Straight line at the bottom it flashes sometimes
    Sergeant:
    Champion:
  • 244 Answers
This can be caused by a loose cable or a bad video chip. There's not an easy way to fix this without taking the LCD apart and looking at the cables. Here's a guide on how to do so if you'd like:
http://www.ehow.com/how_6911006_troubleshoot-lcd-laptop.html
I don't recommend trying this unless you have tech experience.
Posted on Apr 06, 2011
Testimonial: "hoping it will do"
Bottom thread is still loose even if i try to balance the tension, how do i balance the thread tension?
You bobbin tension CAN be adjusted. First, thread your machine with different colors in the top and bobbin, set your top tension at its default, and run a line of straight, and then a line of zigzag stitches, and compare the results at the top and bottom. You will be adjusting your bobbin to your top tension. If the top tension looks like a straight line instead of stitching and the zigzag looks like "chicken tracks" instead of a zigzag, but the bottom looks like a zigzag, your bobbin tension is too loose.
Remove the bobbin case, and locate the straight-slot screw. There are generally two; one is a Phillips and one is straight--you want the straight one. Leave the other alone.
The rule is "lefty-loosy, righty-tighty." If your stitching displays the above symptoms, it needs to be tightened, so turn 1/4 turn to the right--no more--then test again. You will need patience, but don't turn more than that. It is easy to do, but if you don't do it systematically, you can make things worse, and very slight adjustments can alter the stitching significantly.
Apr 15, 2015 | Singer Sewing Machines
Why do I have white / faded print when printing black? It also has problems printing straight lines - sometimes jagged sometimes just faded.
I do not know for sure but it sounds like the paper is not griped properly, this would cause the jagged lines. I would try another ink cart when the loose paper problem is resolved. I hope this helps.
Jul 23, 2014 | United Stationers HP Officejet Pro 8600dn...
The top half of my pictures with a flash are shaded.
Not seeing the pictures I have to guess. If the shade you mention is not like a straight line, but more rounded, try making the picture without the lens hood. Or use a external flash, when you use another than the standard lens. I don't think you can take a picture in manual, with a shutter speed above 1/250 second, because in such case the top or bottom part could become shaded then, but then the shade is in a straight line from left to right.
Dec 26, 2013 | Nikon D3100 Digital Camera
I can't acess the web nor get my google or verizon emails or google voice
Have you turned on your data? If you haven't tried this yet you must in order to use web and emails. First, click on the bottom left button with the three lines. A list comes up find settings and press it, another list will come up. Next press wireless & networks, scroll to the bottom and press mobile networks. Once there press data enabled to turn on your data. That should enable you to access web and emails. Another tip, in the settings menu, press accounts & sync then press background data this will help with apps syncing. BE CAUTIOUS WITH THESE SETTINGS!!! I advise you turn them back off when you're done using them because they will use a ton of data if left on a may get you penalized by Straight Talk! THEY WON'T HESITATE TO CUT YOU OFF WITH NO REASON EXCEPT YOU'RE USING MORE DATA THAN EVERYONE ELSE IS!!! Sign out of email, Facebook and anything else that uses data constantly. I hope this is helpful good luck have fun!!!
Feb 22, 2013 | Straight Talk ZTE Merit 990 GSM Android...
Dishwasher has about 2" of
Is your drain line clear? It feeds into your sink drain and if there is any blockage it can prevent a good drain. Is the drain line as straight as possible? Make sure the bottom of the dishwasher is free of debris (food, paper from labels, etc; plastic pieces) . To be safe you can take a long handles brush and scrub around the center of the drain area to dislodge any materials. Also, a white vinegar rinse will sometimes help remove debris and clean the interior of the washer. 1/2 cup white vinegar in the tub and then begin the cycle. If none of these remedies help, it might be the pump or the timer.
Oct 28, 2010 | Vacuums
Phone lines are flashing making a loud beeping noise. The screen is texting funny words. Phone is ringing with ambulance style ring before the normal tone
The phone doesn't like something it's sharing a line with.
First, check to see if the extension number on each phone is different. You may have two extension 11's.
Next, check that line 1 is line 1 one all of the phones, then line 2 is line 2 etc. If one phone has line line 1 showing up on line 2 then you may have wires crossed somewhere. Or if you pick up a line on phone one and line 2 goes red on one of the other phones you have wires crossed.
Last, check in the plugs to make sure the connections are straight. Sometimes when a phone plug is inserted the pins cross and short two lines together.
Mar 18, 2010 | Panasonic KX-T7730 Corded Phone
Light flashes as straight line at the bottom of my laptop screen
Does it display the BIOS screen or anything when you first power it up? If you've only had it for six months, the laptop should still be under warranty. I would contact the manufacturer on this issue.
Jan 12, 2010 | Computers & Internet
My dishwasher AEG FAVORIT keeps beebing and not working it flashes with a arrow and stright line? it stoppted half way through
The arrow straight line meens end of program. However the flashing lights do indicate an error codeas per the handbook. This could be the ati flood device (polystireen float / micro switch) at the bottom of the machiene indicating a water leak. This device puts the washer in pump out mode and nothing els works until the error has been rectified.
Sep 19, 2009 | AEG 23 in. Favorit 50750Vi Built-in...
Timing marks and procedures
If it is the 2.5 EJ25 motor the marks ar on the cover and pulleys. Top pulleys are Single line straight up and double straight down which should line up with bottom pulleys double marks. This should line up the single lines on bottom pulleys with 90 degree mark on outer cover both sides.The center pulley for crank should be straight up with notch in block.
Jul 23, 2008 | 1998 Subaru Legacy
Printing is crooked
if paper comes out straight, and lines in paper are not straight then there is problem wit laser unit, its not installed corrrectly, also you can check drum unit and transfer belt for correct installation.
Apr 27, 2008 | Konica Minolta Magicolor 2530 DL Laser...
Computers & Internet Logo
104 people viewed this question
David Payne
David Payne
