Question about Barska Optics Barska AC11202 - 4-16x50 Benchmark Targeting Riflescope, 30mm, Mil Dot- Wat
I need an instruction manual for my barska 4-16 x 50 mil dot scope. barska product code ac11002
HOW CAN I GET THE FRONT HOOD OFF OF MY BARSKA RIFE SCOPE.
Posted on Nov 20, 2013
fps353535
  • 99 Answers
SOURCE: How do you use mildots on a Barska 10-40x50 varmint scope?
One Milliradian (mil dot) is one onethousandth of a unit (1000 yrds its 1 yrd, 1000m its 1m)
for a more indepth explanation visit this site :)
www.shooterready.com/mildot.swf
GL
Posted on Apr 07, 2009
miket756
  • 2702 Answers
SOURCE: to read mil dot what power does scope need to be
any power it works on all of them
Posted on Aug 30, 2010
miket756
  • 2702 Answers
SOURCE: how do I adjust the
in a word you cant,,,,,its a 4x28mm so its a fixed scope at 4x's mag with a 28mm lens
Posted on Nov 28, 2010
  • 16010 Answers
SOURCE: I am shooting with a
You have to understand how scopes work. There is a tube in the middle that is held in place by springs and those springs press the tube against the screws. When you adjust the screws you are either pushing back the spring or letting it expand towards the screw depending on what direction your adjusting for. There could be loss of tension on the springs or the spring end has come loose or had something wrong with it and it has now changed the tension that it once held. Short of taking the whole thing apart to see what is going on, you should back the screws all the way out and re-sight the scope. You also need to check the mounts and make sure they are tight. IF nothing else you should get another scope. Sorry.
Posted on Jun 12, 2011
  • 2418 Answers
SOURCE: Son just bought me a
Simply put, the Mil-Dot is a way to estimate range with the scopes reticle. This type of reticle was developed for military applications. The space between the dot centers is equal to one milliradian (Mil). hence the name mil-dot. One Mil equals 3.6" inches at 100 yards, or 36" at 1,000 yards. To use this system effectively you must know the size of the target. For instance most people are an average of 6 feet tall or 2 yards. The formula used for determining range to the target is (size of target x 1000 divided by number of mils the target covers). Hope this helps FixYa up.
Posted on Sep 01, 2011
Bought a Barska red dot sight and it needs the battires changed were is the battery soure on the sight so that I can change it out.
The battery's are under the large top cap, use a screw driver or coin to remove. watch for how they come out keeping in mind the positive side up. Hope this helps Fix Ya up.
Jun 11, 2011 | Barska Optics Barska 1x30 Red Dot Scope...
I don't have any instructions for this Barska 80060 Telescope. I need to know how to put it together and use it.
Sorry no manuals for that scope. However MEADE maintains a list of manuals. Look under the REFRACTOR heading for one that is similar to your telescope.
http://www.meade.com/manuals/index.html
Dec 25, 2010 | Barska Optics Barska AE10096 - 80060, 600x...
I need a danish manual for the enthusiast 70060
No manual is available for that small telescope. The manual only has assembly instructions. It does NOT tell you how to use the scope. Contact a local Astronomy club for assistance.
Nov 07, 2010 | Barska Optics Barska AE10094 - 70060, 525x...
Does it matter at what magnification i use when ranging using mil dots?
no it dont but it would be far better if you test fired your gun till you could shoot by gessing the hold over/hold under anf forget about the bam silly mil dots they will only be right on the gun they were set up on and no two guns shoot the same so you see the mil dot is a bit of a con realy
Dec 16, 2009 | Barska Optics Optics
Cant find out where to chang the batteries
Go to Barskas service/help desk, their Email; service@barska.com , they are in California and are quite helpful.
Good luck. :)
Apr 18, 2009 | Barska Optics Barska® 50 mm Red Dot Scope...
GL
Apr 04, 2009 | Barska Optics Barska 10-40x50 Ao Varmint...
Tasco 6-24x42mm rifle scope parallax adjustment
Here's what you need to know about Mil Dots and rangefinding.
When you look through the scope you should see 5 mil dots on each axis, your scope may have broad lines taking place of the 5th mil dot if it is a "modified" mil dot scope. For measuring purposes, 1 mil is the distance from the center of one dot to the center of the one directly above or below it. 3/4 of a mil is the distance from the top of one dot to the bottom of the one above it, or the "space in between dots". 1/4 mil comprises a single dot, the space between the top of one dot and the bottom of that same dot.
A quick calculation is Size of Target (In Yards) x 1000 / Size of target in mils = Range in Yards
Miliradian or "Mil" is an angular unit of measure, so if you were shooting at 1000 yards and moved up 1 miliradian that would be one inch impact moved up.
Anyway lets say you have a 30" target and we need to find the range... using your scope you place the bottom of the target at the CENTER of a mil dot and count how many mils up, good estimation is key... I'll draw a little text diagram, an asterisk * will be the target top and bottom, and parentheses () will be a mill dot
Now lets assume the asterisk on the left is the bottom of your target and the one on the right is the top, I put Ten Hyphens in between each dot so if you count from the left you should get about 1.6 Mils. Its real easy to do it in your head, you already know two whole dots is one mil so you just have to estimate whats to the right (or top if you were looking down a scope).
So we know the target is 30" and we have a Mil Reading of 1.6
30/36= .833 so 30" is .833 Yards
So now we can use the equation .833 x 1000 / 1.6 = 520.6 Yards is the distance of the target
Now you can also use Mil dots to do hold over for when the target moves or for wind and elevation but that gets extremely complicated.
Parallax in Rifle Scopes is explained here
http://www.6mmbr.com/parallax.html
There are many books and websites to confirm what I've said here, but the best way is to go out to your range and talk to some long range shooters and show them your rifle/scope etc and get hands on help.
Mar 16, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
RIFLE SCOPE WARRANTY
Here is the contact info for them. ask them :)
Please rate this as fixya :)
Nov 16, 2008 | Barska Optics Barska 10-40x50 Ao Varmint...
Damaged scopes
Contact Cecil Tucker in Odessa,TX 1-915-368-0630
If he won't or can't fix it for you (he gets alot of target scope business) at a reasonable price, he can tell you who will.
Nov 06, 2008 | Barska Optics Barska 10-40x50 Ao Varmint...
Barska Optics Barska AC11202 - 4-16x50 Benchmark Targeting Riflescope, 30mm, Mil Dot- Wat Logo
232 people viewed this question
Top Barska Optics Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
xalint1
xalint1
Are you a Barska Optics Optic Expert? Answer questions, earn points and help others
