The left output plug produces a lower volume than the right plug. The speakers are working fine. What do I need to do to fix this?
  • 76 Answers
Check if the pannings in the amplifier is set to center. check speaker wirings for any cuts. Perhabs new wires may do the job
Posted on Apr 06, 2011
Where do I pug the speakers in ? I need a Picture,Show me the picture.
    • 1 Remove the Dell A215 speakers from the box. Place the speakers in your computer area. The speaker with the volume knob is the right speaker and should sit to the right of your keyboard. Place the other speaker to the left of your keyboard.
    • 2 Plug the left speaker into the right speaker. The left unit has an orange-brown plug that connects to a similarly colored port on the back of the right unit. The other end of the cord is fixed to the rear of the left speaker.
    • 3 Insert the two-prong end of the power adapter into an electrical outlet. Plug the other end into the black power port on the back of the right speaker.
    • 4 Insert the main audio cable into your computer. This cable is fixed to the back of the right speaker and has a green head. Plug the green connector to the green audio-out port on your computer. This port may be on the front or back of desktops or on either side of a laptop.
    • 5 Turn the knob on the right speaker clockwise to turn the speakers on and increase the volume. Turn it counterclockwise to lower the volume partially or all the way to turn the speakers off. The speakers should work automatically on any computer with a sound card.
Let me know if this solved the problem and good luck..
Sep 09, 2011 | Dell A215 Computer Speakers
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
Left speaker is not working on my 2.1 speaker system...
A few things can cause this to happen. First we should check the computer. Take a pair of headphones or other speak set and check if sound comes from both sides. If to then the computer output is correct, else the computer is channeled to output to one side.
To change sound settings, if this is windows, go to your control panel and look for sounds option. In there you can change speaker settings, change volumes. On the volume control you can balance the speaker output. center the slider to make both correct.
If sound is coming from the PC correctly with a test object you will need to check your speakers for a fade option, not many have this it is just a suggestion. If no fade option exists, make sure the plug is totally seated. Improperly seated plugs will cause only 1 channel to be outputted or none.
If all the above does not help then check the cabled leading form the computer to speakers for damage as well as checking the wire between the left and right speakers for damage. Many times the output lead from the right to he left gets damaged from stress or other things and will stop output. Wiggle and pull the wire gently in each direction if they don't physically look damaged to see if sound is produced. if it is then the wire is internally damaged or loose from the speaker.
good luck
Mar 14, 2010 | Altec Lansing Audio Players & Recorders
I have a Denon AVR587 running in 7.1. I have an unusual problem as the rear channels seem to play all sounds at a higher pitch and lower volume than all the other speakers on the system. I am using a voice...
Hey ajn1n1 we need to fine where the tinnyness is coming from Lets do a test shall we,
hook up your voice matched polks to your front left and right speaker outputs on your amp to see how they sound as mains. if you hear tinny then its the speakers. sometimes speaker need to be broken in a bit.
hook up your main front left and right speakers to your rear outputs. if you hear the tinnyness then its the output of that channel on the amp or a setting. Newer amps let you change speaker sizes in the menu so that it can change over the crossover for that channel.
Dec 11, 2009 | Denon AVR-587
My new Acer Aspire one D 250 laptop has a very low volume output . All the volume controls are up including wave output but with no success
Right click on the speaker icon in the task bar, lower right hand corner of the screen.
Select "Adjust Audio Properties."
In the popup box, go down to "Speaker Volume." Click "Advanced"
In the new pop-up, make sure that "Laptop speakers" is selected. Click all the OKs you need to in order to establish that setting and clear out of "Adjust audio properties."
Now you SHOULD have much better sound from your speakers.
For some reason, my D250 keeps defaulting to "Stereo headset" which produces much lower volume sounds when a headset is not inserted. So low that you can't watch and hear a video through the speakers and understand what is being said. Once you switch to "laptop speakers" you'll be able to hear stuff. It won't be high volume, these things just don't put out high volume, but it will be reasonably audible, if this was the problem.
Nov 25, 2009 | Acer Computers & Internet
Quiet front R channel on Sony
Does problem persist when you connect other speaker to front right channel? (i.e. when you connect your FL speaker to FR and vice versa)?
Jul 15, 2009 | Audio Players & Recorders
No sound out of left speaker
did the left channel work when u switched speakers, if so then the left speaker or wiring is a fault.if not then the output circuits on the amp are blown or the fuse is blown some amps have internal fuses in the output to protect the output transistors. unplug the power cord and take the cover off, look to see if u can find any fuses and check these for continuity u can hold these up to the light and u should see a fine filiment in one piece and not broken. these fuses sometimes blow just from age and use at high volume like a regular light bulb.If the fuse is blown replace with the same value else the output transistors will need to be replaced most likley along with the drivers.
May 19, 2009 | Sony STR-DE135 Receiver
Hitachi SR-2000 receiver's right speaker connection does not work
The SR-2000 has fuses for both left and right outputs. Make sure neither are blown. Otherwise this receiver has a STK 463 integrated chip that controls the output for both channels. When replacing the STK-463 it is also acceptable to use STK-465.
Jan 10, 2009 | KLH R3100 Receiver
Volume out of speakers nill
I bought two of these in "non working" condidition. All it was is this: There are two plug-in's or shunt's whatever you wanna call them that come pre-installed on my units that were up/down and should have been horizontal in block marked "speaker output".
Both unit's work fine now. Came from factory that way!
Try it and let me know at kyhillbilly@bellsouth.net
Someone
Aug 22, 2008 | KLH KL2400 Tuner
Speaker Problems
Can you swap speakers and see if the left working speaker works when plugged into the right output?
If it does, then your right speaker is bad or the right speaker cable/plug may be bad.
If the working left speaker doesn't work on the right output, then I would suspect a problem in the right channel audio amplifier.
Please let me know if I can be of further assistance to you.
- Jim
Feb 29, 2008 | Emerson MS3100 3-Disc CD Changer
23 people viewed this question
 Grubhead
Grubhead
