Question about Gateway (5500381) CD-ROM Drive
My cd reader is not working I can open and close it it runs, or at least it makes a lot of noice but it doesnt read at all Thanks
  • Gateway Master
  • 27,725 Answers
Make sure that the cd rom is getting enough power test all leads that are attached to the cd drive including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd rom then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if your computer came with a motherboard disc the sound drivers could be on it
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
if these fail to fix the problem
It could be a problem withthe lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the acpower 3. remove powercable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected hope this helps
2. http://www.howtodothings.com/computers/a3631-how-to-clean-a-cd-rom-drive.html
Posted on Apr 06, 2011
Non-responsive program
it is possible that the disc was recorded in a format that cannot be read on your machine
Mar 27, 2017 | Sony VAIO VGN-A690 Notebook
Whenever I watch a dvd on my HP Pavilion dv4 it stops and some noice is coming. The dvd stops.
1.Click on Start.
2.In Start Search or Run type devmgmt.msc and then hit enter.
3.This would open the Device Manager Window.
4.Now locate something which reads as Cd/DVD , there would be a + sign next to it,
5.Click on the +Sign next to it and down below locate the driver responsible for the funtioning of the cd & dvd.
6.Now right click on the driver and then click on Uninstall.
7.Now locate an option right at the top which reads as ACTIONS.
8.Click on Actions and then click on Scan for Hardware Changes.
9.Close the Device Maneger Window.
10.Click on Start and in Start Search type Regedit and then click Enter.
11.This would open the Registry Editor Window.
12.Locate an option which reads as HKEY_LOCAL_MACHINE
13.Click on the +Sign next to it.
14.Now locate another option which reads as SYSTEM.
15.Click on the +Sign next to SYSTEM.
16.Now Locate another option which reads as Current Control Set.
17.Click on the +Sign next to it.
18.Now locate another option which reads as CONTROL.
19.Click on the +Sign next to it.
20.Locate an option reading as CLASS.
21.Click on the +Sign next to it.
22.Now we would find a lot of keys..
23.Locate a key which reads as 4D36E965
24.Click on the Key and then look right at the right top corner of the screen and locate Upper Filters and Lower Filters.
25.Right click on Upper Filter and then click on Delete.
26.Do the same if you get Lower Filters as well.
27.CLose the registry and restart the computer to check rthe funtionality of the Drive.
I am sharing a screenshot of how filters look in registry..
http://filedb.experts-exchange.com/incoming/2008/06_w26/35425/Regedit-DVD.JPG
Hope this works.
Regards
Ken
May 18, 2010 | Computers & Internet
CD DVD drive not working
1.Click on Start.
Hope this works.
Regards
Ken
May 14, 2010 | Computers & Internet
My dell studio laptop (one month old) has problems playing dvds
It sounds like you have eliminated a media player problem.
Here are some more things you could try:
Disable your antivirus when playing the movie.
Have Dell replace CD/DVD drive. I got a bad drive in my new Latitude and they replaced it. It was a long phone call...be prepared.
It could be overheating. Make sure you have good air flow under the notebook. They make notebook coolers which you can find with a web search.
If this helps please vote for my solution.
Jan 19, 2010 | Dell Studio 15 Laptop
My computer is slow and the is not reading or burning CD/DVD
Slow computer problem would be different then that non reading disks. Slow computer could happen in many cases, a virus is taking up all the memory, or defragmented hard disk, programs that required more memory and cpu speed. CD, DVD could fail to read due to loose cable, BIOS setup or damaged drive.
Sep 16, 2009 | HP Pavilion a800n (PP163AA) PC Desktop
Internal samsung cd-rom sn-124 doesnt recognize cd's/wont work
replace it. samsung cd rom even its dvd writer have lots of problems. sometime they dont want to open unless you leave a cd in it. sometime it doesnt read cd. better change it. get a Sony, LG, Pioneer DVD writer.
Aug 20, 2009 | Computers & Internet
Need Pc Suite For LG KP 500
hello there,
most cd reader can read small cd. review your cd slot ,there is small circle inside drive and suppose to suite small cd
Dec 14, 2008 | Lands Phones
HP Pavillion not reading audio CD
It is possible that this is a drive issue, I've seen drives that one of the optical reader device has gone out, but generally it'e the DVD reader and will only read CD's. It's very rare that the CD reader goes and the DVD reader works. Before you replace drive, if it's only music CD's (you didn't mention program CD's), then update your media player. If it still won't play, then unistall the media player and completely reload it. At this point you can replacse the drive.
Jun 28, 2008 | Computers & Internet
Windows
hard drives dont read cd's
does the door close?
if not close it.
1)left clik my computer
2)double clik the cd rom drive, making sure theres a disk in it.
3)right clik on my computer
device manager
look for a yellow exclamation point or red X where the cd-rom is.
high light the cd-rom
right clik
uninstall
windows will detect and re-install the cd-rom drive.
try a cd
if that doesnt work update windows
also buy a cd-rom cleaner at your local electronics store
clean the drive w/th cleaner
try a cd
if updating your driver for the cd rom drive and all ive suggested then its time for a new cdrom drive
Dec 09, 2007 | Dell OptiPlex GX260 PC Desktop
Gateway (5500381) CD-ROM Drive Logo
60 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
