Question about Skull Candy Lowrider Headphones
The wire is disconnected - Skull Candy Lowrider Headphones
  • Skull Candy Master
  • 5,309 Answers
If you click my user name you will find a tip about headphones that might be able to help you.
Posted on Apr 22, 2011
Central heater wires melting at disconnect. can someone please help?
Over heated wires can be due to high current or from a loose connection. If from high current, then the entire wire will melt along the whole length. If the melting is only near the disconnect, then the connections at the disconnect are suspect, or the contacts within the disconnect are bad.
Jan 26, 2014 | Heating & Cooling
Cutler hammer 60 amp non-fusible disconnect... looking for instructions or a diagram to install
You connect the two hot wires from your power source to the two lugs in the. On the other side of the disconnect you connect the two hot wires to the A/C unit to the other two lugs. You tie the neutral wires (white) together and insulate them. You ground the ground wire to the box and run a ground wire to the AC unit.
So, you should have a red, black white and ground wire on the supply side to your disconnect. The red and black are your hots from your main box to the disconnect. They go on one side of the disconnect. The units red and black go ont other side. You connect the neutrals and ground it and you are in business.
Don't guess, because you are fooling with 220 Volts AC which will knock you silly.
Aug 02, 2011 | Heating & Cooling
I have a Jenn-Air CCE3401 Electric Cooktop I want to remove. How do I disconnect the wires from the cooktop? In other words, how do you get inside the cooktop to disconnect the wires? Disconnecting...
Firstly turn the power off. Lift the cooktop out from the benchtop and lean it against the wall. There will be a small panel where the wiring terminates into the cooktop. Remove the panel and disconnect the wiring to the cooktop. Ensure that you insulate all wires properly. You can then turn the power back on if you need to.
Feb 12, 2011 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Change out starter
Starter - 4 Cylinder 112139431
  1. Release hood latch and open hood.
  2. Disconnect and isolate the battery negative cable.
  3. Remove the air cleaner box.
  4. Remove the lower bolt.
  5. Remove the upper bolt and ground wire
Starter Removal - 4 Cylinder 112139432
  1. Remove starter.
  2. Disconnect solenoid wire connector from terminal
  3. Remove nut holding B+ wire to terminal.
  4. Disconnect solenoid and B+ wires from starter terminals.
Jan 01, 2011 | 2004 Dodge Stratus
How to disconnect electrical wiring harness from fuel pump
1-First disconnect your battery ,and then disconnect the connectors,,just disconnect the connector,don't cut the wire,,care full
Sep 25, 2010 | 1996 Jeep Grand Cherokee
Were is the connector to disconnect for ignition timing 89 gmc sierra
You have to disconnect the brown wire thats on the firewall. It disables the computer controlled advance and allows you to set the base timing. Disconnect SET TIMING connector (tan/black wire) located in harness close to distributor. DO NOT disconnect 4 wire connector at distributor.
Thank you for using fixya and good luck, set timing is O".
Jul 05, 2010 | 1989 GMC Sierra
Keeps flashing PROTECT when switched on
Check all of your connections very carefully. If all seems well, disconnect one wire at a time, then power on after each wire is disconnected. Alternate between power off (remove a wire) then power on. If the PROTECT comes back on, reconnect the one wire and then power off. Disconnect the next wire, power on, and see if the PROTECT comes back on. If so, reconnect that wire and continue until all of your wires are checked. If at some point after disconnecting a wire and powering back up, the PROTECT does not appear, that wire you just disconnected is the culprit and needs to be replaced. Even a single strand of speaker wire crossing to another opposite polarity (speaker wire) or input can cause a fault making the receiver "PROTECT" itself. Although it may be tedious, it is effective to trouble shoot this way for the first step. If you want disconnect all wires from the receiver and then power on to see if it does it independently of any other connections. I hope this helps and good luck. Please vote 568462d.jpg below if this is helpful.
Oct 30, 2009 | Sony STR-DE345 Receiver
I need do know what wire disconnects the computers control of the timing so i can adjust the timing and plug it back in
Disconnect the brown and black striped wire next to the heater box the wire goes up the firewall on the passenger side look right over top of the blower motor. you'll see a plug sticking out of the wiring harness loom to allow you to easily disconnect and reconnect the wire reconnect the wire when you have static timing wutxtye0rjd9d9ekmodqt1eoxkvn9hr9qjz1l3dabggyud7sdgr36czsrfxqenadhnijx9nfayi+sz1sug0aaaaasuvork5cyii=
Apr 24, 2009 | 1989 Chevrolet Camaro
Dryer stpped working
with power disconnected
if any wire disconnected before any test, reconnect & test dryer, reconnect wires after each test
disconnect wires from start button and test, conduct when pushed, no conduct when release
if fail replace start button test dryer
disconnect wires from door switch and test, conduct when pushed, no conduct when release
if fail replace door switch test dryer
follow leads from start button to relay(relay is first device connected to start button), and make sure all wires connected at both ends. If any wires disconnected, test dryer
locate thermostats and thermal fuses on fan housing and ducts
individually disconnect wires from each and test. conduct good, no conduct fail
replace any failed thermal fuse or thermostat test dryer
if all prior test OK
replace relay, test dryer
Oct 10, 2008 | Magic Chef CYE4000AWW Electric Dryer
Panasonic PT-53WXD63G Flyback, H.O.T., and Triper
The small wires are disconnected at the focus and screen control block, and the large HV cable is disconnected from the HV splitter.you may have to reuse the large red wire if the new flyback doesnt have the HV lead attached. The Hot is the horizontal output transistor its mounted to a aluminum heat sink near the flyback.
Jul 24, 2008 | Panasonic PT-53WX54 53" Rear Projection...
Skull Candy Lowrider Headphones Logo
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Owen Barnes
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
