Question about Abit AW9D-MAX Motherboard
Good day all! My motherboard is an Abit AW9D-MAX From today morning I have not power on signal at the PS-ON pin. (14.) Please, help, what element pull down to the ground this pin. I prepared a short connection with a swich, but this is not a good service ... I have smd work station, and I can repaire, if I know, vhere is the problem. Best Regards Janos Lenarth
  • 108 Answers
Don't change the pin connection, change the power supply either.
Posted on Apr 06, 2011
Need parts for my awd9 mother board. heat sink for processor, wiring diagrams and wire harness. Also is a 480 power enough to run a invidia gen6 256 graphics?
you can get the power sup. at any computer store.the cpu heat sink you need to know the wattage of the cpu before you get the heat sink fan.And far as wiring diagram your book the came with the board has it if not you need to go to the web site of board to get it.All the plugs fit dvd or cd rom hard drive and motherboard have its own from the power sup. ok jim
Oct 25, 2013 | Abit AW9D-MAX Motherboard
1 long beep in post
Hello one long beep, is a failing ram module.
Try to renew the modules, or remove the modules, and insert one at the time.
Just to test one of them for fault.
4x 240 Pin DDR2, Dual Channel DDR533//667/800, up to 8 GB
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
One short beep is normal.
Good luck
Jan 23, 2013 | Abit AW9D-MAX Motherboard
Abit aw8-max error 4E
I found this link that may help. but due to you not posting you system specs i am unsure of what your trying to run. could be a processor issue or video card . you need to be detailed in you system to get good answers.
http://forums.hexus.net/abit-care-hexus/165643-aw9d-max-hangs-4e-error-no-post.html
Sep 30, 2011 | Computers & Internet
I can't install Windows, (7 or XP) I've tried various drives and each time it goes through the copying process but it sticks at the starting windows point
I'd definately be using a KNOWN good drive or better yet a new one to see if the problem stops. When I say good I mean one that's been through a software confirmation,like tuff-test pro(only available to technicians or pirates,lol). You can also try a different cable,a different cd or dvd drive & if your copy of either windows is a burnt one(like no-one's done that),re-burn it at the slowest rate possible(4x is good) & try again. It's definately a hard drive issue of sorts if your using legit cd or dvd from microsoft.
May 16, 2010 | Abit AW9D-MAX Motherboard
I an trying to set up raid 0 with two 500 gig wd hard drives on my abit awd9-max on a new install. I am running xp.raid is enabeled in bios. I hit f6 on windows setup installs dirvers but seems to be a...
In bios make sure the raid chipset is active. Ususally there's 2 one needs drivers one doesn't. I use the one that doesn't then in bios there should be a way to set up your array. Raid 0 is striping mode so you should only see one hard drive,the d drive should be the cd/dvd device. If this is right then you did it right.If it were raid 1 then you would see both hard drives,because one is mirroring the main drive for backup.
Dec 31, 2009 | Abit AW9D-MAX Motherboard
The same prob
hey there, first of all, just want to make sure you cleaned and reapplied thermal paste after removing heat sinks (arctic silver 5 the best). Next, do a deep CMOS clear (shorting out the pins on your mobo) followed by booting 4-5 times continuously while holding the INSERT key. This ought to get you back into your BIOS. Good luck, let me know if you need more help.
seth
Jun 19, 2009 | Abit AW9D-MAX Motherboard
AA8 DuraMAX won't power up
if you are sure that the ps is ok replace the motherboard
Mar 21, 2009 | Abit AA8-DURAMAX Motherboard
New Samsung SH-S203 DVD writer with SATA has a plug-in in the back that doesn't seem to match the plug on my SATA cable which goes from my ABIT AW9D-MAX motherboard to my Pioneer burner which also has a...
The power connector is really similar to SATA connector. It's not like IDE/EIDE. It should be a flat connector.
Take acloser look, most of the times both connectors are very close.
Jun 28, 2008 | Computers & Internet
About motherboard
This is a very general question. Try the manufacturer's web site. Most also have forums where experienced users of a specific board will be able to help. Tom's Hardware and Anand Tech are also good sources.
Aug 24, 2007 | Abit AW9D-MAX Motherboard
Abit AW9D-MAX Motherboard Logo
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
