Question about Garmin Approach G5 Handheld GPS Receiver
I put new batteries in , pushed on button, Garmin screen comes on and that's it and then can't turn off. Need to pull the batteries to turn off. Any suggestions. This is on a Approach G5
  • 464 Answers
This sounds like a firmware issue try downloading Garmins WebUpdater Software and giving the unit a firmware update. If your are unable to connect the GPS to the PC you will have to send it in for warranty or repair. Here is a link to the Garmin Software you will require for the updates.
Hope this helps!
Posted on Apr 13, 2011
Garmin echomap 50 keeps cutting in and out
Loose or corroded wiring and or connections.
Jul 25, 2013 | Garmin echoMAP 50s with Transducer
On My garmin gps 72H none of the buttons will work. EG I cannot change pages or turn off. Was working fine then changed batteries and this occured. Any suggestions??
I would read the owner manual first and then remove the batteries for a while and put back. This does not use recharge able batteries?
Nov 03, 2012 | Garmin GPS 72 GPS Receiver
Just got new battery put in because of recall only used one time. Turned on garmin and garmin screen came on and is stuck on this screen. Does not turn off or on What's up?
Your device freezed that is why it is stuck on the garmin screen. You need to first reset your garmin by holding the power on/off button for about 15 seconds, that way it will restart.
About the battery, when you get a new battery for your device, you need to charge it for about 3 hours before powering on, once you power on without charging it first, then it might kill the cells of the battery as they are lithium ion battery. What you have to do is to remove the battery, insert it back, then you plug it to a power source for about 3 hours, be sure that the battery is charging as the green light comes on as you plug it. If the green light does not come on, then you need to connect it to a computer using your USB cable, that way it will charge. Once it is charged for about 3hours, then you will be able to turn on your device. First reset, then charge battery. That should do the job for you.
Hope this information was helpful.
Dec 31, 2010 | Garmin Nuvi 770 Car GPS Receiver
Wrong language on garmin oregon 400t
I called Garmin for this very same reason. The answer is; while your GPS is off place your index finger in the upper left of the screen, turn on the GPS, a screen will come up and ask if you want to clear the GPS (or something to that effect), say yes. (Yes is the top button) Then you can choose english. YAY!
Rin
May 03, 2009 | Garmin StreetPilot 2720 GPS Receiver
Black Screen to no power
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Gps will does not work
Feb 22, 2009 | Garmin StreetPilot C330 GPS Receiver
C330 wont turn on or power up
It took a nap...
Jan 22, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin c550 GPS-Won't turn on at all.
push and Hold the power button down while you push reset, keep power button pressed til it boots again. If it does not, and it's in warranty ship it to garmin. If it's out of warranty, have someone open it up and remove the battery for a couple of minutes.
Jun 29, 2008 | Garmin nuvi 350 GPS Receiver
could the battery be dead? Leave it to charge on the wall charger for several hours. Then try again. There is a way to do a hard reset....
Jun 08, 2008 | Garmin nuvi 350 GPS Receiver
Garmin auto gps c330 freezes
"Black Screen"
It took a nap...
Oct 14, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin Approach G5 Handheld GPS Receiver Logo
234 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
