Question about HP LaserJet 4L Printer
Printer not picking the paper and a red light is on
HP Laserjet printer top door hinges are broken. Is there parts available and if you do then I need instruction how to. Thank you
Posted on Sep 03, 2011
My Hp officejet k7100 is not picking up paper and sometimes it ll be showing red light,
You have to clean your printer and also need to clean paper picking sensor with clean dry brush.
Aug 24, 2016 | HP OfficeJet K7100 Photo inkJet Printer
Red light stays on... wont print wont pick up paper... cleaned as much as I could...
There are a lot of conditions that cause the red light to come on. These include toner cartridge empty, paper jam, waste toner tank full, etc. The only good way of determining the printer fault is to check the smart panel software on your computer. It will tell you what the printer is experiencing.
If the printer can't pick up the paper, check the condition of the paper pickup roller. It is located in the back, and above the paper tray. Often it get dirty and cleaning it with a damp cloth helps it to pick up paper better. Hope this helps you.
Dec 29, 2010 | Samsung CLP 300 Laser Printer
Paper only feeds 1/2" then stops and red light goes on
The paper is not being picked up quick enough. The cause is probably a worn or dirty pick up roller. Try cleaning the pick up roller under the machine, the tend to become dirty with paper dust and hence lose grip and slip on the paper. If its worn you can try cutting new tread in it with a stanley blade, just be careful not to cut right through the pick up tyre.
Jan 26, 2010 | Xerox Phaser 6110 Laser Printer
Printer shows a red light for paper. It will not
Remove the paper tray and clean the feed roller with alcohol or water.
Oct 04, 2009 | Brother HL-2040 Laser Printer
Samsung CLP-300 picking up too many pages
Hi
Thanks for using FixYa. Paper jam is a very common problem with the printers.
First of all clean off the rubber piece that pulls the paper into the printer from the tray with rubbing alcohol, and also take a knife to the rubber piece to rough it up to create more traction.
To clear the paper jam problem you need to remove the back roller mechanism to get at paper. If still the problem persists, then check the following to resolve the issue--
1. Please check all interlocks, electrical and signal connections are seated properly.
2. Front cover, back cover and lid are closed properly.
3. Power plug and USB cable are connected.
4. Printer is turned on with switch on the back.
5. Toner signal lights sequenced, with yellow overall led on.
6. There is some noise of paper roller movement.
7. Toner signal lights all out, overall status light turned to red
8. No visible paper in paper tray or anywhere else.
9. No paper in tray---added paper
10. Waste toner container is full or not installed ---empty, installed properly.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Samsung CLP 300 Laser Printer
Will not pick up paper from tray. Red light blinks indicating a paper jam. Prints fine if single sheet thru bypass slot.
Not picking up paper indicates either a worn nip roller (rubber on feed spindle) or you have a broken gear in the feed mechanism.
Aug 14, 2009 | Brother HL-2040 Laser Printer
CLP300 not picking up thicker paper
this printer only supports up to 120gsm paper,any thing thicker will get jamming errors
Jun 12, 2009 | Samsung CLP 300 Laser Printer
Paper tray is full and the paper light keeps flashing.
First check the machine for paper jams. If not, remove the paper from the paper tray and reinstall it. Then try to print from the MP tray.If this works, check paper size settings on the printer driver, or the small black arm which hangs down next to the paper pick up roller, and is the paper sensor.
Feb 09, 2009 | Brother HL 5040 Laser Printer
Phaser 6110 - red light on, not printing
Just had user with same problem. Printer status = paper jam but no paper in feed path therefore suspect paper pick up problem. Asked user to take out paper tray and turn paper in tray over. This solved problem.
So possible fix = turn paper over or try different paper.
If printer is old try cleaning pickup roller. My users printer had only done 227 pages.
Sep 11, 2008 | Canon PIXMA® MP530 All-In-One Printer
Printer problem
hi, Take out the toner and check for a paper jam.turn the printer upside down and check under the paper tray for a jam. When you reset the printer check to see if the printer picks up the paper, if it tries to pick up the paper then the red light flashes you should rough up the roller on the front above the paper tray, the rollers sometimes get smooth and won't pick paper up. You should also look inside where the toner cartridge goes and there are some little plastic flaps.Check that these are not stopping the paper going it. hope this helps
Sep 25, 2007 | Brother HL-2040 Laser Printer
HP LaserJet 4L Printer Logo
Seeker5211
Seeker5211
