Question about Sharp Aquos LC37D44U 37 in. LCD HDTV
Sharp Model LC-37BD60U : There was a thunderstorm in the area. The Direct TV receiver is O.K. but the TV will not turn on. I have 120 VAC at the 2 pin plug where it plugs into the television. I have tried disconnecting and connecting the power cord several times. Is the set fused internally?, if so where is it located and what type (3AG, etc.). Thank you in advance
  • 325 Answers
The fuse is internal nearest the point of where the 120VAC contacts the power supply. The fuse will be brand specific BUT will be a slow-blow ceramic (white). Replace with only the exact same rating of fuse to avoid fires within the tv.
Hope this helps and please rate!
Posted on Apr 06, 2011
    Scholar:
  • 91 Answers
Most likely the Internal Fuse has blown
You can buy replacement for very cheap
The Fuse will be located on the power supply board
You will need to remove the back panel of TV to get to the power supply board
Usually it will be a t4 250V in UK
You will have to take the fuse out and look at it as all TV's are different
If you dont have a multi meter to test the fuse you can turn up your stereo loud and touch one end of the fuse to the 3.5mm audio Line out and the other end to your finger, if the stereo buzzes it means the fuse still works
Goodluck
  • Andrew P.
    Andrew P. Apr 06, 2011
    FYI, DO NOT try this idea about touching the fuze. Just get a $10 multimeter, which you already have. An experienced person COULD do this, but I recommend to just use your meter you read the 120VAC with.
TV only detecting channels 2-13 should be detecting 2-63
Go back to the initial set up procedure for your Sharp TV and do a search for active HD channels. They will be decimal numbers such as 13.1.
Jan 13, 2014 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No power due to thunderstorm, it's off but connected to the power source..
It can be affected due to current surge on the line, the most probable affected area is the power section of your TV. Some incidence are only fuse blown out where you can replace the fuse with a new one just be sure that the rating is the same. But others are major components like MOSFET, Thyristor, Varistor which are usually sensitive on current surge.
May 27, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I have the same problem. I recently purchased a Sharp LC-52D78UN TV and I am receiving nothing but Black & White pictures when connected to Direct TV cable receiver. Why and how can it be fixed. I...
I suggest you check the cable input system. It is possible that the cable unit produces S Video or B-G and the TV is set up to receive standard quality RGB.
Hope this helps
Nov 21, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
When I turn on my TV sharp model LC-32D44U turn on a 2 second on analog canal 2 than turn off and start a green led flashing ..
common problem for this particular model, one or more CCFL (backlight lams) falure. Lamps are not avalable as the replacement parts, only way to get them is to take appart bad/broken screen tv.
Oct 12, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
I'm looking for the remote code for this tv so I can program it into my sattelite receiver.
If you are using Direct TV, the codes are available at the direct tv website....
Directtv has a link on the TV using the menu for programming the remote control.
And if not directv, look up the model of your current remote, and see what the code for Sharp is ..
good luck and don't forget to vote!!!
Oct 11, 2010 | Sharp LC-32DA5U 32 in. HDTV-Ready LCD...
Sharp Aquos LC 32G4U not receiving any channels-
Most locations are real hard to get local stations using indoor antennas. If you are in a location where you do not have cable, I would try either a outside antenna on the roof or go with Direct TV Dish / Dish Network system.
I hope this helps,
Skyassoc
Jan 04, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp LC-32SB24U TV. Remote no longer functions.
Unplu the TV from the wall, wait for 30 sec. plug it back in.
Nov 07, 2009 | Sharp 32C-240 32" TV
I need to receive a manual on the operation of my sharp tv
I believe your TV is a LC-32SB24U, not LC-325B24U.
You can download a manual at www.sharp.ca/manuals
Feb 21, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Auto Tuning Channels on LC20B2MA Aquos TV
 Automatically tunes in and preset
receivable TV stations.
Make sure the antenna cable is
properly connected.
1 Press MENU (PRESET-1) on the
upper part of the LCD TV set for
more than two seconds. The
AUTO mode screen appears.
2 Press VOL (–)/(+) (PRESET-2)
on the upper part of the LCD TV
set.
All the TV stations in your area
that can be received by the LCD
TV set are automatically preset.
3 The screen shows whatever is on
channel 1 when full auto channel
preset is finished.
Aug 07, 2008 | Sharp Aquos LC-20B2U 20 in. LCD Television
Sharp Aquos LC37D44U 37 in. LCD HDTV Logo
513 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
