Question about GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator will cool for about 2 weeks and then everything starts meltingand it stops cooling
    President:
  • 2,468 Answers
Your evaporator coil is freezing over due to either the defrost heater or thermostat on the evaporator coil are not working,you can check both of these components with an ohmmeter but the thermostat needs to be below freezing to test or it will show bad even if its good,theyre both behind the rear panel inside the freezer,if the evaporator is iced over you cannot get cold air to move
Posted on Apr 06, 2011
My GE side-by-side is not cooling.
The electronic control board is probably your culprit. These control boards control the compressor, fans and defrost. Look for any burned spots on the printed circuit bout it could be just bad.
May 11, 2014 | GE GSS25SGPSS Side by Side Refrigerator
Not cooling
either your heating element for auto defrost is broken or your thermostat is is broken
Dec 09, 2013 | Frigidaire Refrigerators
My freezer has started to frost over. It started about 2 weeks ago and is getting worse. What is the cause for the automatic defroster to stop working.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 15, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
My refrigerator stopped cooling and my freezer stopped freezing but the freezer is still cooling
Same thing with our GE Eterna Series - off and on for the last two weeks. Took back panel off, looked around, vacuumed dust build up off of the fan blades, etc.; everything worked fine for five good days. Then frig went out stopped cooling. Off and on for the last week. Unplugging it works for a day then back to not freezing and or colling.
Jul 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Added freon to ac and car will not cool
Needs to be checked for a freon leak, best way to do this is to recharge and add dye, with a uv light you will be able to fine the leak, most auto parts sell the dye, and the flash light you will need to fine the leak, good luck.
Jul 08, 2010 | 1999 Oldsmobile Alero
Frit not cooling
Try a defrost period of about 36 hrs, sound like you thermal probe is encased in ice.
Apr 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag plus frig bottom freezer
Whirlpool refrigerator and freezer problem. a cup was place in the refrigerator to catch the percipitation coming from an inlet from the freezer. Which they are two inlets located in the center back of the refrigerator from the ceiling adjacent to the floor of the top freezer. the Freezer back t-shape vent goes down to these inlets where the percipitation is coming from. What is this the damper
Mar 17, 2010 | Maytag MBF1956HEQ / MBF1956HEW /...
Not cooling
make sure everything is running. (compressor, Condensor fan, and evaporator fan) If everything is running then does the back wall in the freezer have frost buildup? If yes then its a defrost problem. If no frost and everything is running usually means a sealed system problem. Also make sure the condenser is clean.
Jul 25, 2009 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
85 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
