Question about Gigabyte GA-K8VT800 Motherboard
Motherboard ga-k8vm800mnf do not find sata hard disc.
  • Gigabyte Master
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 06, 2011
I have a Packard Bell iMedia 2350 that uses the Gigabyte motherboard GA-K8VM800MNF. I have replaced the IDE hard disk with a sata drive. The bios does not see the hard disk and now I am trying to find
I don't think updating the bios will change anything, it's just updates for processors if you look here: Bios Update.
Motherboard Manual here
I don't know which drive you have and your's is a gigabyte board but some motherboards have a problem finding sata2 drives even though the drives are supposed to be backwards compatible. Read this asus board
Jan 31, 2012 | Intel Motherboard
I have a GA-81PE775-G motherboard, will a WD5002AALX (sata-3) be compatable with this
Hi, I have reviewed the Gigabyte Motherboard that you have mentioned. It has SATA (Serial Advanced Technology Attachment) supporting 150 MB per second. Which means that the Hard Drive of Western Digital (SATA 3) which you want to connect is compatible with the SATA port of your Motherboard.
However, the SATA 3 of your Hard Drive supports 3 Gb per second. Hence it will be working in 150 MB per second when you connect to your Motherboard.
Aug 09, 2011 | Gigabyte GA-8IPE775-G (818313002198)...
Can i use a sata hard drive with my ga 7vklm mobo
The Gigabyte GA-7VKMP motherboard does not support serial ATA SATA drives. Open the link provided; http://tw2005.giga-byte.com/Motherboard/Products/Products_GA-7VKMP.htm
2 x ATA 66/100/133 bus master IDE ports
1 x FDD, 2 x HDD and 1 x CD audio input
IrDA(1x5) and COM2 on board
GBT standard front panel
2 x USB2.0 connectors (support 4 ports by cable)
You can connect the adapter below to an opened IDE port and connect a SATA 1.5 drive to your system.
http://www.satagear.com/SATA-MM-A1_SATA_Adapter.html
This should allow you're SATA drive to transfer data faster than the 133MHz standard IDE speed.
Cheers'
Mike
Aug 10, 2010 | Gigabyte GA-7VKMP Motherboard
What kind of hardesk can installed to it sata or ide
This motherboard can use a SATA or IDE hard drive since it has connector for both SATA and IDE, but I suggest you use SATA hard drive for faster data transfer.
You can check this link for the complete specs for this motherboard.
http://techwiki.hardwarecanucks.com/product/2NTEyNzM3NzU4MA/Gigabyte-GA-8I945P-G/#spec
Aug 08, 2010 | Gigabyte GA-8I945P-G Motherboard
CANT BOOT WITHE HARD DISK SATA ON MATHREBOARD GA-8KNXP / GA-81875
The computer has to be programmed for SATA. Please provide us with the symptoms in detail and we can help you. We will also need the computer Name, the Model Number and verification of the numbers corresponding to your motherboard.
We thank you for considering our service.
My name is Constantin (Arzconst)
May 17, 2009 | Gigabyte GA-8KNXP Ultra Motherboard
Wont boot
i think the cpu may have a problem with the board or the memeory. either its bad, damaged or incompartible with your system. try out another cpu
Mar 24, 2009 | Gigabyte GA-K8VT800 Motherboard
Motherboard accepting sata cords for hard drives
I'm afraid that this board does not support SATA drives.
Hi - You can download the manual from the link underlined in blue below:
8VM533M-RZ
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 25, 2008 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Gigabyte GA-K8VT800 Motherboard Logo
267 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
