Question about Samsung Televison & Video
Powers on and off continuously. - Samsung Televison & Video
  • 84 Answers
Hi, there is a possibility that the contact of the power switch was broken or remained pushed by something else or there is rusting on it.
Posted on Apr 06, 2011
AccuWave Magnetron - "Continuous Power Levels" WhirlPool MicroWave Oven
It certainly sounds like something is wrong. My first GE microwave was like this and it wasn't advertised as anything special. After a long life I replaced it with a Sharp (makes most all microwaves) and was disappointed at the cycling on and off. Now Panasonic makes what they call Inverter microwaves with continuous power. I recently bought a GE (probably made by Panasonic) with this Inverter technology and am very pleased with it. Make sure the microwave you have says AccuWave on it, if it does, it sounds like the magnetron may have been replaced with a non-continuous type of magnetron. Was it bought refurbished/returned/clearanced? I think when I was researching this that it MAY have something to do with the type of power supply to the magnetron and not so much the magnetron itself.
Mar 23, 2017 | Whirlpool Accuwave Microwave Oven
Cartridge error 1203
The 1203 error indicates either a communication failure between one of your cartridges and your printer or a short in one of the cartridges. Please follow the steps below to fix the problem:
1. Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply, and power the AIO on. Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
3. Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return?
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4.
4. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
5. Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return?
Yes: Continue to Cleaning the Cartridge Contacts, and then repeat steps 4 and 5 of this procedure. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 6.
6. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
7. Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on. Did the error message return?
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
1. Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
2. Remove the cartridges. Clean the cartridge contacts (How to Clean the Print Cartridge Nozzles and Contacts Manually).
Source: 1203 Error Message on the Lexmark X7170 All-In-One
Oct 08, 2011 | Lexmark X7170 All-In-One InkJet Printer
Amp comes on running 2 12" 450 watt pioneer subs, volume only seems to be about half output, with speakers bridged
This could be the reason. If you look at the specs for this amp you will see that the continuous power out is rated for 380W bridged. The speakers rated at 450W should be able to handle close to 315W continuous. Now if you split these numbers being you have bridged these speakers, you drive each one up to about 190W continuous. The speakers are being driven approximately by 60% of the rated capability. I personally like to keep it right where you got it, not exceeding 80% of the speakers rated capacity.
Here are the specs for the AMP:
  • Specifications
  • Peak Music Power 760 Watts
  • Number of Channels 2
  • Load Impedance Capability 2~8 Ohm (Stereo), 4~8 Ohm (Bridged)
  • Continuous Power (4 ohm) 125W x 2
  • Continuous Power (2 ohm) 190W x 2
  • Continuous Power Bridged (4 ohm) 380W x 1
  • Frequency Response 10Hz ~ 50kHz
  • Total Harmonic Distortion 0.008%
  • Signal-to-Noise Ratio 100dB
  • Dimensions 12" x 2-3/8" x 12-3/4"
  • Features
  • Bridgeable
  • Channel # Capability 1/2/3
  • PWM Regulated MOSFET Power Supply
  • Screw-Type Speaker Terminals
  • Balanced Isolator Input Circuit
  • RCA Inputs 2 Channel
  • Input Level Control Hi-Volt (200mV ~ 6.5v)
  • Built-in Crossover Selectable LPF (80Hz, -12dB/Oct.)
  • Aug 06, 2010 | Pioneer GM-5000T Car Audio Amplifier
    Replaced drum on Dell 1720dn printer. Where is
    This should fix the drum light being on that 1720
    Turn off the power using the switch on the back of the printer. Open the front door of the printer. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash. When the LEDs start to flash, release Continue button. The LEDs will continue flashing until only Error LED will be lit. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit. Wait till the printer completes the POST process. POST is complete when fan noise and rollers stops. After POST wait for 5 seconds Press Cancel button 4 times slowly until the Toner Low LED is lit. This is the procedure resetting the counter. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue. Now only the Toner Low LED will be lit. Cycle the power of the printer: Remove the power cable - Wait for 5 seconds - Plug the power cable back to the printer - Power the Printer on.
    May 13, 2009 | Dell 1720dn Laser Printer
    First Page printing Jibberish with the Zen thing at the end.
    Try these.
    Reset the Photoconductor Drum Counter
    1. Turn off the power using the switch on the back of the printer.
    2. Open the front door of the printer.
    3. Hold Continue button down, power on the printer, and continue to holding Continue down until the LEDs begin to flash.
    4. Close the front door. Continue, Ready/Data, Toner Low and Load Paper LEDs should be lit.
    5. Wait till the printer completes the POST process.
    6. Press Cancel button 4 times slowly until the Toner Low LED is lit.
    7. Press and hold Continue until all LEDs begin to cycle in sequence, then release Continue.
    Now only the
    8. Cycle the power of the printer.
    - Remove the power cable
    Feb 24, 2009 | Dell 1720dn Laser Printer
    Message says cartridge error 1203 and it wont
    Step Action 1 Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply, and power the AIO on.
    2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
    3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on.
    4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
    5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
    6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
    7 Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
    Feb 23, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
    Cartridge Error Message
    Feb 16, 2009 | Lexmark X7170 All-In-One InkJet Printer
    Replaced colour cartridge and got error 1203
    Power off the All-In-One (AIO) and remove the power supply fromthe back of the unit. Wait 30 seconds, then reinsert thepower supply and power the AIO on.
    Yes:Continue to Step 2.
    No: Print a test page. If the test page prints, the error is resolved.2 Open the top cover of the AIO and remove bothcartridges from the AIO. 3
    Power off the AIO and remove the power supply from the back of theunit. Wait 30 seconds, then reinsert the power supply andpower the AIO on.
    Yes:There is a hardware problem with the printer. Continue to ContactingLexmark below.
    No: Continue to Step 4.4
    Power off the AIO and remove the power supply from the back of theunit. Reinsert the power supply and power the AIO on. Open thetop cover of the AIO and insert the color cartridge. Close thetop cover.
    Yes:Continue to Cleaning the Cartridge Contacts, thenrepeat Step 4. If you have already tried cleaning the contacts,continue to Checking the Cartridge.
    No:Continue to Step 5.5
    Power off the AIO and remove the power supply from the back of theunit. Reinsert the power supply and power the AIO on. Open thetop cover of the AIO and insert the black/photo cartridge. Close the top cover.
    Yes:Continue to Cleaning the Cartridge Contacts, thenrepeat Step 5. If you have already tried cleaning the contacts,skip to Checking the Cartridge.
    No:Print a test page. If the test page prints, the error isresolved.
    Nov 12, 2008 | Lexmark X5470 All-In-One InkJet Printer
    Will not turn on
    When holding the power button, to turn on the device, the screen pixelates dark and then goes blank. If I continue to hold the power button the screen will continue to pixelate dark and then go blank. In the end, the device still will not turn on.
    Dec 18, 2007 | Garmin GPSMAP 180 GPS Receiver
    Televison & Video Logo
    Henry  Thomas
    Henry Thomas
