Question about LG WM2688HWM TROMM SteamWasher
The door lock won't release - LG WM2688HWM TROMM SteamWasher
    Genius:
  • 1,400 Answers
Hello
This is a common error,unplug machine for two minutes to reset.Open door while machine is unpluged.
Posted on Apr 06, 2011
Maytag range model mer6750 - I tried to open the oven door too soon after a self cleaning cycle Now door won't open and fault code F9-2 appeared. What to do? THANK YOU
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
F9 Door Lock Warning Check door lock circuit or Replace Clock
F-2 Oven temperature sensed by electronic control Replace the clock/relay board.
Here is the part you need to order.
May 18, 2013 | Kitchen Ranges
1994 Lexus ls400 replaced powersteering pump and won't shift out of park, no instrument lights no power windows, no power door locks, no power trunk release
Sounds like a major fuse blown.
Any wiring disconnected or stripped near the pump ?
Have you checked the major fuses around the battery and underhood fuse box ?
Apr 15, 2013 | Cars & Trucks
Door locks won't lock/unlock
What kind of vehicle is it?
May 02, 2017 | 1999 Chevrolet Blazer
Door lock won`t engage
Hi - I understand that the door won't engaged, however does it show any other symptoms? Try to start a drain spin cycle and let the unit run for approximately 5-7 minutes and press cancel once. If the door opens immediately, unit made have a bad door lock. If you have to wait for the door to release to open, then possibly you have a control or wiring issue.
Sep 15, 2012 | Frigidaire GLTF2940ES Front Load Washer
Film camera back door won't close
Does it not close or does it not lock? If it does not lock it may be the light seals are obstructing the door. If it will close but not lock open the camera, pull up the rewind knob, see if the release slider is operating.
Jun 28, 2012 | Pentax K1000 35mm SLR Camera
Maytag Neptune door won't lock, or start the was cycle.
check all wiring for tightness and any corrosion from door latch up to the central control unit first,if ok then replace door latch component as this part wears out quickly you will need to remove washer top,then door boot spring to release door boot from door frame to access wiring to door lock component
May 06, 2012 | Maytag MDE5500AYW Electric Dryer
My gas door is locked and won't open on my 2001
Inside the truck behind the trim is a manual release for the gas door, the release looks like the head of a large key on a small wire string. It is marked.
Feb 10, 2012 | 2001 Volvo S60
The door is locked and won't open; how do i unlock it manually?
unplug it,remove the bottom panel,stick your hand up where the door lock assy. is and on the bottom of the door lock assy. there is a plastic wire that releases the door manually,grab it and pull down and the door will release.
Jul 10, 2011 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
105 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
