Question about HP Compaq Presario SR1720NX (EL435AA) PC Desktop
My Presario SR1720NX has a blinking green light on the back near the power supply when plugged in but no power. Already replaced power supply - is my system board a goner?
    President:
  • 749 Answers
Would check the switch at the front of the pc.Have had several issues with that particular switch getting pushed out on compaqs just enough to allow them not to turn on.Would also verify that all powers supply plugs are pushed in all the way.
Posted on Apr 06, 2011
Green light flashing but computer is dead. what to do?
The green light on the motherboard? Your Computer has a few miles on it. It may be the PSU needs replacing. Also replace the CMOS battery and reseat/replace the Memory Mods, if you haven't already. If you unplug and plug in does the computer try to start? Fans spin? LED's blink? Anything? If it starts and shuts down in a few seconds that would, most likely, be a Power Supply issue. Their is a chance, of course, that it's just done.
Mar 19, 2013 | HP Compaq Presario SR2150NX PC Desktop
I have a Compaq Presario SR2010NX that will not boot. When I plug in the power cable, a green light blinks at the back of the tower on the power supply. I was given the desktop in mint condition, which...
your power supply is bad. the blinking light means there is a failed component in the power supply. replace the power supply and you will be good to go. around 60 dollars at any computer place. please rate me thank you.
Jan 04, 2011 | HP Compaq Presario SR2010NX PC Desktop
My Presario 8000T power on then off
Hi there. Seems you already have a clue on what you are doing (good job). Try to test the system with another RAM stick. It may be a bad RAM, bad CPU or most likely, bad motherboard. But, before you change the motherboard itself, do the RAM test. It is the best shot. There is a device that you plug to the PCI port of *********** board but by the time you pay for it you are better off testing the RAM first. Good luck (please, if this helped, leave a comment).
Jan 07, 2010 | Compaq Computers & Internet
Green light flashing on back of unit near power cord also green light flashing on motherboard near power supply plug in.
I would suggest trying to replace the power supply. If that does not fix the issue, i would need to hear more about the computer.
May 06, 2009 | Sony VAIO VGC-RB40 PC Desktop
Blinking green light front and back. Clicking sound from inside.
Do you mean the little green LED light near where you plug the power cable into the back of the computer? If that's the blinking light then unfortunately, this means that power is getting to the power supply but it is not going from the Power Supply to the Motherboard/Devices. The power supply is broken and is not converting the power from the wall to the proper voltage for the Motherboard/Devices. You will have to replace the power supply.
Call HP, and I hope you are in warranty and get it replaced for free or you can order the exact same one from HP that originally comes with that model. 1-800-HP-INVENT for their tech support line.
May 05, 2009 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
Will not pwer up. Greenlight blinking on back
The green blinking light can mean there is a problem with the power supply.
Try unplugging the computer from the wall, and turning on the pc on switch.
After a few minutes, try plugging it back in.
If that does not start things up, you may have a bad power supply.
If the power supply is bad, these models take standard power supplies. You should get an ATX 350Watt or higher power supply.
They are easy to replace, unplug the power from the wall, disconnect all the cables inside the computer. Unscrew the four phillips screws outside the back of the computer where the power supply is attached to the case.
Remove and replace.
If you don't feel comfortable with this, a good local computer shop can help you out.
Apr 13, 2009 | HP Compaq Presario SR1330NX (PP161AA) PC...
Pc will not power up. Green light on power switch blinking like a slow stobe light. I tried un plugging it, did not work. I tried swicthing it to 240v, then back to 120v did not work. I tried an alternate...
The power supply is shot. Best suggestion is to replace it. You need to make sure it is replaced with the same model power supply. Check online for a replacement unit.
Mar 10, 2009 | HP Compaq Presario SR1110NX PC Desktop
I have a Compaq SR 1000 desktop set and I can't get the power to go on. When I plug the unit in a green light in the back keeps blinking. When I disconnect, hold in the power button the blinking stops, but...
Hello shapscomp
The blinking green light is likely your Ethernet card's LED. Is the blinking light located near your Ethernet (network) cable?
It sounds as though your power supply has failed. You may be able to purchase a replacement power supply for it.
Would you like some assistance in deterimining if that is the case?
Thank you
BJ
Apr 05, 2008 | Computers & Internet
Open Questions:
HP Compaq Presario SR1720NX (EL435AA) PC Desktop Logo
270 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
