Question about SanDisk 2GB microSD Memory Card
How do I install SD 2gb memory card into my Sharper Image camera? Model No: FC F3405471
samkong
  • 106 Answers
SOURCE: Can't format 2Gb Extreme III SD card in Canon G9 camera
Did you try formating with the Camera? Before that, Try formating with Windows Disk manager, then format with the camera, It will solve the problem.
Posted on Nov 02, 2007
pshinde23
  • 136 Answers
SOURCE: My computer does not recognize my SD 2GB SD Flash
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
Posted on Jun 25, 2009
SOURCE: i forgot my micro SD sandisk 2GB memory card password
For Nokia s60 1st and 2nd edition phones.
1. First Install FExplorer in your phone memory.
2. Got to drive C: , you will find a file called mmcstore
3. Send it to your pc directly and open it in notepad or rename the file.
4. At the end of the file you will find your password.
For Nokia S60 3rd Phones, Nokia N-Series and Nokia E-Series
There is almost no way yet known to hack the memory card password in case of these types of phone but there is a way to do it some of the s60 3rd edition phones and almost all the E-series phones.
The remote lock option in E-Series phone allws you to unlock your phone by sending a sms.
The only thing you have to do is to activate this feature by going to Tools | Settings | Security | Phone and SIM | Allow remote lock menu. The password of your memory card will be your remote lock message.
So you have to just send a sms containing your remote lock message that will automatically change your memory card passsword.
Posted on May 30, 2010
parasgumbhir
  • 179 Answers
SOURCE: i forget my memory card
does it have a switch on the outside, if so flick it It should have a little nubby switch right there. You pull it down to lock, up to unlock. if not then You can replace the switch by placing a piece of tape over the gap in the unlocked position.
Posted on Oct 07, 2010
parasgumbhir
  • 179 Answers
SOURCE: 2gb sd card not detected
install proper drivers for the sd card..
Posted on Nov 08, 2010
Powershot a 400. brand new chip. can not take picture?
You don't state which memory card you have installed.
But if you have installed one which is SDHC rather than SD you'll get that problem as your camera is only compatible with SD cards up to an absolute maximum of 2G. Even then, it can be unreliable with 2GB cards and so in practice 1GB is the recommended maximum. As the camera is only a 3MP model, 1GB is more than enough even at the maximum image quality settings.
Note that this is a hardware restriction. There is no way to update your camera to accept 4GB SD cards (maximum SD capacity, very few were ever made), and also no way to adapt it to accept SDHC cards (which start from 4GB and go upwards).
Jul 16, 2011 | Canon PowerShot A400 Digital Camera
WHAT SD CARD SHOULD I BUY FOR SHARPER IMAGE HD110
Any of these will work:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007962%20600006200&IsNodeId=1&name=Secure%20Digital%20High-Capacity%20(SDHC)
Class 4,6,10 etc = The speed at which data can be written to the card. The higher the class, the faster data can be written. Try to get a better Class.
Feb 28, 2011 | Cameras
My model is SD 10. Sofar I had 256 MB memory card in that camera. Recently I put 2 GB card. After somedays the camera take long time for processing. Finally in the photo taken day light, I can see only...
switch to a sd card of less than 2gb as your camera's internal image processor power is being used in running or reading the huge 2gb sd card ...and that is the reason the image izz getting white ...try for 1gb or less ..
Jan 31, 2011 | Canon PowerShot SD10 / IXUS I Digital...
New 4G memory card states full have re-formatted but still shows full. Have tried a 2G card but that is ok to use any ideas please
Your new 4GB card is an SDHC card. The S700 works with MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to go with cards 2GB and smaller.
Jan 10, 2011 | Samsung Digimax S700 Digital Camera
When I take a picture it goes to internal memory and not to my sd card. What is wrong?
First, make sure you're using a supported card. The C340 works with MMC and SD cards. If your card is larger than 2GB then it's actually an SDHC card and won't work.
If you do have a supported card, make sure the image storage location is set to Auto. In the Review mode, press the Menu button then select Image Storage (camera and memory card symbol).
Dec 15, 2010 | Kodak EasyShare C340 Digital Camera
Memory card saying "full" when its not
Your problem is that you are using an incompatible type of memory card.
Your camera was designed to use SD cards with a maximum capacity of 2GB. It cannot use larger capacity models, and is also incompatible with the later SDHC cards.
SDHC cards are the same shape and will fit your camera, but have differences beneath the skin and so won't work properly in your camera. Without any memory card in place your camera uses internal memory; it's then only by lucky chance that your camera has sufficient SDHC compatibility to allow you to transfer the internal memory image to the SDHC card when you subsequently insert it into your camera.
Your only solutions are to either use an SD card with a maximum capacity of 2GB or to replace the camera with a later model which is fully SDHC compliant.
Apr 29, 2010 | Samsung Digimax D73 Digital Camera
Trying to install memory card did format and
Although you haven't stated the make, model and capacity of your memory card the information in your question suggests that you have used the wrong memory card.
The CD33 is compatible with SD memory cards but not with the later SDHC models (the HC means High Capacity). They'll fit into the camera just fine as they have the same shape as an SD card, but the CD33 chipset is incompatible at the basic hardware level and cannot format SDHC cards.
To complicate matters further, the original SD specification allowed up to a maximum 2GB, and this was later extended to 4GB but hardly any SD devices can use the 4GB cards without a firmware update. No firmware update was ever released to allow your camera to use 4GB SD cards. Your camera was also designed before 2GB SD cards were available so whilst it may be compatible in theory it was never tested with them.
I'd recommend that you stick to 1GB maximum SD cards unless you use a Kodak branded 2GB version: Kodak's website claims that your camera should work with their own brand card of that capacity, so if it doesn't you can claim on their warranty for a refund or maybe an exchange for two 1GB cards.
If all this is incorrect and you're using a regular SD card of no larger than 1GB then you either have a faulty card or a faulty camera. The only way to find out will be to try a new 1GB SD card from a major brand name. If the camera proves to be faulty then it's beyond economic repair as labour costs for diagnosing the fault alone will exceed the camera value.
I hope this reply has been of assistance and ask in return only that you rate my answer.
Nov 10, 2009 | Kodak EASYSHARE CD33 & Printer Dock Series...
I bought a 2GB SD card for my Kodak EasyShare C330 Camera
Buy a 1GB card (or 2). The spec for the SD card format is going to 2GB but the Kodak C330 not compatible with 2 GB SD memory cards.
Click
Jun 01, 2009 | Kodak EasyShare C330 Digital Camera
Internal memory photos download to sd card
1. Ensure memory card is inside camera.
1. Turn on camera.
2. Press Review button on back of camera
3. Then Press Menu Button on back of camera
4. Select "Image Storage" option (by depressing the joystick on RHS of back of camera).
5. Select "Internal Memory" option (by depressing the joystick on RHS).
6. Select "Continue"
7. Press Menu button.
8. Press "Review" button
9. Press "Review" button again.
10. Press "Menu" button.
11. Scroll down to "Copy" and select this option by depressing the joystick.
12. Scroll down to "All", then select by depressing the joystick.
13. Contents should now copy over from internal memory to SD card.
14. Don't forget to reselect Auto detection of SD card afterward. This is done by turning camera off then back on again. Press "Review". Press "Menu". Select "Image Storage". Select "Auto". Select "Continue".
Jun 27, 2008 | Kodak EasyShare C875 Digital Camera
SanDisk 2GB microSD Memory Card Logo
78 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Carlos Calvo
Level 1 Expert
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
