Shield status are off cannot get them back on
    Sergeant:
    Champion:
  • 293 Answers
Is this error are for antivirus?
reinstall your antivirus application
Posted on Aug 06, 2008
WHIRLPOOL DUET GAS DRYER WGD87HEDW1
Unplug for 1 minute. Plug back in. Check status
Apr 17, 2016 | Whirlpool WGD87HEDW Duet WGD87HEDW 7.4 cu....
On a 1991 silverado do I have to put the shield back on the gas tank I have a bigger tank and my shield will not fit
You don't have to put the shield back on, no. If you aren't then you shopuld give it a coat of paint followed by a rust protectant.
Nov 17, 2013 | Cars & Trucks
HAVE A MEGALOOP+ hearing aid SYSTEM. THE SOUND FROM A NEW DIGITAL TV IS DISTORTED CAN I ALSO PLUG IN A MICROPHONE TO USE WITH THE NORMAL SCART ATTATCHMENT IF SO WIRING INSTRUCTION PLEASE
I would imagine the level is too high. Does your loop amplifier not have a sensitivity control?
You could come out of the scart socket but check for a headphone volume control first!
The connection standard requires that the pins are utilised in the following manner:
Hope this is useful.
scart.gif PIN USE LEVEL / IMPEDANCE 1 Audio Output (R) 0.5V / 1K-ohm 2 Audio Input (R) 0.5V / 10K-ohm 3 Audio Output (L) 0.5V / 1K-ohm 4 Audio Ground -------------------- 5 Blue Ground -------------------- 6 Audio Input (L) 0.5V / 10K-ohm 7 Blue 0.7Vp-p / 75ohm 8 Status (CVBS) L:0-2V H:10 - 12V / 10K-ohm 9 Green Ground -------------------- 10 Data D2B (Inverted) -------------------- 11 Green 0.7Vp-p / 75 ohm 12 Data D2B -------------------- 13 Red Ground -------------------- 14 D2B Ground -------------------- 15 Red 0.7Vp-p / 75 ohm 16 RGB Status/Fast Blanking L:0-0.4V H:1-3V / 75 ohm 17 CVBS Video Ground -------------------- 18 RGB Status Ground -------------------- 19 Composite Video Output 1V / 75 ohm 20 Composite Video Input 1V / 75 ohm 21 Case Shield ---------------------
A 21 pin SCART cable with all pins connected is wired as per the following diagram:
Jan 23, 2011 | Televison & Video
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
How do i turn my hijack shield back on?I can`t remember how to go to my shield settings.
Open the program. Click the Shields tab on the left. Click the Shield Summary tab. Go down to the IE Hijack tab and click it. On the page that comes up put a check in the IE Highjack under CriticalWeb Browser Shields. Check your other shields. Any shield with a triangle and exclamation point is not on. If it is on you will see the blue shield.
Oct 21, 2009 | Webroot Spy Sweeper (spysweeper) for PC
Microwave waveguide spatter shield burned through
THE PART IS CALLED A WAVEGUIDE COVER AVAILBALE FROM REPAIRCLINIC.COM
Jan 20, 2009 | Microwave Ovens
Tv turns on and than red status light comes on and shuts down
it sounds like the 3300uf caps on the power supply have gone bad.look at them and see if they are pregnant. if so change them. while you have the shield off see if any other caps are pregnant, if so you might want to think about having the chassis repaired.
Dec 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
I need an I/O back panel shield for an XFX NFORCE 680i LT SLI MB
You may get more joy if you sent them an email to contact@xfxforce.co.uk Give them the serial number of the board and hopefully they will respond. Failing that technically you have to send it back to tiger as they sold it to you. Usually the io shield fits to the motherboard layout. Although there is not much difference between shields they are not normally sold separately. Have you tried "googling"it
Feb 26, 2008 | Computers & Internet
Shield reattachment
Well, I don't have a solution to getting it back on, but if you could tell me how to get the stupid thing off, I could maybe figure out how to get it back on for you. :) I can't find anything about it via Cosco either. grrrrr!
Aug 08, 2006 | Cosco Alpha Omega 22-180 - with Shield
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
