Question about ASUS K8V-VM (K8V-VM GREEN) Motherboard
Mb driver installation problem
I have a system with asus k8v-vm motherboard. I have lost its dirver cd attached along with thie motherboard. After reinstalling windows it is impossible to install the driver for its vga, sound and network card. How can i download the mb drivers of k8v-vm motherboard drivers.
  • Anonymous Mar 02, 2009
    i have lost my sound driver cd hence my computer sound is off
I down loaded drievers please help me.
Posted on Sep 21, 2008
Install EXE
Posted on Aug 14, 2008
  • 144 Answers
Go to following link for downloading the drivers for your mobo:
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=K8V-VM&type=map&mapindex=0
Hope that helps..
Posted on Aug 06, 2008
SOURCE:
My problem is audio,video,network,all devices driver pls help me quick thank u
Hi, you can download the drivers here at ASUS:
http://support.asus.com/download.aspx?SLanguage=en&p=1&s=20&m=K8V-VM Ultra&os=&hashedid=N6VbiY4LBNFupVaY
Remember to select your operating system.
The drivers needs to be unziped before installation.
Hope this will help you.
Apr 21, 2011 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
FREE DOWENLOD ASUS K8V-VM Ultra Motherboard Driver
on this page
select motherboard-->socket 754 --> K8V-VM Ultra --> select your operating system and go to download page
If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
Feb 27, 2011 | Computers & Internet
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
I m having asus k8v-vm bt no space for sound card
The Asus K8V-VM motherboard has an intergrated audio chip on the motherboard, Realtek ALC660. You need to enable it in the bios. If you do not have you're manual down load it from Asus; http://www.asus.com/Search.aspx?SearchKey=K8V-VM You'll also need Adobe reader installed to view the manual. Enter the bios menu. Open Advanced. See the top of page
2-21 in the manual. Set, High definition Audio to [Auto] Save and exit the bios. Also check out page 1-19. You can install the driver software from the Asus CD or download it from the Asus link provided above.
Realtek Audio Driver V5.10.0.5211 for Windows 2000/XP/XP 64bit. (WHQL)
Cheers'
Mike
Jan 10, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Motherboard drivers
go here: http://support.asus.com/download/download.aspx?SLanguage=en-us
in the upper left corner in input model to search type k8v-vm, under category click all then click search info.
Click on k8v-vm, select your operating system and download drivers
Aug 19, 2009 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Asus k8v-vm mother board drivers
boot block compatible version ver 003
bad bios checksum, start recovery
is alone window seen in my computer
Dec 26, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Motherboard driver
i lost my motherboard dirver cd Asus P5PE-VM Motherboard
Sep 09, 2008 | ASUS P5PE-VM Motherboard
ASUS K8V-VM (K8V-VM GREEN) Motherboard Logo
212 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
