Question about Zyxel P660HWD1 v2 WirelessADSL2+ Gateway Router
Internet light keeps flashing and I lose internet connection every 9 - 10 minutes
    Scholar:
  • 50 Answers
Hi and welcome to fixya.
This kind of problem can be either an ISP problem (which cannot be fixed from here) or a router problem.
If it is the latter, the following can cause such a problem:
  1. If you are trying to connect via wireless, make sure that there is nothing blocking the wireless signal from the computer to the access point/router and that they are close enough to one another.
  2. Try to reset the router to default factory settings or upgrade its firmware to start from the beginning its setup. Latest firmware can be found here and general setup/reset instructions here. If this was caused AFTER you reset or upgraded the firmware of the router, this indicates that you missed all the previous settings (if something was needed specifically for internet to work).
  3. Try to connect via ethernet cable only or wireless only if the problem is in either just to see the difference in connectivity issues in each case.
  4. Try to use the following commands (cmd prompt for XP/Vista/Win7) to get and check the network settings that the computer gets every time you connect.
ipconfig /all (this shows general connectivity info,if you see a computer's IP address of 69.*.*.* then the problem is with your ISP's modem which probably needs re-setting).
ipconfig /release (this releases all ethernet or wireless from any IPs that the router provides. Equals to 0.0.0.0. - use ipconfig /all to review the change after the command finishes).
ipconfig /renew (this renews all ethernet or wireless IPs from the router. Again if you get any addresses starting with 69.*.*.* the problem is with your ISP).
Please let me know if this troubleshooting helped you at all.
**Don't forget to rate this solution**
Thanks.
Regards from FixYa.
Posted on Apr 06, 2011
Testimonial: "Very helpful ,not perfect but much improved"
Lose internet connection timing out
It may be your ISP. Verizon keeps losing my connection frequently
Sep 23, 2012 | Linksys Wag120n
I lose connection even when hardwired
might need a firmware update check website for recent and compare to firmware on your modem
May 29, 2012 | Motorola Computers & Internet
Netgear wpn824 v2 loses connection The internet light blinks amber every few minutes and I lose connection to the internet.
if you're online and loses connection every couple of minutes,that most likely be and issue with you ISP. it's intermittent connection issue with the server or might be the modem if it's more than a year.. better is to contact your ISP to check on their end,also to create a work order to investigate and monitor the issue.
Oct 07, 2011 | NetGear RangeMax WPN824 Wireless Router...
My modem ADSL data light keeps flashing and sometimes does not appear affecting my ability to acces the Internet. I usually have to re-boot my computer and this seems to solve the problem for a time. It is...
I usually have to re-boot my computer and this seems to solve the problem for a time. It is very inconsistant and anoying.Thank youM. Davis
ADSL DATA light flashes says there is internet activity (Internet status: Connected)...
ADSL DATA when off says there is no internet activity (Internet status: Not Connected)...
This occurs when there is a lot of noise in your telephone line...
It is adviced to do a line test in this case to find the amount of noise in your line...
If there is a lot of noise your modem will lose the internet connectivity and will try to re-establish the connection with ISP...
In this case the ADSL DATA light switches between OFF and ON...
One more thing...
ADSL SYNC light should be steady...
If it is blinking is says there is no syncronisation between your modem and ISP...
Dec 08, 2010 | Belkin Computers & Internet
I keep losing internet connection every few minutes. the light will turn red and then reboot itself. i tried all of the different channels and it does not help. what is wrong
If the light turns red then it says, there is a lot of noise on your telephone (dsl) line..
If there is a lot of noise, then the dsl will lose the connection and it will try to establish a connection again...
at this point you will lose your internet connectivity...
So i advice you to contact your ISP and ask them to change the telephone line from the junction box...
or ask them to check the amount of Noise in your DSL line...
Signal to Noise ratio (SNR) value on your DSL modem should be more than 40db for greater connectivity...
If it goes below 30db, you will face frequent disconnection and very slow internet...
Nov 26, 2010 | 2wire (1000-000057-000) Modem
N1 Vision keeps losing internet connection from modem.
Hi Friend,
Please check it by updating the Firmware for your router from the below website
www.belkin.com/support
Regards,
Aysaam
Apr 13, 2010 | Belkin N1 Vision Router
I keep getting kick out of the connection every 5
An Unsecured network is open for anyone to freely use with open security to your computer too,
Not good at all.............
reset your router
should be a reset button on the back,
hold in till the lights on the front flash then its reset open explorer browser
type in 10.1.1.1
log in as Administrator
add new user
set password while adding new user
save your new settings(write them down too)
test the internet for function
if no function then contact your ISP to assist with connection to internet
all sorted now please rate me MISTERDJ
Apr 11, 2010 | Computers & Internet
My modem keeps losing internet connection
Update your drivers and then do a speed test. Most isp send updates to the subscribers when they update, yours may not. Don't forget to check all of your connections before wasting time calling your isp. I trust this test the most. Rember you don't always get what you pay for.
http://www.speedtest.net/
Aug 17, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
Motorola SB5120 works fine just loses connection suddenly?
Could just be a lemon. Try a different modem in you can.
Sep 23, 2017 | Arris SURFboard SB5120 Modem
PS3 keeps losing internet connection
Have your ISP check the refresh on there end (Suddenlink had mine set a 4 minutes instead of 24 hours)
Feb 05, 2009 | Sony Playstation 3 (PS3) Console
Zyxel P660HWD1 v2 WirelessADSL2+ Gateway Router Logo
638 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
