Question about Kensington Computers & Internet
What is the best way to remove a kensington lock anchor point from a laptop if the allen key supplied will not unscrew the device.
4 Suggested Answers
yooperbud
  • 8637 Answers
SOURCE: Kensington key board
Normal 0 Assuming that you have good batteries installed, turn the Keyboard over and locate the small reset/connect button on the back of the keyboard and press it. Then try to see if it is working. If not try pressing the button on the receiver and then on the keyboard. Try typing, should work okay.
Hope this helps. Bud
Posted on Jan 19, 2009
  • 3 Answers
SOURCE: What is the best way to remove stuck toilet anchors
try rotating the entire toilet counter clockwise so the bolts are in the insert slot of the toilet flange and rotate the nut and the bolt head should line up and pop free of flange.
Posted on Oct 31, 2009
  • 54 Answers
SOURCE: How to unscrew the cap on a Blanco single faucet with sprayer
allen key is usually 1/8 inch
Posted on Apr 13, 2010
I need to remove this lockwood lock from my front door as it has stopped working but can't work out how to remove it
if its still locked and not working , then your in for a real chore !! as these are designed to not be able to just unscrew if there locked up , if its not locked , open door and unscrew frame part from frame (screws held it on frame) then look at bottom of key lock section , see small set screw (use allen key on this ) remove this screw , then using a small pipe wrench (you didn't want to keep it right ?) unscrew the lock section lefty loosey and then with a slight pry with small screwdriver entire front cover will pop off , this exposes the screws into the door , remove them an lock will come off door (leaves big holes in door thought)
May 13, 2016 | Cars & Trucks
How to change a front seat belt anchor
You give no make or model of car. Usuallly you have to remove the seat. You will need a trox rachet to loosen the anchor from the vehicles side. You must torque the anchor when you repace it. What happend to the old one.>?
Dec 28, 2014 | Seat Cars & Trucks
How do I reattach handle on freezer door pull that has come unscrewed on French Samsung refrig
Many times the handle is slid on from one side or the other onto the screws. Try sliding the handle off by gently putting a screwdriver or putty knofe under the handle on the side that is still attached and pushing the handle sideways. This should remove the handle so you can remove the mounting screw and get it back on the door. then you can slide the door handle back on after getting the screw attached on the door again.
Oct 04, 2014 | Samsung RF265AA Bottom Freezer French Door...
How to remove the chuck from a mastercraft 12 v drill
You have to remove a screw, anchor the handle down, and then unscrew the chuck itself. You do this with a vise, and a big allen wrench for leverage.
First, the rReverse threaded screw inside the chuck itself. Open the chuck all the way and you should see it down at the bottom of the whole. It'll have threadlocker on it probably, so it might be a little tight, but you need to remove that screw.
After that, switch the drive to low gear (not high speed) and put the handle of the drill tightly into a bench vise. Careful not to crush the handle. Get the biggest allen wrench (key) that you can find that will fit into the chuck, and tighten the chuck around the wrench. Once that's in, take a hammer and smack the end of the wrench - that will unstick the chuck and get it turning (you'll want to do this so that when you hit the wrench, the chuck turns counterclockwise). Spin the chuck the rest of the way by hand and it will come out.
Jun 25, 2014 | Computers & Internet
Insersion ball coupling lock
when you insert the unit into the coupling ,the allen key will be fitted in a hole to enlarge the ball so that it cannot be pulled out . At this point you will remove the allen key and lock it with the keys
Mar 07, 2014 | Cars & Trucks
How to reattach brake cables on my mountain bike
Hi chermy637
You need to unscrew and loosen the brake pads with an Allen Key until you have enough slack in the cables to reach tboth he pads and brake levers easily. Clutch one brake lever (as you do when braking) to maximum, hook the grommet at the end of the cable into the hole slightly larger than the grommet, then slide it back along the groove leading from the hole so the cable is anchored in the pivot end of the lever, carefully threading it through to the static rest that the lever rests against when released.
Extend the cable, now anchored at the brake lever at the end, down towards the brake pad on the same side of the bike. Feed the grommet of the brake pad end of the cable through the hole in the retaining arm holding the brake pad.
Holding the grommet to stop it springing back through the hole with your subordinate hand, use your principal hand to take the Allen Key and tighten the retaining arm of the brake pad adjusting the orientation of the brake pad and the rim of the wheel as you go along. Just before the gripping point, pull the cable down to take up any slack, pulling any extra length down through the hole with your subordinate hand as you tighten with the Allen Key.
When the cable is held fast at the brake pad end and the brake pads are well aligned with the wheel rim, test for the correct tension on the brake lever and adjust the tension of the cable accordingly.
Repeat the process on the other side of the bike.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it.
This helps Answerers, like me, better understand the needs and the point of view of Askers, like you, and guides us in exploring the best ways to provide the most comprehensive, useful and high quality Responses and Solutions we can.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Thanks for using FixYa.
Sep 07, 2011 | Cycling
How do I remove the chuck from a dewalt drill model dw100
Easy,
I just had the same question and could not find any info except sent it to Dewalt or pay for a $70 tool???
A normal chuck you would unscrew the left handed lock screw down the end of the chuck. The DW100 doesnt have one.
Wrap a cloth around it and tighten in vise. Chuck a big allen key in it...5/8 or so...tighten that down. It should spin freely in the drill which is locked in the vise. move the allen to 3 or 9 o clock position...ie horizontal. get your fingers out of the way. Hit the allen with a hammer...hard...in a direction that is "lefty loosey"...you may have to do it a couple of times but eventually the threads will break loose and the chuck will unscrew. CHuck is held on by friction only. Replace the chuck in the same but opposite manner. Hitting the allen so that it tightens things up.
The key is that the gearbox provides enough backward resistance when the allen is hit firmly to allow the chuck to unscrew itself...
...easy
Nov 19, 2010 | Garden
I need to change the chuck assembly. i have removed the screw from the center,but i am not able to remove the chuck. any suggestions on removing it without damaging the drill will be greatly appreciated.
Get a large 90-degree allen wrench. It's best to use the largest allen key the drill can accommodate, at least 3/8" to 1/2". Put the short end of the allen key in the chuck and, with the long end of the allen key pointing straight up, completely tighten the chuck.
Firmly holding the drill on the edge of a table, you're going to have to hit that allen wrench with a hammer, hard. Use the flat side of a hammer to hit the allen wrench so that the blow will spin the chuck counter-clockwise. Sometimes it can take a real hard swing, so swinging through smoothly helps.
Sep 02, 2010 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How does the holder detach? Allen wrench,star, push with a screw driver?What do you use to remove the holder from the wall?
there is no set screw or allen key for this. It is mounted in the anchor bolt by use of a mounting screen, pressed in until it clicks and difficult to remove
Nov 19, 2009 | Moen YB2808 Eva Paper Holder - Chrome
How do I remove a keyless chuck from my Sears drill.
The chuck is screwed on with a normal thread, the screw in the centre (already removed) is left hand thread. Holding the drill with the open end of the chuck facing you, it should unscrew anti clockwise. It might take an impact to start it off. I normally put the gearbox to slow, set the cluth to drill and then holding the drill firmly, hit the allen key against the edge of my workbench. Bring the drill down like a hammer blow so the allen key hits the bench (which should be on your left). I find this more effective than holding the drill on the bench and hititng the allen key with a hammer as it allows for less drill movement at the point of impact.
Nov 14, 2008 | Drills
Computers & Internet Logo
Top Kensington Computers & Internet Experts
dctocali
Level 1 Expert
rey francis basa
rey francis basa
Are you a Kensington Computer and Internet Expert? Answer questions, earn points and help others
