Phaser 8400N powers on to this Error code 37016.43.77598
  • 4,323 Answers
Hi
This error code means that one of the heaters in the print head has failed or is not warming up enough. This is not a cheap fix as either the heater/print head assembly or the electronics module should be replaced to remove this error. Hope this helps...please post back for further assistance.
Daniel
Posted on Apr 06, 2011
How to set up printer to print double sided. Printer Xerox Phaser 8400
First look at your printer identification.
You can see it in either the display or on the startup or configuration pages.
It must have a "D" in the name for you to be able to do automatic duplexing. i.e. 8400DN or 8400DX . Then you can scroll to printer setup
and select defaults, and then turn on the duplex, or double sided printing.
If yours does not have a "D" i.e. 8400, 8400N then you would need a new sim card to enable the duplex option.
Oct 22, 2009 | Xerox Phaser 8400 Laser Printer
37,002.47 in Xerox Phaser 8400
This is an electrical error in the printhead 650-4303-00. Unfortunately it is expensive.
Whit
Item, Inc.
Aug 10, 2009 | Xerox Phaser 8400N Thermal Printer
How do I remove ink from a Xerox Phaser 8400 - I want to load new ''fresh'' ink
I use a pen or something similar to work it up the loader and the stab it wit a push pin or paper clip to lift it out. You'll need to run some solid color pages to purge the ink from the printhead.
Xerox Phaser 8400 Fault 37,008.44:9490
this is a Preheater error 37,008.44 I will put the link below so you can see how to fix it the repair for that error is on page 105
https://www.office.xerox.com/partners/products/Phaser8400/SQRG/8400_85XX_Service_Manual.pdf
Jul 23, 2009 | Xerox Phaser 8400N Thermal Printer
Xerox 8400 Printer error code 37,002.47:181994
37,002.47: PEST Error - Printhead Left jetstack disconnect. The left jetstack is
not drawing the expected power from the supply.
Could be a connector came unplugged. Could also be ink spill on circuit board, causing it to go haywire.
Jul 20, 2009 | Xerox Phaser 8400N Thermal Printer
Ink not being removed from metal drum, causing jam
Normally indicates that the mintenance kit is drying out and not properly lubricating the drum.
Or non xerox ink sticks have been known to cause that.
Jul 14, 2009 | Xerox Phaser 8400N Thermal Printer
Error code 07007.40:135989 Phaser color printer 8400
7,007.49: The process motor stalled while tilting the head.
Troubleshooting Procedure for 7,007 Error Code
Step Questions and Actions Yes No
1. Check the Printhead wire routing.
2. Remove the Printhead and inspect the
Printhead tilt and drive gears for ink
spills.
3. Re-route the wiring.
4. Clean around the gears and Printhead.
Did this correct the problem?
Complete. Go to Step 2.
2 To ensure Process Drive is correctly aligned,
homed, and free from damage, see “Homing
the Process Drive Train” on page 6-8.
Complete. Replace the
Process
Drive.
Jun 30, 2009 | Xerox Phaser 8400N Thermal Printer
Xerox Phaser 8400 gets no power
I have been hesitating on answering this because people hang me out to dry on phaser printers when I give them good info. But here goes.
What you can try is go to the back of the machine, whre eh on off switch is located. there are 2 larger thumb screws you twist to align with the back frame. That holds the main board in place, Losten them, remove the main board, reseat the RAM memory into its slots, re insert the main board and try turning it on. If that doesn't work the most likely problem, ( 90 % likely) is the electronics module. And I am sure you did not pay as much for the machine as an electronics module would cost, Generally they are over $1000. Best price.
Jan 21, 2009 | Xerox Phaser 8400 Laser Printer
Can anyone help I have a Xerox 8400N and im getting 10mm image printing down one side rest of page blank
About a 95 percent chance that you have a bad print head.You can try cleaningn cycles and also jet substuitution but your problem is blocked jets.
You could have a piece of paper between the drum and print head.
Dec 22, 2008 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400N Printing Stripes
When you go into the eliminate light stripes there is also a mode called Jet Substitution. You can sometimes bypass the bad jets.
If that does not work then the print head will most likely need to be replaced.
You can replace the printer for less than the cost of a print head normally..
Jul 08, 2008 | Xerox Phaser 8400 Laser Printer
16 people viewed this question
jasbo
jasbo
