Question about Zephyr Savona ZSA-M90S Kitchen Hood
Savona ZSAM90S (36'') 785 CMF. The fan/motor does not run. I have replaced every single part without success. I replaced the motor, switch module, capactor without success. I check the 115VAC to the motor and is ok. The light which is controlled from the switch module works. I do not think there is a fuse at all! Do I have bad power ground(return)? It tests ok. Please could you help? I do not have a wiring diagram. Please could you assist? The vendor in California is not very helpful!
5 Suggested Answers
SOURCE: Push Button Switched
zepher sent replacement sritch.
had to wait a while -parts from italy (heh)
so far ok
design is poor
Posted on Jul 18, 2008
SOURCE: light blub burnt out
The easiest way to remove the light bulb is to wear a rubber glove, use your palm to press against the bulb, and turn counter-clockwise.
The suction created by the rubber glove should allow you to remove the light bulb easily.
Posted on Jan 15, 2009
SOURCE: Replaced light bulbs but no light
Original bulb has a JDR designation. I ordered bulbs and received bulbs with a JDRC designation, the brand was Hikari--these bulbs were shorter than the original bulbs and will not seat properly even after removing filters and turning bulbs by the neck of the bulb (porcelain section). Since they won't seat completely in the socket there is no electrical contact and they won't work.
Posted on Apr 07, 2009
SOURCE: savona zephyr light switch
Did you ever find a source for the switch assembly? Janderson@andersonpangia.com
Posted on Mar 27, 2011
1991 Miller/Nordyne cmf-80 furnace Periodic non ignition
That's a "mind of its own" condition that I've gained & lost customers over. When the unit first starts in heat, you mentioned the induced draft motor will start with no other reaction from the system, that should be the best time to locate the issue by using a volt meter. If you are getting 24 volts to MV/PV at the gas valve then you know all of the heating circuit has "proved", and that the gas valve is the problem. If not, the backtrac until you find 24v. Now if you are simply just changing parts until you find the problem, which we've all done, I believe you've changed all that you can. Check all wire connections. Its probably a loose, corroded, or damaged wire/cannon plug(the plastic plugs that multiple wires are connected), stopped up gas pilot orifice, or the gas valve its self. Hope this helps!
Feb 15, 2017 | Heating & Cooling
Can blower motor, cig. lighter, fan cooling motor, door locks all be tied into the blower motor relay faulting out?
Sounds more like a key switch or fuse box problem.
The circuits you mentioned would be on separate fuses but could be connected to the key switch. The relays are grounded by the engine computer to be energized.
Nov 20, 2015 | 2001 Pontiac Aztek
Where is the fan relay switch on my 1993 Taurus SHO
The cooling fan relay is part of the module assembly mounted on the driver side under the air intake/filter assembly and is not replaceable without changing the module. It contains many relays. Thanks Ford. Check the fuses. Try hot wiring the fan at the motor and see if it comes on that way. Connect the ground to ground and run a wire to the pos side of the battery. That will narrow it down to a bad motor or calling you local Ford parts.
With the proper scan tool, you can toggle the fans with the tool through the testing section of the tool. Also, check for any DTC's.
Aug 11, 2012 | Ford Cars & Trucks
I have a PUMA air compressor that has been running fine until this morning, it will not run, I have power (220 ) to the wires at the pressure switch and the reset button was not tripped, motor and...
If you remove the fan belt and the motor runs without a load,
one of your motor capacitors is bad. some motors take one
capacitor, some take two. the capacitor is what helps the
the motor give that extra torque to run the compressor pump.
good luck!
Jul 17, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
Savona zephyr light switch is burn out.How do i replaced it.
Feb 19, 2011 | Zephyr Savona ZSV-E30AS Stainless Steel...
How to turn on &off blue-tooth in hp 6910p
i've compiled everything for you and highlighted your answer
Special instructions for the HP Compaq 6910p
BEFORE WINDOWS INSTALLATION 1) MAC addresses The MAC addresses of the Ethernet (cable) and the wireless interface (WiFi) are written on a label on the side of the box. They are also written on a label at the back of the notebook. They must be registered in the CERN network database via http://network.cern.ch (using another computer) before starting the Windows installation.
2) Wireless switch on
When you start the installation, verify that the wireless light (with an antenna symbol) above the keyboard is on (blue light) in order to install properly the wireless drivers. If not, touch that antenna symbol with your finger: it is a sensitive button.
WINDOWS XP After Windows XP installation 1) Keyboard_Filter_01 As by default users are not in the Administrators group, a window titled "Found New Hardware" may tell you: "You must be member of the Administrators group on this computer to install this hardware: Keyboard_filter_01". In that case ignore that message and first regain administrative privileges by using the NICEAdmin application to add your account in the Administrators group. For that click on the Start button, select All Programs then NiceAdmin then Change Account Status. On the popup window click on Add Me, enter your login password and click on the green button (with an arrow). Then Reboot (a logoff/login is not sufficient). This time, the installation of the Keyboard_Filter_01 driver will be done silently.
Don't forget to use NICEAdmin again to remove yourself from the Administrator group in order to improve computing security after your next login. But don't log off until you have installed all your programs (for example the Bluetooth software explained below).
2) WiFi To setup a wireless network connection, you must be within range of a wireless Access Point. Check also that the wireless interface is switched on (blue light above the keyboard).
When Windows detects a wireless network for the first time, it should prompt you with a Wireless networks detected message in the notification area of your taskbar. If so click the notification message. If you are not notified, click on the Start button, point to Connect To and click on Wireless Network Connection. In either case, you should see the dialog box Choose a wireless network. Select CERN and click connect. On the warning "You are connecting to the unsecured network ...", click on Connect Anyway. Wait until connected to close that dialog box.
3) Bluetooth
If you need to connect to Bluetooth devices, HP provides a software to manage your connections. To be allowed to install this software, you must be registered in the Administrators Group of your computer. For that you can use NICEAdmin: click on the Start button, select All Programs then NiceAdmin then Change Account Status. On the popup window click on Add Me, enter your login password and click on the green button (with an arrow). Then Log Off and login again.
Check that your notebook wireless interface is switched on (wireless button above the keyboard with blue light on). The Bluetooth installation package is located in "C:\SwSetup\HP Bluetooth software v5.1E 26Mar07". In that folder, double click on Setup.exe to start the installation.
After the installation, you can use NICEAdmin again to remove yourself from the Administrator group.
4) DVD player
If you need to play DVD videos you can install the WinDVD player provided by HP for your portable. First right click on the CERN CMF (Computer Management Framework) icon in the system tray. If the CMF icon is not present reboot your computer and wait some minutes. Choose Add/Remove CMF Packages. On the CMF page tick the install box for the package WinDVD player for HP and click on the Save button. Then a CMF balloon should appear proposing to install WinDVD. Click on the balloon (or double-click on the CMF icon). In the CMF windows select WinDVD player for HP and click on Start Now. After some minutes CMF should display a balloon telling The installation of the package *WinDVD player for HP* completed successfully.
WINDOWS VISTA After Windows Vista installation 1) WiFi To setup a wireless network connection, you must be within range of a wireless Access Point. Check also that the wireless interface is switched on (blue light above the keyboard).
Click on the Windows Start button then choose Connect To. Then select CERN, click on Connect and then on Connect Anyway. When the window announcing Successfully connected to CERN appears, put a checkmark in Save this network and in Start this connection automatically. Finally click on the Close button.
2) Bluetooth
To activate the Bluetooth, press the wireless button (antenna symbol above the keyboard) to get a blue light on that button. Then click on the HP Wireless Assistant window which appears in the bottom right corner of the screen. If the status of Bluetooth is not on, click on turn on. Close the HP Wireless Assistant.
3) DVD player
Nov 13, 2010 | HP Compaq 6910p Notebook
Zephyr Savona range hood quit work on low spds-hi still works
Motor Speed may not be working and this means the either the motor is bad or switch is bad for motor Low Med Hi Switch
May 27, 2009 | Zephyr Savona ZSV-E30AS Stainless Steel...
Range hood is making noies
use a good 3 in 1 oil. Don't use WD-40 it will only clean it then dry out the bearing. the problem will be worse than when you started.
Feb 06, 2009 | Zephyr Savona ZSV-E30AS Stainless Steel...
so far ok
design is poor
Feb 29, 2008 | Zephyr Savona ZSA-M90S Kitchen Hood
Zephyr Savona ZSA-M90S Kitchen Hood Logo
Top Zephyr Kitchen Ranges Experts
Treefrog15
Treefrog15
The Vanguardian
The Vanguardian
Dale Copeland
Dale Copeland
Are you a Zephyr Kitchen Range Expert? Answer questions, earn points and help others
