Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
I have a 5.5 OHV Briggs and Stratton and it only runs if it is choked or half choked. When the choke is open (run position) the motor kills. There is only one adjustment screw, but making adjustments to that does not seem to make any difference. What's wrong!
  • Briggs & Str... Master
  • 7,482 Answers
Check your fuel filter if you have one.
If the mower/weedeater is over a year old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Sounds like you will need to clean the carburetor or replace your carburetor internal rubber parts like the diaphgram and O rings.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor or using starting fluid and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor or follow the instrucitons you get with the carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
Posted on Apr 07, 2011
I have a 5.5 OHV Briggs & Stratton and it only runs good when it almost fully choked or half choked. There is one adjustment screw on the carb., but when I adjust it , it does not seem to run any...
The carburetor needs to be cleaned. There is something in one of the passages that is keeping it from running correctly. To do this you will need a can of carburetor cleaner (spray) and a very thin wire to probe in all of the holes of the carburetor. First, take the carburetor loose from where it mounts to the engine. Then take the wire and probe all of the holes in the carburetor, and also the holes in the fuel bowl nut (if any are present). Then shoot the carburetor cleaner through the holes to remove any loose particles of dirt or debris and to make sure the passages are clear. After you have done this, then you will need to blow through the holes to make absolutely sure that everything is removed that could be blocking either fuel or air from passing through the carburetor. Re-install the carburetor back onto the engine, and check to see if the unit is running ok. If at this point the carburetor is still not running correctly, you may have to replace the carburetor. When you go to the parts counter you should have the MODEL, TYPE, and CODE off of the flywheel housing. These numbers are stamped into the metal. I hope this helps you out.
Apr 06, 2011 | Briggs & Stratton Briggs Stratton...
I have a Intek Twin 24 ohv engine. It will only run smooth if the choke is half open. If the choke if fully opened, the engine is unsmooth and revs high to low by itself. I tried cleaning the carb but...
I had problems with my 20hp v twin.The fuel was the problem.I stopped using fuel with ethanol.Problem solved.My 60 hp Evinrude had the same problem.Ethanol was responsible for eating away gaskets and o-rings.This stuff also eats away at some aluminum carbs.Thanks congress for voting to add this **** to our fuel.Wish you would pick up the repair bills too.
Nov 13, 2010 | Briggs & Stratton Briggs Stratton Intek V...
3.5 Briggs with not run at full throttle
same problem, was told it was the jets, are your symptoms as follows
runs at low throttle, will only run at full throttle if fully choked
dies if choke is relieved
Apr 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Motor will run fine with the choke on , but push
The governor is out of adjustment. It will be located on the side of the engine with a rod pointing downward with a weight
Apr 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Motor won't run unless choke is on. It is a 16 hp v twin.
check breather to make sure it is clean and clean the carburator
Apr 07, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Lawm mower engine will only run on choke
the carb is gummed up with laquer. take it of the motor and soak it in some solvent for an hour. but first take off the float cover before emersion.
Nov 12, 2009 | Briggs & Stratton Briggs Stratton Intek V...
21hp intek v-twin runs only with choke on full
You are not getting enough fuel.... by choking it you are enriching the mixture with less air , more fuel.Some where in the fuel system or carbureator something is still plugged.Or the mixture screw is too far in.
Oct 30, 2009 | Briggs & Stratton Briggs Stratton Intek V...
I have the exact same problem on my 7hp briggs for a genny
Your carburetor is dirty. Need to be take apart and cleaned with carburetor cleaner.
Oct 06, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
272 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
