Question about Acer Aspire One D255-1549 Atom N550 1.5GHz/1GB/250GB/bgn/NIC/WC/6C/10.1" WSVGA/W7S/Black LU.SJ0D.089 Netbook
I used my aspire one d255 and drained the battery 'til it switched off automatically, i plugged the charger and it worked finished what i was doing and shut it down. the next day it won't power on. plugged the charger and a red light is seen on the battery icon at the bottem left side of the keys ( where most of the led lights are) what is wrong with it? i just bought this last dec2010.
  • 109 Answers
Try to remove the battery for about 1 mn, then reinsert it and try.
Posted on Apr 06, 2011
My tablet won't power, only shows battey then shuts off, won't charge
Most likely a dead battery or bad charger. Test and/or replace the battery or charger.
May 10, 2014 | Noria 7 Android 4.2 Tablet - White
My aspire one D255-2256 will not shut on , Can you help me please ?
What do you mean by shut on ?
If your laptop works fine while plugged in but stops working while unplugged it's likely that either your laptop battery is bad or your laptop is not charging the battery properly.
Below are steps that can be taken to help identify the cause of this issue. Leave power plugged in
Make sure the computer has been charging from the power plug for at least two hours before attempting to unplug it.
Remove and reconnect battery
In some situations the battery can become loose.
Removing it and then put it back into the laptop. Third-party utility
Use a third-party battery utility to determine the total capacity of the battery. For example, BatteryCare is a free software utility capable of doing this.
Replace battery or AC adapter If your computer is still in warranty we suggest skipping to the next step.
If the above steps have been completed, we suggest replacing the battery in the computer or AC adapter. In most situations it's a bad battery. Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
if it does not start in safe mode it could well be a hardware problem
Check all power and data leads from motherboard to hard drive and all of your cd/dvd drives make sure connections are secure dust free and not faulty computers need all power and data to travel through every working device and to finish its cycle so any faulty lead will end in computer error or shutdown / fail to boot or to reboot on a cycle make sure your computers RAM modules are securely seated with no dust in the sockets also the Cmos battery has charge and seated with no dust in the sockets some motherboards cmos batteries are soldered in might be getting hot check you CPU make sure its securely seated and has thermal grease http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
or it might even be a virus until you have your laptop up and runing you wont be able to run your antivirus software.
Hope this helps
Jan 21, 2013 | Acer Aspire One D255-2256 Netbook
Acer aspire one D255 will not charge
You don't have a real serious problem. Just use the Power Cord. Now if the Power Cord does not work, that's a real problem. If your power cord is good and you can use your laptop with it, then the problem is your battery is bad if it will not take a charge. It's time for you to buy a new battery.
Apr 09, 2012 | Acer Aspire One D255-2670
My acer aspire D255 has froze.black screen and wont let me switch off.
Direct remove your laptop battery & insert then power on
Sep 25, 2011 | Acer Aspire One D255-2670
My Acer Aspire One D255 will not turn on. Light shows blue then immediately goes off. Won't boot on or anything.
Make sure that you have a charge. Try plugging it in and turning it on. If it still doesn't work then you might have a low battery, bad charger, or there could be a problem with the power supply. A bad charger and or a bad power supply would require replacements. You can probably find the charger at best buy or newegg.com. The power supply could probably be found at newegg.com. You might try taking it to a local electronics store and see if they have a different charger they can test it with, that way you would know for sure it isn't the charger.
May 03, 2011 | Acer Aspire One Netbook
How do you use the crystal eye web cam?
The Crystal eye web cam will run itself when needed.
IE: If using Skype for video calls, it'll automatically switch on when the call is made.
Apr 26, 2011 | Acer Aspire One D255-2670
Hi, my acer aspire one d255-1549 won't power up. when i connect the charger, the red battery indicator light is on, still won't power up. i need help, thanks
Try booting from an operating system compact disk you used for installing the first operating system or any other operating system same as the one you were currently using
Apr 09, 2011 | Acer Computers & Internet
I have an ACER Aspire 5052AWXMi. The battery is drained as I was trying to charge it while the battery was running down but it didn't work. The battery is fully drained and my charger (and friends'...
had this problem with a friends, you may have to update the bios, acer know about the problem with the batterys, flash the bios with the update, turn the laptop off remove the battery and switch it on using the plugged in power, now put the battery back in while its on, leave for 5-10 minutes and it should then start charging. its a fault with the acer one's
Sep 03, 2010 | Acer Aspire One PC Notebook
Acer Aspire One D255-1549 Atom N550 1.5GHz/1GB/250GB/bgn/NIC/WC/6C/10.1" WSVGA/W7S/Black LU.SJ0D.089 Netbook Logo
94 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
