Question about Mantis 2-Cycle Tiller
My tiller was fully serviced by Mantis and a new starter fitted. Its got the correct petrol / oil mix in and a new plug but it will not start. It wants to fire but refuses to 'catch' When this product is working its brilliant but I have always found it difficult to start.
boscia
  • 163 Answers
SOURCE: Mantis Tiller
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Posted on Nov 30, 2008
SOURCE: Would like to know what year this tiller would be.
replace primer bulb. If that's not the problem check the float in the carb for pin holes . check fuel lines and intake line
Posted on May 17, 2009
SOURCE: trouble starting old Mantis tiller 9012 - don't have a manuel -
Mantis has the owners manuals in pdf format available for download on its website. The tillers are here (I hope the link to the tiller group works...if not, just go to the main site and look for "owners manuals" link.
Also, you can call a number and get a representative who usually can help at the numbers listed there, find authorized service people if its not something you can do yourself, order parts and find detailed schematics in the owners manuals. My dog actually ate mine. LOL. But they are free, the owners manuals, unlike other places that charge you for them like they were a "part".
http://mantis.com/owners_manual_library-swell2_tiller_engine.asp?cat=8
Posted on May 18, 2009
  • 376 Answers
SOURCE: mantis tiller sv-4 echo engine no spark from coil
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
Posted on May 31, 2009
SOURCE: motor run but blades don't
mine is doing the same thing
Posted on Oct 06, 2009
Mantis tiller won't start
Flush out old gas. Check/clean spark plug. Oil filled? Try spraying starter fluid in carb. Carb should not have any oil in it. Change air filter.
Jun 04, 2015 | Mantis Tiller Honda 4 Cycle - No Kickstand...
Need to know oil / petrol mix for Mantis 2 stoke Tiller
it is a 50:1 gas:oil mix. I'd also strongly recommend adding a fuel stabilizer to the mix, as a tiller has a tendency to sit for long periods without being used. Good luck!
Nov 17, 2012 | Mantis 2-Cycle Tiller
New mantis worked perfectly last season. Stored it for the winter. Tried to start it this spring. Pull cord is frozen up. Can't pull it out.
First, call Mantis and get their advice. It may be covered under warranty (I believe it comes with a 2 year warranty). If not under warranty remove the spark plug and try to pull the starter rope. If you can pull it out squirt a little 2-cycle oil in to the spark plug hole and pull it out several times before reinstalling the plug. Then try to start it again. If you can't pull it out after removing the plug try removing the engine cowl that contains the starter rope and see if you can pull it out then. If you can't then there is something wrong with the starter rope mechanism. Try some oil or Liquid Wrench on the spring to see if you can free it up. If you can then the piston may be seized. Again, squirt a little oil ni the spark plug hole. Take a ratchet wrench and socket to put on the crankshaft nut. Try to turn it. Do not apply to much force. I would send it back to Mantis for repair or replacement unless you are mechanically proficient enought to take the engine apart. If you have been using the correct fuel/oil mixture this should not happen.
May 21, 2011 | Mantis 2-Cycle Tiller
Engine wont start. Changed plug; mixed new gas/oil combination. No start!
if you have a spark at the plug try cleaning the air filter, could be just dirty
Jan 07, 2011 | Mantis 2-Cycle Tiller
How much gas to mix the oil in?
First check that your Mantis needs an oil/gas mixture, most of the newer Mantis tillers have four-stroke motors meaning they have oil in the crankcase and use straight gas. If your Mantis needs oil mixed in the gas use a 50:1 ratio. That's usually 2.6 ounces of two-cycle oil (it's sold in bottles that size) to one gallon of gas but read the oil bottle to get the proper mix ratio.
Sep 08, 2010 | Mantis 2-Cycle Tiller
Mantis tiller starts but will not stay running
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Jun 06, 2010 | Mantis 2-Cycle Tiller
Will not get to working speed
RECOMENDATIONS:
-Drain all fuel from the fuel tank.
-Remove and REPLACE with a NEW spark plug.
-Remove and RELPACE with a NEW Air filter.
-With spark plug and air filter removed and fuel drained pull the starting cord many times 12 or so to ensure there is no fuel in the chamber and also check for a spark at the plug.
-RE-MIX WITH NEW FUEL your 2 cycle oil to the correct ratio in a clean fuel can. it is OK to dump some in the fuel tank slosh around and dump out in an approved container for disposal.
-Hold off on putting back on the air filter until you have had it running
Hope this tip helps.
R/David
Jan 19, 2010 | Mantis 2-Cycle Tiller
What is the correct oil/gas mix ratio?
The 2 cycle needs oil and gas mixed while the 4 cycle needs the oil changed every 10 hours of use. 2 cycle is 28:1
Jul 03, 2009 | Mantis 2-Cycle Tiller
Oil smoke on my mantis tiller
Too much oil in the fuel mix. Look for a 2 cycle oil called Opti-2. Comes in 1 or 2 1/2 gallon mix pouches w/fuel stabilizer. One mix for all 2 cycle. It's the best and no measuring, foolproof.
Jun 07, 2009 | Mantis Tiller
Mantis will not start
mantis tiller primer ball will not pump gas. I replaced the old one and it still does not pump fuel. when Ipump the ball Iget pressure in one line but no sucttion into the carb.
Oct 09, 2008 | Mantis 2-Cycle Tiller
Mantis 2-Cycle Tiller Logo
20 people viewed this question
Top Mantis Garden Experts
paulfvincent
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
