Question about ASUS M2N68-AM SE2 Motherboard
Well my Asus m2n6 am plus motherboard at least i think its the problem WELL the BIOS doesnt save settings made and i need to reinstall mi windows because it totally crashed :D virus or something But to the point i always try to change the boot priority in bios and every time it restarts it uses the default settings !!!! And every time when loading it shows me a dialogue of two options it always says it has detected a new CPU or somethnig :D now those options are : 1. Press F1 to open setup 2. Press F2 to load default chagnes This isnt the pc with the problem the pc is right broken pc is right next to me :D And i am not English i am from slovakia so if i sayed something wrong corect me OK :D thanks for early replies :)
  • 62 Answers
The problem must be with the CMOS battery. That causes the BIOS setup to not retain changes, including the system clock. Verify also whether the time is correct.
Posted on Apr 06, 2011
How to enable tpm in m2n68am plus motherboard
Hello the homepage is here:
http://www.asus.com/Motherboards/AMD_AM2Plus/M2N68AM_PLUS/#download
But first select you current windows 32 or 64 bit.
Select the file you want and click on global for download.
I have seach in the files and a bios update should solve the problem.
I recomend to use asusupdate to upgade the bios.
If you are unfamiliar with that get a expert to help you.
Download first asus update and install it.
Next download the latest bios version.
Both files needs to be unziped before installation.
Open asus update and choose update bios from file
Select the bios file you just have downloaded typical a bin file
Click next and the program will do the rest.
You can do that while windows is running.
And remember DO NOT flash the bios with a wrong one
It will destroy the mainboard.
Remember to set up the boot settings when the job is done.
Good luck
Oct 27, 2012 | ASUS M2N68AM Plus Motherboard
Cerna obrazovka nemam disketu bios
Hi, you can download the bios here:
http://www.asus.com/Motherboards/AMD_Socket_A/A7V600X/#download
Download the asus update utility from here:
http://www.softpedia.com/get/Tweak/System-Tweak/ASUS-Update-Utility.shtml
The asus Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows environment.
The Asus Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
Aug 25, 2011 | ASUS A7V600-X (90M7A820G0EAYZ) Motherboard
Hi..i installed Windows 7 but i dont have the sound driver. My motherboard model is: M2N-MX SE PLUS. Where can i get it as free download?
http://drivers.softpedia.com/get/BIOS/Asus/Asus-M2A-MX-SE-Plus-Bios-0406.shtml
Please open the link above and click the download button.
Jul 12, 2011 | ASUS M2N-MX Motherboard
Cmos bios bad asus p5ld2-x/1333 i945gc. how i fix?
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
May 23, 2011 | ASUS P5LD2-X/1333 - motherboard - ATX -...
I want to update my P4BG-VM asus m.board bios update
Please go to this site and select your operating system. Your bios update options will be listed under the bios drop-down. Hope this helps.
May 22, 2011 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
I have an asus p6 x58d-e motherboard Bios ver.0303 . I hve installed 6Gb of RAM (3x2Gb) in triple ch. The RAM is A-DATA Gaming series - AX3U1333GB2G8-1G . I get this message at bootup saying "memok...
It means that every time the motherboard starts it tests the memory and it's OK. Go into the BIOS, disable the memtest and save all the settings. The easier solution is to load the default settings and after that change the boot order and save the settings again.
Jan 20, 2011 | ASUS P6X58DE Desktop Board Intel Chipset...
I' ve a problem with Asus P4P800S- X
Please enter the bios check all the settings if all are correct then press f10 save the settings and exit.
Feb 03, 2010 | ASUS P4P800S-X Motherboard
I m having asus k8v-vm bt no space for sound card
The Asus K8V-VM motherboard has an intergrated audio chip on the motherboard, Realtek ALC660. You need to enable it in the bios. If you do not have you're manual down load it from Asus; http://www.asus.com/Search.aspx?SearchKey=K8V-VM You'll also need Adobe reader installed to view the manual. Enter the bios menu. Open Advanced. See the top of page
2-21 in the manual. Set, High definition Audio to [Auto] Save and exit the bios. Also check out page 1-19. You can install the driver software from the Asus CD or download it from the Asus link provided above.
Realtek Audio Driver V5.10.0.5211 for Windows 2000/XP/XP 64bit. (WHQL)
Cheers'
Mike
Jan 10, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Startup problem
you must be pressing F1 to continue after you replaced the battery, as if it boots into windows there is no problem with the bios, you may be forgetting to correct the time and date and save the settings. You need to press F2 or Del instead of F1 to get into the cmos settings
Jun 19, 2007 | ASUS P5RD1-VM Motherboard
ASUS M2N68-AM SE2 Motherboard Logo
244 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
