Question about HP Photosmart C4180 All-In-One InkJet Printer
Problem withColour Cartridge 854 for HP Photomart c4188
My printer had a defect developed after clearing papper jam, it says check colour crtridge, which i find no damage. it was working till recently. refilled cartridge twice worked smoothly.
printer does not go beyond display.
if i check cartride, then it momentarily goes to alignment and suddenly shifts to check colour cartridige.
What could be wrong
NSGPrasa
  • nsgprasad Aug 06, 2008
    I have tried several times to reinstall the cartride. but not worked
    nsgprasad
  • 446 Answers
It could be the cartridge wasnt properly in place.
turn off unit and manually remove the cartridge again ensure that you install correctly.
Posted on Aug 06, 2008
When printing paper jam
hi,your question is not compleat but papper jam is mainly complaint for you check the cartridge &fuser unit &papper pikup unit
Apr 06, 2014 | Samsung ML 1710 Laser Printer
Papper got stuck . spongy peace 9"x1/2" came out ,
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Nov 04, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Printer papper jam cant see any papper mfc-240c
Did you remove the rear cover and check for paper there? If it still shows a jam and there's absolutely no paper inside the printer, you may have to shut it off (or unplug it if it won't turn off), wait a few seconds, and turn it back on to clear the jam detection.
Sep 05, 2009 | Brother MFC 240C All-In-One InkJet Printer
Have just replaced the colour ink but getting message to replace. It doesn't recognise there is one in.
If you used a generic brand cartridge, you might try an original HP replacement. I have had many HP printers for service that don't work well with the remanufactured cartridges.
If the new cartridge is an HP, try exchanging it as defective where you purchased it. You probably got a defective cartridge. (Hey, it happens occasionally!)
Apr 27, 2009 | HP Officejet 5610 All-In-One InkJet...
Hi i hace HP Photosmart C4188 All-in-One Printer and since last few days i am facing a problem "Remove and check crtridge on right"
the right side cartridge is gone faulty and needs replacement so this error message.just follow the message and replace the cartridge.also try cleaning the cartridge before replacing them sometimes the cleaning helps.
Dec 15, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Unable to print anything because of continual paper jams. I can clear them with difficulty, from the rear of the printer. This first happened after I printed a colour picture and immediately tried to...
Papper Jams = Old Paper Feeder Rollers
1. Buy new printer.
or
2. Replace Paper Feeder Rollers.
Thank you for choosing FixYa!
Azkeyz. Wizard Division.
Sep 23, 2008 | HP Office Equipment & Supplies
PAPER JAM WONT RESET EVEN AFTER PAPPER WAS REMOVED ON A DELL 924
On the paper jam ,I tried to pull the ink cartridge over to center. It came over a little & then it jammed up.I noticed the ink cartridge lock tab had popped up & jammed it to the right , once I got the tab back in place the code cleared & it works good now.
Aug 24, 2008 | Dell 924 All-in-One InkJet Printer
Hp 5610 all in one printer.
5610 will not download, says no connection to computer.
Dec 17, 2007 | HP Officejet 5610 All-In-One InkJet...
HP Photosmart C4180 All-In-One InkJet Printer Logo
175 people viewed this question
Ben Johnson
