Question about Watches
Porsche Design P6000 rubber band with folding clasp How to re-size?
Noggin
  • 944 Answers
SOURCE: Replacement for the folding clasp
Go to this link and identify your closest retailer. http://www.julesjurgensen.com/Retailer.asp They should stock many items and be able to get all others if still in stock. If not then most jewelers could make one up, perhaps as good as the original, but i would expect it to be quite pricey. Hope this helps :)
Posted on Mar 25, 2007
  • 2501 Answers
SOURCE: I just bought a Haurex watch with the white rubber
Go back to the supplier; If you cannot get the clasp to work, you should be shown how to operate it (or it should be replaced if it is broken).
Posted on Dec 31, 2009
SOURCE: clasp on watch band is big problem. Will not stay
I will not pay for advice. Skagen should be there for their customers as all big companies are. I understood the advice would be free.
Posted on Jan 16, 2010
escapement
  • 2334 Answers
SOURCE: need a watch band clasp extender
Click on my profile (escapement), then click on Tips and Tricks. There you will find how to order parts from AK. Rate me, please.
Posted on Mar 18, 2010
mcdevito75
  • 1970 Answers
SOURCE: The clasp broke from my Fossil watch. Can the
mcdevito75 here, Without seeing the watch it"s hard to tell, but I would figure the clasp could be repaired, but the cost may equal a new band and clasp. Look for a small watch repair shop in your area and compare repair cost of the clasp with that of a new band.
Posted on Jul 06, 2010
How do I make the watch band smaller?
to adjust the size of your wrist...eat chocolate!
most watches with linked wristbands require the links removing.(small pins to b e pushed out) the type with the chain links usually have a clamp to release to slide the clasp up the band. the instructions should be with the watch manual. or ask a jeweler to help.
please post pictures if need more help so i can see the design
Nov 09, 2011 | Calvin Klein Ck Small Minimal Golf...
I just recieved my new watch, I do not understand how this watch closes or clasps, so I cannot adjust to size. it is 109179wtcl. In the manual I think it is a metal insert but the picture does not help me....
I have had a couple of watches that have clasps like that. Essentially it folds into itself, if you look at the metal part that does not fit the rest of the band you will notice some rectangular openings and two little projections.
Now, to close it you have to pull each side of the bands in, the metal bar should also fold a little as well, then each side should clasp.
I hope this helps, also to get back open you should just be able to pull it open, it will should have no ill-effect on the watch. I really hope this helps.
Mar 07, 2011 | Anne Klein Watches
I bought my bulova 96R105 today, the jeweler placed it on my wrist, but now I can't undo it. Please help
It may have buttons on the sides of the clasp that you must press. If you do not see the buttons on the sides of band, it is a friction fitting, and you must pull on one or the other side of the "butterfly" clasp for it to release.
If you see a large outside clasp, there will sometimes be a fold over safety. This is called a tri-fold clasp. You must pull up the hinged clasp one direction, then the main clasp the other direction. A bi-fold clasp has no safety, and can be pulled one direction to open.
Feb 04, 2011 | Bulova Diamond Accented Calendar #96R105...
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 | Watches
Can't adjust the wrist band on citizec C651
Look where the band connects to the fold-over clasp. There are several holes on the clasp. Use a plastic headed thumbtack or some other small pointed object to push the pin in and move to desired hole to fit your wrist.
If the longest adjustment is still not big enough you will need to add a link to the band. You can contact Citizen Watch at 800-321-1023 they will send you 3 links at no charge.
Oct 21, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Unclear as to how you adjust the rubber band strap
  1. Remove the deployant clasp from the watchband. The clasp is attached using spring bars on each end of the clasp. The method of spring bar removal varies but is usually performed by pushing a small pointed tool (one end of a spring bar tool) into a hole at the end of the clasp. While depressing the spring rod, pull the buckle away from the bracelet to detach. Repeat this for both sides of the buckle.
  2. Step 2 Measure the watchband to determine proper sizing. Use the scissors to cut along the inner grooves to remove needed sections (each section of the rubber will contain a new set of holes for the bracelet spring bars). Cut carefully and conservatively, as this step cannot be undone.
  3. Step 3 Reattach the buckle to the band after resizing. Reverse Step 1, pushing the spring bar in while sliding the buckle back into place.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 16, 2010 | Tissot T Race Case Stainlesssteel carbon...
I need to know how to put on a Haurex watch using it's intricate band
pull the small loop on the end of the metal clasp. place the other strap through the loop and snap closed. fold one end of the clasp shut then the other.
Aug 07, 2010 | Haurex Italy San Marco Chronograph Watch...
I need help
It probibly is a tri-fold clasp or a "hiding clasp" When you look at you watch can you see a clasp? If not you just need to pull from the middle if the back of the band. One end will open to the left another will open to the right. Don't be afraid to pull on it, that probibly is the main problem your having. Movado makes a solid band that can take some punishment
i
Aug 13, 2008 | Movado 0604586 Wrist Watch
Broken clasp on watch band
The only thing you do is go to service center,maybe they have an extra clasp.Somtimes customer adjusted the size of thier bracelet and when ok they leave their udjusted clasp.That's why some service center had an extra clasp.
Jun 17, 2008 | Watches
Watches Logo
307 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
