if you short the SLEEVE of channel A output to ground you can pop the channel A amp. The TIP of channel B is the hot BUT the SLEEVE of channel A is the HOT. The ttip I posted explains why this is and it isn't mention in the Behringer documentation.
Aug 06, 2011 | Behringer EUROPOWER EP4000 4,000-Watt...
I have a very loud hiss/buzz sound coming from my Roland. It goes away if I lower the high volume knob. This just starred to happen recently. I tried changing connections from ch1-4 but no fix.
If this ties to a keyboard, make sure the keyboard and this are BOTH plugged into the same receptacle. You should send a higher level from the keyboard (turn volume up to around 70% or so) and use less volume at the input gain of this amp. Use more at master volume if the amp has one if needed. If the hiss is there with NO input cables plugged in and input gains at 50%, that is objectionable, the amp probably needs servicing. Unused channel gains should be clear down.
Apr 11, 2011 | Roland Elektronische Musikinstrumente...
How can i setup mu xenyx 802 with my pc? i also hve fca202...
You can do it one of two ways when coupled with the FCA202. First, You can just come out of the main outs on the 802 via 1/4 in to the 202s 1/L in and 2/R in. Second, you could do two separate channels (ie. Vocal channel and Guitar Channel) using the L/R out on the 802. Use the pan knob to send the instrument to the selected channel. So, If your Guitar is on channel 1 pan hard left and you will only get it out of the left channel sending to channel 1 of the 202, and your vocal is in channel 2 pan hard right and you will only get it out of the left channel sending to channel 2 on the 202. Good Luck, Cody J.
Dec 17, 2010 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
How do I get the USB input into the monitor channel on a Behringer Xenyx1832usb
I suspect that you don't, at least easily.
Try this:
IF you can send it to the mains, run a cable from the mains 1/4 jack back to an unused channel input. Set the monitor level on that channel to send the mains back out to the monitor so that anything on the mains from USB will be in the monitors... This is hokey and you have to disable this channel by not sending it to the mains, from the mains lest the thing will oscillate.
As versatile as this Behringer stuff is, I rather doubt that the USB can be routed directely by setting to the monitors... But just ry to find documentation about this!
Typical of this brand, finding and understanding the documentation can be frustrating.
Apr 25, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Fender Concert II preamp is faint and distorted on 2 channel
It sounds like a job for a technician. There are high voltages in the chasis and the potential for a serious shock to the unwary.
That said, I can suggest several possibilities.
First, make sure the controls aren't causing the problem. Contacts can build up dirt and oxides and block the signal. Try twiddling the controls and see if the problem comes and goes, or if you hear scratchy noises. If symptoms are found, buy a contact cleaner spray, take out the chasis after unplugging and letting it set for an hour, being very careful not to touch any exposed conductors inside. You'll see some holes in the control bodies; squirt cleaner for 2-5 seconds and work the controls.
Also see if the problem happens without the footswitch, and try the channel switches several times - same problem, dirt and oxidation.
Other possibilities - cathode bypass capacitors drying up, and it looks like the amp uses some opto-couplers at various stages.
Nov 09, 2009 | Fender Hot Rod Deluxe Guitar Combo...
Focusrite ISA428 Pre Pack quad microphone preamp (with ) Logo
178 people viewed this question
Top Focusrite Music Experts
Vito Vacirca Jr.
Are you a Focusrite Music Expert? Answer questions, earn points and help others
