Question about Samsung NC10-14GW PC Notebook
I have Samsung NC10 with windows 7 and the built-in microphone doesn't work at all..I've checked the volume it's full and un-mute..Also when I put an external mic , I can't be heard on sound/video recording..Can anyone please help?
SOURCE: USB port doesn´t work...
You will have to reinstall the usb drivers again from http://www.samsungpc.com/products/x05/x05_supporteddrivers/x05_supporteddrivers.htm
Posted on Oct 30, 2008
  • 114 Answers
SOURCE: how do i disable my built in microphone?
You should be able to mute it in the sound mixer. That yellow speaker in the System Tray (double left click). Remember to select the Recording one from the top menu if necessary to pull up the sliders and mute buttons display.
Posted on Jan 30, 2009
SOURCE: samsung nc10 built in web cam won t work on msn
Upgrade to the latest version of MSM Messenger to fix this problem.
Posted on Apr 14, 2009
  • 18 Answers
SOURCE: My Netbook NC10--no sound comes out when playing
Go to the device manager and right click on the device and select update drivers. You may need to reinstall the sound drivers.
Posted on Jul 09, 2009
  • 10 Answers
SOURCE: HI I HAVE A NC10
The problem is that your laptop has no sound drivers. To fix, we need to install these "drivers" (a program that tells windows how to interact with your speakers correctly).
Assuming you're using windows 7, download the following file: http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_UK&CttFileID=2477453&CDCttType=DR&ModelType=N&ModelName=NP-NC10&VPath=DR/200910/20091008134156078/Sound_Win7_6.0.1.5923.zip
Once it's downloaded, go to the place where you saved it, then right click and click "extract all" click next through all the steps and you should have a new folder. Double click on that and then double click on "SETUP.EXE". Click through all the steps, if anything asks for permission give it permission, if any warnings come up, accept them because you know this is a trusted piece of software from samsung, then finally restart your computer when you're prompted to.
Posted on Mar 13, 2011
My built-in microphone doesn't work. It says it's working but every time I try to talk, it doesn't recognize my voice. Any suggestions on what I should do?
My windows is in french, so I might not translate the windows' names right, but i'll try to help you.
Maybe it's muted, check in your Configuration Panel, in "Sound and Audio", in the Volume Tab, click on the first "Advanced configurations". And check if it's muted.
Aug 24, 2011 | Audio Players & Recorders
My microphone isent working on my laptop i plug a mic in and nuthen can be picked up
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Mar 22, 2011 | Thomson M140 Microphone
I am trying to hook the mic up to my computer in the location for microphones and it is not working. i also tried via my tv and stereo system. it will work to receive sounds if plugged into the phones
Click VOICE
That should be it.
Feb 23, 2011 | Samson R31S Microphone
I cannot get my microphone to work
Click VOICE
That should be it.
Feb 19, 2011 | Toshiba (P000257700) Microphone
My microphone is built in to the computer but will not even show up in my recording devices. it used to work fine and now it doesnt say it even exists on the computer.
See last paragraph of instructions below re unlisted devices.
Click VOICE
That should be it.
Feb 19, 2011 | Compaq Audio Players & Recorders
My microphone on Presario F762NR stopped working i did troubleshooting and it did not find any problem! maybe it is turned off somewhere and i don't know where!
Click VOICE
That should be it.
Feb 18, 2011 | Compaq PC Microphone (Black or Beige)...
My computer will not see or hear sound from my microphone but i know it works
Click VOICE
That should be it.
Feb 17, 2011 | Labtec Verse-514 Consumer Microphone
My microphone on my laptop does not work i checked everything test it nd cnt hear my voice..?
Click VOICE
That should be it.
Feb 16, 2011 | Toshiba (P000257700) Microphone
Computer does not recognise my microphone, so i can't use skype to call people. i know the microphone works, i've had this problem before and i eventually got the computer to recognise the microphone - but...
Click VOICE
That should be it.
Feb 16, 2011 | Audio Players & Recorders
My Mic is on all the time it is also coming through the speakers so when i turn external speakers on there is an huge feedback
See Adjust volume below
To use any microphone with your computer you will need to enable it in control panel. Instructions are for Windows XP but are similar for Vista and Win7
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and the volume slider is at the top of the scale.
Ensure the MUTE ALL box isn't checked before closing window.
Click VOLUME button in SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. The same applies to 'Internal MIC' if you are using a laptop with built in microphone - this must be enabled/ disabled separately to the external MIC.
To adjust audio volume.
You can also put a check mark in the box to show the volume control icon on the Task Bar so you can go straight to it to in future
Feb 10, 2011 | Toshiba (P000257700) Microphone
Samsung NC10-14GW  PC Notebook Logo
655 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
