My Eurodesk MX8000 started having problems when powering up. The whole board would light up red & green ( peak, -20 & master solo), but it would successfully power up after a few attempts, I thought it might be the switch. The other day, after a many hour session, the board was still powered up but not in use, there was a loud crashing sound and the whole board lit up red & green. I've read about similar problems, Can you help diagnose?
  • 1 more comment
  • a_k_a_ken Apr 06, 2011
    I have both the power amp and mixer opened and I see no visual signs of a problem. The capacitors, fuses and the switch LOOK fine.
    I'm looking close all over and am not seeing any abnormality. I know the crashing sound indicates something blowing out but does that corelate to it happening occasionally at start-up? Is it possible that it is the switch even though it looks okay?
  • a_k_a_ken Apr 07, 2011
    This does not seem to be a signal path problem but a power sorce problem. I have to agree with SuperTech-11 with the exception that I don't see anything that looks improper. If something eventually blew, would there have been the occassional symptom prior to complete failure? And is it possible that could produce no visible sign? The board is clean and I don't see how dirty pods could cause this type of thing. Thank you.
    Genius:
  • 1,126 Answers
The first thing to check is the main out puts that is what will go first, and it will cause shut down problems, and if they are ok, then put new heartsick compound on the back of the out puts.
Posted on Apr 07, 2011
  • Veril Gillette
    Veril Gillette Apr 07, 2011
    If it is happy at start up,then check the power supply, electrolytic caps can look good and still be bad, also check the rectifier could be leaky and needs to be replaced, this is a common problem.
  • 2,098 Answers
Hi Ken,
If you have a contact cleaner, spray the switch, volume control and other potentiometer. This symptom may due to dirty contact of that parts...
  • 1,591 Answers
There's a good chance you have failing electrolytic capacitors probably in the power section.
Any caps that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
That loud crash you heard was likely an electrolytic capacitor exploding, so that should be easy to spot!
If you are handy with a soldering iron an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
A lot of incorrectly manufactured capacitors are ending their lives these days. They usually outlive the warranty, but not always, and not always by much - but depending on use, some lasted much longer than others, but inevitably failed within 1.5 - 3 years in most cases.
this issue spans plasma TVs, as well as large and small LCD TVs and monitors, amplifiers, mixing boards, PC motherboards, PC power supplies and many other devices - it's not specific to one company, brand etc.
The parts are cheap, and skill required is minimal - even if you don't know how to solder, there's a plethora of videos that you can find that will show basic soldering technique well enough that you'll be able to do this repair the day you watch such a video (assuming you have a soldering iron, desoldering braid or desoldering pump, and solder....flux isn't even necessary if you get a resin core solder)
Even a basic soldering kit at Radio Shack or The Source is cheap....much cheaper than replacing the MX8000 by a long shot!
Posted on Apr 06, 2011
  • Norman Skinner
    Norman Skinner Apr 06, 2011
    We're stilll looking for something that probably blew really bad, so look for very short wire looking leads where a component should be, and see is any regulators or transistors have part of their face missing.
My Onida Power solo 20 L 1200wqtts Microwave Oven domestic use model start moving turntable when the door is opened & stops when door closed.There is no oter problem like door & door Switches,
Possible that the switch or the lock is jammed or that the relay or main processor board is fault. Please take care that the microwave is not ON as this is dangerous.
Aug 18, 2012 | GE Microwave Ovens
STANDYBY LIGHT FLASHES RED GREEN RED GREEN HOLDS FOR 2 SECONDS THEN THE SEQUENCE STARTS AGAIN BUT THE TV HAS TURNED ITS SELF OFF
The power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem...
Jul 15, 2011 | Televison & Video
Canon IP5200R printer. Green & red led`s flash 20 times, pause & repeat. print head will not come out of park position on righthand side. Fault occurred while printing a photo error 6500 displayed
Hello!
Error 6500 or green and red flashes 20 times, mean hardware error. Particularly, the Logic Board Assembly
There are two possible fix: first is to reset the printer's waste ink counter and the second is to replace the Logic Board Assembly (part # QM2-2733)
Reset the Waste Ink Counter:
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the
Power button. (DO NOT release the buttons. The Power LED lights in green to indicate that a
function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button 4 times (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
For technical help:
  • For toll-free technical support, please call 1 (800) OK-CANON (1-800-652-2666) during regular business hours (currently Monday-Friday 10:00 a.m. - 10:00 p.m. ET, excluding holidays).
  • Toll-free TDD Support Line for the Hearing Impaired is available Monday - Saturday (excluding holidays) at 1-866-251-3752
Hope this helps!
May 18, 2011 | Office Equipment & Supplies
TV just turned off while watching. standby light flickering red 7
Ur power board have dead capacitors.U Know how to solders?Take the tv aparts,check these capacitors in the power board for dead capcitors like puff up or burst open.Replaced these capacitors to get power back.Or buy and replaced the whole reburbish power board at Shopjimmy.com,Ebay.com.
Jan 21, 2010 | Televison & Video
My 32 in. sylvania power light blinks green & doesn't turn on & goes right to the red standby light. Why
Power board is dead,must replaced parts like capacitors puff up or burst open.Or replaced the whole power board.The websites Shopjimmy.com,Ebay.com have reburbish power board part.
Jan 13, 2010 | Sylvania LC370SL8 37 in. LCD Television
No. You said you can fix anything but I can't
Your posting here seems to be the middle of an existing conversation. I'd like to help, but I'll need a bit more info. Can you describe how you have this connected to the system please?
It seems a bit odd that a Solo indication would cut off all output as that is usually a feature to allow you to hear the channel without it being sent to the mix. Is there a solo option for the mains?
Any information that you can provide that details what happens and how you are connected would help. Also, is there a pattern at all for when this occurs? In other words, is this more likely to happen after the unit has been in use for a long time or less likely?
Thanks,
Dan
Jun 29, 2009 | Behringer EUROPOWER EP2500 Amplifier
Need fuse block diagram for a 1991 Plymouth Voyager
Cavity
1 20 amp yellow hazard flashers
2 10 amp red heated mirrors
3 20 amp yellow body lights
4 not used
5 20 amp yellow windshield wipers
6 20 amp yellow turn signal lights
7 10 amp red radio
8 not used
9 7.5 amp violet illumination lights
10 2 amp pink left tail lights
11 2 amp right tail lights
12 not used
13 20 amp yellow rear window wiper/washer
14 2 amp pink speed control
15 10 amp red gauges, warning lights
16 not used
17 10 amp red left low beam headlight
18 10 amp red right low beam headlight
19 20 amp yellow stop lights
20 20 amp yellow rear a/c heat
21 20 amp yellow fog lights
22 20 amp yellow park lights
23 20 amp yellow battery
24 20 amp yellow back up lights
25 circuit breaker power windows,power vent windows
26 30 amp lt. green a/c heater blower motor
27 circuit breaker power door locks
28 not used
May 21, 2009 | 1991 Plymouth Voyager
The players red and green light keeps flashing and wont come on
THIS CAN BE SOLVED BY CHANGING THE MAIN POWER SUPPLY BOARD OF YOUR DVD PLAYERS. The main problem should be the Main Capacitor in the circuit. The safer side is to change the whole board.
Apr 23, 2009 | Televison & Video
Pt5598 rplaced convergence board no luck.
If the picture is still bowed, the power supply fuses are open.
Check the power supply on the red connector for + and - 20 volts.
The fuses are on the main board,are on the deflection module in the middle, tward the front of the TV. They should look like green (or brown) resistors. An ohmmeter check will show which ones are bad.
They should be 3.5 amps. Replace with 4 ohm GMA fuses with pigtails if you can't find picofuses. I also had a set that would fry the 1 ohm resistor on the 20 v supply. This was near the fuses.
I replaced the whole module to fix that.
I hope this helps. Lee, www.crazycomputers.com
May 31, 2008 | Akai PT5598HD 55" Rear Projection...
1999 ford explorer car stereo install
Heres the whole list. 1999 Ford Explorer Constant 12V+ Light Green Switched 12V+ Yellow/Black Ground Black Illumination Light Blue/Red Dimmer n/a Amplifier Remote Blue Antenna Right Front Front Speakers 5" x 7" Doors Left Front (+) Orange/Light Green Left Front (-) Light Blue/White Right Front (+) Dark Green/Orange Right Front (-) White/Light Green Rear Speakers 5" x 7" Rear Doors Left Rear (+) Gray/Light Blue Left Rear (-) Tan/Yellow Right Rear (+) Orange/Red Right Rear (-) Brown/Pink (from the12volt.com) Best of Luck.
Sep 28, 2007 | Car Audio & Video
156 people viewed this question
 Grubhead
Grubhead
