Parts can be found at amazon, click here and take a look: Amazon com Central Pneumatic parts. I hope this was helpful. Cheers
SOURCE: Air Compressor won't go over 35PSI
Hello, Your air compressor is leaking in the cylinder and is unable to produce more than the 35psi. Unfortunately oilless air compressors do not last very long. The rings and cylinders wear out. I have successfully repaired some units but, I usually recommend buying the oil type compressor. They last forever. If you want to try and repair it let me know and I'll help you. Good luck.
SOURCE: can't find air filter for central pneumatic air compressor
i do not know which one you taking about! the Air intake or in line moisture type on the discharge.
but both are universal just go to air compressor shop or go on line.
SOURCE: what type of oil for central pneumatic air
It should use 30 weight mineral oil, or 30 weight motor oil.
SOURCE: I need parts for a central pneumatic compressor
http://www.harborfreight.com/manuals/93000-93999/93785.pdf
That should be it, please let me know.
SOURCE: I have a central pneumatic
Its the pressure regulator, if you discharge the air and can set the regulator to a lower psi, and it pumps
to that psi. you will have to replace that part, make sure to have make, model , serial# of compressor
so that the correct part can be fittted to you compressor. good luck!
