Question about Battery Technology LENOVOIBM NonOEM Laptop Battery for 41U3198 42T4549 42T4548 42T4653 42T5262 42T4264 42T5265
My laptop battery is not charging after alarm shut down,Fully discharged
  • 109 Answers
Your battery is dead, get new OEM one
Posted on Apr 06, 2011
One:you can change a new laptop battery.
Two:you can update battery by software(Battery MaxiMiser and Power Management)
Posted on Jul 24, 2013
  • 73 Answers
There are three potential causes for your battery not to charge:
1. Your power supply may no longer provide enough power to charge the battery and power the laptop.
If possible try another power supply.
2. The battery may have failed and needs to be replaced
Most laptop batteries are designed to "self destruct" if they detect a fault with one of the battery cells internally and will lead to a "no charge" situation. This activity is intended to prevent a fire, the battery should be replaced and recycled.
http://www.batteryrecycling.com/
3. The charging circuit in the laptop may have failed. This would require a new motherboard to repair.
My 2005 escape will not start i had the battery fully charged but the alarm sound is very low, when turning the key all the gages jump, check engine light and battery light had been on prior to shutting...
Fully charging a bad battery is a waste of time as the bad cell discharges internally. Best have a load test done on the battery to eliminate it first.
Aug 25, 2013 | 2005 Ford Escape
Tip
How to charge your laptop battery properly? During the the process of notebook...
How to charge your laptop battery properly? solarroll-laptop-solar-charger.jpg During the the process of notebook using, we need no to deliberately charge the laptop battery to 100% state or fully discharged laptop battery to automatic shutdown protecting. The correct way is that charge the battery in 20% state and stop charging in 98% . If the machine has the power calibration procedure, when the battery standard-by time significantly reduced. Then calibrate the battery in time to active the protection circuit performance.
For early notebook batteries (Ni-MH Ni-MH or Ni-Cd Ni-Cd), really need to fully charge and discharge in order to maintain good battery capacity. But for the lithium battery is not necessary even it may damage the battery.
In fact the lithium batteries has a little memory effect. The lithium battery materials is very sensitive to the conditions as temperature, the use of frequency and so on. The battery will be aging after used for some period time (standby time reduced). The natural wear and tear is an important reason, and inadequate maintenance is another important reason.
A well-designed lithium batteries have a very good protection circuit to prevent excessive charge and discharge.As over-charging and discharging of the Sony VGP-BPS8 battery will be the rapid reduction activity. Under the protection of protection circuit, the user fully charge and discharge the battery several times, in fact, impossible to achieve had "full" level.
Sometimes WINDOWS show that battery capacity is 20% or more, you can use 30 minutes. But after used 10 minutes or less the machine suddenly automatically shut down. The reason is that the battery has been aging, the battery protection circuit can not monitors the battery real capacity. In the normal battery depletion, the protection circuit original parameters have been unable to properly reflect the actual situation of the battery
So power calibration procedure is to correct the benchmark protection circuit parameters to accurately reflect the actual capacity . This correction process will often take two or three complete charge and discharge. As previously mentioned, fully charge and discharge will reduce the battery activity. It is not frequently used, usually once a month.
on Jan 18, 2010 | Computers & Internet
How to calibrate battery laptop toshiba satellite m45-s359
Calibrate laptop battery pack under the following conditions:
? When the battery status display seems inaccurate.
? When you observe a significant change in normal batteryrun time.
? When the battery pack has not been used for one monthor more.
How to Calibrate laptop battery
To Calibrate laptop battery pack, you must fully charge, fullydischarge, and then fully recharge the battery pack.
Discharging the Battery Pack Disabling Hibernation
To fully discharge the battery pack, disable Hibernation temporarily.
To disable Hibernation:
? Select the Power Meter icon on the taskbar or access Power Options > Hibernate, and clear the Enable Hibernate support check box.
    To fully discharge the battery pack:
  1. Select the Power Meter icon on the taskbar, or select Start > Control Panel > Performance and Maintenance > Power Options > Power Schemes.
  2. Write down the 3 settings in the Plugged In column and the
  3. settings in the Running on Batteries column, so you can reset them after calibration.
  4. Select the drop-down lists and set all 6 options in both columns to Never.
  5. Select the OK button.
  6. Disconnect the notebook from the external power source, but do not turn off the notebook.
  7. Run the notebook on battery power until the battery pack is fully discharged. The battery light begins to blink when the battery pack has discharged to a low-battery condition. When the battery pack is fully discharged, the power/Standby light turns off and the notebook shuts down.
Dec 13, 2010 | Toshiba Satellite M45-S359 Notebook
I have a Dell XPS M1210 laptop for which I have just purchased a new 9-cell compatible battery. It worked great for a couple of hours, but now shuts off immediately when unplugged from the AC power supply....
You might want to try what I did when I had a completely discharged battery for my Dell Laptop. I attached the battery to the computer, make sure the computer is off and plug in the charger for a full twenty four hours (undisturbed). And this really worked. I had no problems with the battery. Good luck.
Feb 26, 2010 | Dell XPS M1210 Notebook
Battery fully charged but still shutting down when disconnected from mains
Find another battery it says like the one you have is faulty. If you try another known good battery and that fails just like yours then try a know good ac adaptor. If that fails, then its a problem with the motherboard not charging batteries properly but it really does sound like a faulty battery from my experience.
May 08, 2009 | Acer Aspire One PC Notebook
Laptop Charge troubleshoot
This can be due to a dead cell in the battery pack,Could also be the charger is going bad or shutting off prematurely.
Please rate this a fixya
Feb 13, 2009 | Sony VAIO VGN-FJ270/B Notebook
Laptop power connection faulty
Hallow Dear,
As your explanation about Battery issue simply I’m advising you to replace your battery with original one.
But before that there is one thing that you can try it out.
---Use your laptop until battery goes down & shutdown automatically then remove the battery and try to discharge it completely with small bulb manually
When it’s on completely discharge (0 Volt) keep it on Outdoor Sunlight about 12 hours.
After that connect it to your laptop & recharge it completely (until Computer LEDs showing you as Fully Charged)
****** REMEMBER DO NOT TURN ON YOUR LAPTOP******
Until its Showing you as fully charged
That will be nice if you can check Battery Voltage & Amperage manually as it is charged fully before turn on your laptop. (if not you can give more charging time accordingly)
This will not solve your any component (thermal fuse, vRegulate) problems inside your battery but will increase your battery Cells Life and most vStoraging problems on Cells inside your battery
Thank you & Best Regards
Dinu….
Dec 20, 2008 | HP Pavilion dv6000z Notebook
Toshiba a75-s125
It sounds like your battery is out of time. Buy a new one.
Nov 21, 2008 | Toshiba A75-S125 Satellite Notebook
Battery maintenance
you should charge fully then remove power once it is charged.
use it with battery till battery is discharged.
leaving it plugged in all the time will kill the battery.
thanks for rating.
Jan 15, 2008 | HP Compaq Presario V2000 Notebook
False battery power alarm shut down
Ive had a look at the manufacturer web site but ther doesn't seem to be any driver for your model. You should be able to turn the battery warning alarm off in the management settings
Feb 03, 2007 | Balance CN6555 Notebook
Battery Technology LENOVOIBM NonOEM Laptop Battery for 41U3198 42T4549 42T4548 42T4653 42T5262 42T4264 42T5265 Logo
236 people viewed this question
Top Battery Technology Computers & Internet Experts
Computer Links
Terry Schallert
Are you a Battery Technology Computer and Internet Expert? Answer questions, earn points and help others
