Question about Samsung Televison & Video
Samsung PS-50C96HDX/XEU Sound No Picture Clicks on and Off Believe it maybe Capacitor or fuse issue how do I fix this (step by step) if not what is solution
  • 325 Answers
Step 1: Open tv
Step 2: located power supply board (center of tv from the back)
Step 3: Look for bulgded capacitors on the ENTIRE board. (ESR meter comes in handy for this)
Step 4: Extract the popped capacitors and look at their uF and voltage ratings
Step 5: Replace with NEW capacitors of SAME uF but HIGHER voltage rating (EX: 1000uF 35v instead of the OLD 1000uF 10v)
Step 6: Solder into place (practice on spare board if needed). Make sure NEW capacitors are correctly installed with positive and negative leads (negative will have a stripe on the side)
Step 7: Reconnect all other components and test BEFORE reinstalling back cover (can't tell you how many times I SHOULD have done this)
Step 8: Report back to me with results.
Posted on Apr 06, 2011
Samsung 63 inch plasma sound no picture
This problem isn't a capacitor issue .Its a Y-sus issue or a panel issue
you need advanced help to solve this .
Jun 24, 2014 | LG RU-42PX10 42 in. HD-Ready Plasma...
Hi my Samsung PS-50C96HDX/XEU was working fine and we went out of the room and came back in and the picture has gone but the sound is working fine. I turned it off for a few hours and turned it back on...
You will need to purchase a board called a y-sustain witch controls the buffer boards on the unit, but first you will need to check the power supply board as well. Now just because it does not appear that the caps are dead does not mean you are getting full power to the rest of the TV. I would check into the Y-sustain board at www.partstore.com or www.shopjimy.com . I hope this information does help.
Nov 23, 2011 | Televison & Video
Please could you advise or help me obtain a full service manual for Samsung LCD 37" TV model no:LE37M87BDX/XEU
If you let us know what's wrong with the TV, we may have a solution, rather than have you taking stabs in the dark about what's wrong.
I mean if it's not turning on, whining, or turns off 3 seconds after being turned on, or just clicks if you try to turn it on, or there is sound but no picture...chances are we already have the solution.
Tell us what's wrong with it, and we'll see what we can do!
Jun 24, 2011 | Televison & Video
This was posted last year. my hitachi 57f500a picture went out and sound. When you power up you can hear the clicks and the red light in front comes on solid. Out of the five leds on the power board...
On the board I believe the fuses are marked PS*** . They look like resistors that are sort of tan in color. In most cases if the 115 volt fuse has opened the horizontal output transistor is possibly shorted. I think that was Q7700 and will have a fairly large heat sink attached to it. Check it with an ohm meter in circuit to verify its good or bad.
Sep 01, 2010 | Televison & Video
I have a samsung LE40R73BDX/XEU LCD TV which continually clicks and eventually switches on. The time it takes to function is getting longer. can you help?
the power supply board is going bad. sorry! if you google "samsung power click capacitor" you will see just what is wrong. Next time buy american, wait, there is no american made TV's
Aug 14, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
I have a Samsung HDTV. when i push the power
this is a capacitor issue , one or more of your capacitors has blown on your power supply.
Apr 22, 2010 | Samsung HP-S5053 Television
Samsung power-up problem
two 2200uF capacitor, two 1000uF capacitors on powersupply board.
Replace it! you will save $300.
Jun 19, 2009 | Samsung LN-T5271F 52 in. LCD Television
Having an issue with a Samsung HCP4752W rear projection hdtv...
if its on for that long its probably not a main capacitor issue a blown capacitor of that size would
have some distortion in its shape look for bulging at the top or bottom or fluid leaks at the base
a good capacitor looks like a small tin can
from the sound of it your problem is elsewhere if the picture is the picture is good then it may be a regulator or power transistor if the picture is distorted then its in your convergence circuit.
Aug 13, 2008 | Samsung HC-P4752W 47" Rear Projection...
1997 samsung tv problem
your tv needs to be repaired call a tech.the tv has a defected power supply or related circuit.good luck
Apr 10, 2007 | Samsung TXG2547 25" TV
Televison & Video Logo
328 people viewed this question
Henry  Thomas
Henry Thomas
