Question about Karcher Garden
I have a problem with low pressure on my 310 with full mains pressure this started today
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
Low pressure can be caused by several things. If you have 2 wands or a soap / liguid agent wand (if so equipped ) make sure that your using the high pressure wand and not the liquid agent application wand. Per the original packaging there were 3 different wand attachments. Items 3, 8 and 18 of this link (Detail F):
http://www.ereplacementparts.com/karcher-310-19947000-pressure-washer-parts-c-33388_33389_33441.html Just make sure you do not have item 3 attached until you sort out the pressure problem.
Next see this link (DETAIL C) item C-12 (Strainer NOTE there are 2 of them!) http://www.ereplacementparts.com/karcher-310-19947000-pressure-washer-parts-c-33388_33389_33441.html
Close up of strainers:
http://www.ereplacementparts.com/images/part_6414-2520.gif
Make sure the strainer(s) are clean. Remove item 10 and clean it carefully making sure the o-rings are good. Lubricate it with #150 White grease (
Last... reverse flow your nozzles by placing a rag over a hose bibb / water faucet and flush out any corrosion or debris that may have accumulated in the nozzle jet. (With 3 attachments for the wand.. the chances of all 3 being plugged up at the same time are quite rare!)
This should restore your high pressure.
Thanks for choosing FixYa,
Kelly
Posted on Apr 07, 2011
My Lincoln Continental 2000 Model oil light came on engine stopped after 25 feet. would not restart even though oil full. The car started the next day, but had a rattling sound at the top of the motor
Oil light is rather important it goes out if oil pressure is good comes on if oil pressure is low when it comes on damage is expected with continued operation like wearing of main bearings and pistons and cylinders can lead to a engine rebuild
May 30, 2017 | Lincoln Cars & Trucks
My stihl chain saw runs full out without pulling the trigger? what can i do?
carby idle adjustment or a carby kit and clean needed
carby has a high and a low rpm jets
STIHL MS 290, 310, 390
https://www.stihlusa.com/.../instructionmanuals/stihl-ms-290-310-390-owners-instructio...
Instruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! ..... model. Safe use of a chainsaw involves. 1. the operator. 2. the saw.
Oct 13, 2016 | Stihl 16" Chain Saw Repl. Chain Model...
Nearly stalls on start up and at low revs
If you have what is called a "common rail diesel" I suspect that the diesel pump is not providing sufficient pressure for the system at low rpm's I would suggest that you have the pump pressure tested by an accredited diesel pump shop . The faster you spin the engine then the higher the pressure generated by the pump.
Apr 10, 2014 | 2005 Hyundai Tucson
Low oil light comes on , is it low oil pressure or low oil level
it is a combanation of both low oil level =low oil pressure check your oil level and make sure it is on the full mark and drive it to see how pressure is it could also be the oil pressure sending unit good luck
Dec 26, 2010 | 2002 Chevrolet Malibu
Oil gauge keeps coming on, loss in oil pressure
low oil pressure,mainly its thin dirty oil, pump needs servicing/replacing,pressure release spring,weak
Jul 05, 2010 | 1999 Toyota Camry
I just bought a 2002 GMC 1500HD Crew Cab with 223,000 miles. The truck looks and runs like brand new. They were all freeway miles. The problem is this. When it first starts the oil pressure gauge is in the...
Nope, normal on start up is 60 PSI and once warmed up drops to 45 psi. Have the oil pressure checked for a proper reading during start up's when the engine is cold. As for the lifters ticking, that may be a sign that the engine was ran with low oil pressure or no oil and the lifters are damaged, or low oil pressure and the lifters are starved of oil. Try not to drive it and have a proper oil pressure reading, low oil pressure will damage the engine by having the main crank bearing to spin which is a engine replacement. Good luck and keep me posted.
Feb 09, 2010 | 2002 GMC Sierra C/K1500
Knocking noise when accelerating!! It's loudest when I first start my Jeep grande Cherokee leredo (2000) but then only happens when I step on the gas. Any ideas of what this could be. I do need my...
Knocking noise is generally from the engine. What is your oil pressure? If pressure is low and oil is reasonably full, refrain from driving it till the cause is determined. Noise can also come from the transmission or transfer case but more likely it's from the engine.It can come from sticking valve lifters (moderately bad to potentially serious) connecting rod or main crank bearings (always serious) or piston slap (annoying, expensive but not terribly serious unless very bad) Piston wristpins can also knock but are very rare in todays pistons. Either way, this is not an item to ignore.
Jun 03, 2009 | 2000 Jeep Grand Cherokee
Garden Logo
192 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
