DVD PLALER NO PICTURE OUTPUT. BUT THERE IS SOUND PUT.
  • 84 Answers
Hi, check the rca cables of its continuity or try changing your video cable with the one you know working.
Posted on Apr 06, 2011
My I got sound but no picture on my DVD player
There are three coloured leads on the back of a DVD player if you use composite video - Red is Right channel sound, white is Left channel, yellow is video.
Red from DVD right output to TV right input
White from DVD left output to TV left input
Yellow from DVD video out to TV video in
Sep 03, 2012 | KLH DVD8350 DVD Player
HI i put my DVD on progressive scan by mistake ... i try to press on STOP for 5 seconds ...but nothing change ...i have sound but no picture ??
Try getting the Green component output and put it on the Yellow composite input. Your picture should be black and white. Then you can see the video to change the resolution back to where you need it. Hope this helps.
May 29, 2011 | Zenith Televison & Video
I have picture with the blue ray player but no sound. I plug the same cables into older dvd player and get picture and sound.
Some DVD players will only output sound on one output at a time. For instance HDMI or through the analog (red/white) connectors. Check the on-screen menus on the DVD player and be sure your correct output is enabled.
If this doesn't work, please post the model number of your DVD player along with what connections you are using.
I hope this helps
Mar 06, 2011 | Audio Players & Recorders
I have sound for my Mintek 1710 dvd but no picture
are you using the composite output (yellow) or the component or HDMI outputs. Connect with the yellow first. if you can get into the menu you will probably find a setting to use the component or hdmi output. If you don't get a picture using the yellow output - unit is bad.
Apr 04, 2010 | Mintek MDP-1770 Portable DVD Player
Hi,I can play a DVD disc on the system and get sound from the surround sound speakers but I can't get a picture on the tv,Sony Trinitron.The connetions are from the DAV S500:(DVD only)red and white cable...
First try with yellow video output of DAV-S500 in yellow video TV input to get its picture. (yellow output means composite video out)
Green-Blue-Red video output is component output that will be turn on when you switch the unit into Progressive picture mode, that option would be available in Menu of DAV-S500
Hope this info will help you.
Thanks.
Nov 29, 2009 | Sony DAV-S500 System
Have a samsumg 4600 combo dvd/vhs plays vhs with good sound and picture, dvd only has sound and no picture
need to check the video audio output connectors sounds like it hooked to and output that is only for the vhs
Jul 07, 2009 | Samsung DVD-V4600 DVD Player/VCR
Lights up screen, has sound, but no picture on the units screen!
has good sound--but no picture. the hookup cables are correctly installed
May 05, 2009 | Televison & Video
Cannot play VHS
Combo DVD/VCR players don't output the VHS with Component Video. Most of the time, it won't output over the S-Video either. The high end outputs are ONLY for DVD output. You must run a yellow wire, or use coax cable to get the video. Same goes for the optical digital sound out. It's only for DVD use.
Feb 28, 2008 | Samsung DVD-V6700 DVD Player/VCR
No sound
u gotta make sure all the connectors are right, The dvd player output cables are plugged into the OUTPUT of ur dvd, and they go into the Video Input of the amplifier, U gotta make sure ur speakers are plugged in into right too, out put speakers. Surround system only works on DVDs and some music CDS, so dont expext to have surround sound from all music CDS/
Feb 10, 2008 | Audio Players & Recorders
Hdmi not working
You need to set up the out put of your DVD player. First hook up a non hdmi output to the tv, either component or coax. You don't need to hook up the audio. You should get a picture from this connection. Then you can go into the menu and set your hdmi output to match your tv, probably 1080i. You may have to turn your volume up higher when using the hdmi cable than not. I hooked my audio up directly to a surround sound and don't use the tv's speakers.
Dec 01, 2007 | RCA DRC-285 DVD Player
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
