Question about HP Officejet 5610 All-In-One InkJet Printer
Fax not working Error 388
From my HP allin one machine i am not able to send the fax, most of the time Fax send faild message displaying while take a log report error 388 will come . please help
  • dashaunam Oct 03, 2008
    every time i try to send a fax i get this error code or and other communication error code im constantly holding my breath
  • Sarah McDonald
    Sarah McDonald May 11, 2010
    This error means;
    Unable to complete the handshake.
    *Try to send the fax at a different time when telephone line conditions have improved
    Have you tried to send to the hp fax test number (888)473-2963? Did you get the same message? Are you on a digital phone line? Are you using the fax cord that came with the printer?
We had the exact same problem. Static on the line. We had the cable company check and sure enough our digital modem for the phone line was bad. The new replacement fixed the problem instantly.
Posted on Jan 23, 2009
    Problem Solver:
  • 4 Answers
I used to have the same problem anytime I tried to use the fax. Drove me crazy. The problem for me was that whenever HP software updated it corrupted the installed software and I had to reinstall the program.
I finally ended up copying the files from the install disk on to the hard drive so I could find it quickly when I needed it and HP would repair itself using the hd installation files.
You might also check the back of your printer to make sure that none of the cords are lose or the usb isn't loose from the pc. This will cause it to have problems with the handshake. I found especially during warm weather that they tended to get loose because of expansion.
Hope this helps...
Posted on Aug 27, 2008
Fax not working error 388
Posted on Feb 27, 2009
Error meassage while trying to fax
please refresh fax memory and send the fax
Mar 09, 2012 | HP Officejet 5610 All-In-One InkJet...
Keep gettomg error message 388
Hi There,
HP Support provides definitions and solutions for it's printers.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=uk&docname=buu02549#Error386
At this site you can simply scroll down and click on the blue underlined link "388" which states,
"There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time."
"Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve."
Since you didn't state that you were having a problem sending faxes, I fear this is limit to which I can assist you. That being the case, please reserve negative feedback for HP if the solution isn't sufficient.
If the error persistes and you are not attempting to send a fax unsuccessfully, it would indicate a false error report and that your registry in your operating is a bit out of order where the printer is concerned and the best "final" solution would be to uninstall the printer from the Control Panel COMPLETELY, then hold down the WIndows logo key and press the R key. A Run window will appear. Type in %temp% and hit ENTER. Your Temp File folder's contents will appear. Left click one in that window and then hold down the CTRL key and hit the A key. All files will be selected. Hit the Delete key. Remove every file that Windows will allow and then close the window, Disconnect the printer from your computer. Then go here:
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_query=Officejet+6210
Select the correct version of your 6210 (there are 3). At the next page Download the Full Version software by saving it to your Desktop. Then double-click the software installation file and follow the prompts. Do not connect your printer until the software prompts you to do so.
Ciao for Now
Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
Solution
Solution
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve. Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
Solution
Solution
Sep 07, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Problem faxing-error message
Error 388:
Definition
Solution
Error 403:
Definition
During a V.34 transmission, the local machine is unable to connect (handshake) with the remote machine and is consequently unable to send a T30 frame. This occurs when the line is disconnected or if line conditions degrade during the session.
Solutions
  • Remove any pass-through devices from the phone line, and then try the fax again.
  • Confirm that the fax/phone cable is no longer than required, and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
  • Try to send the fax at a different time when telephone line conditions have improved.
May 29, 2009 | HP Office Equipment & Supplies
Receiving error 388. Can receive faxes but won't connect with other fax machines when trying to send
The reason for the error code:
4e5e48b.jpg Error Code: 386, 387, 388, 389, 390, 391, 392, 393, 394, 395 Definition
Solution
Solution
Please Click here and follow the instructions to resolve the issue.
May 21, 2009 | HP Officejet 6310 All-In-One InkJet...
Error message 388
Hi! Error 388 means the local machine has originated a fax session and detected a remote fax machine but has been unable to detect any T30 frames.
If the machine is in V.17 mode, it is likely the connection has been interrupted. In V.34 mode is also possible for this error to occur due to compatibility problems with certain machines and/or line conditions.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. Disable V.34 on the local machine and attempt the transmission using the V.17 mode. ( See error 227 for changing to a slower speed or disabling V.34 .)
Use the link below-
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=1153695&prodTypeId=18972&prodSeriesId=1153695&objectID=buu02549
Jan 08, 2009 | HP Photosmart C6180 All-In-One InkJet...
What is error 388
there is not error code for the OfficeJet 4315. however, there are similar code for other Hp printer.
error "388" is lised as unable to detect T30 frames. in other words, the machine fail to establish comparable connection. this can be the machine trying to send out fax in high speed, or the phone line problem.
consult the user manul how to set a lower transmission rate, or try to send the fax at a differnt time of the day . If that still give you problem, please call the phone company and have they look a the phone line.
Nov 10, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Can't fax in or out with my L7680
386
387
388
389
390
391
392
393
394
395 The machines were unable to complete the handshake.
*Try to send the fax at a time when telephone line conditions have improved
Aug 05, 2008 | HP Officejet Pro L7680 All-In-One Printer
Fax
error code 388 says :-
*Try to send the fax at a different time when telephone line conditions have improved.
Mar 06, 2008 | HP PSC 2410 All-In-One InkJet Printer
Fax Error codes
I have mentioned the Description for the error codes.388 and 421 error codes means the same and suggestion to resolve the problem.
282 - Retry the transmission.
388 - Reattempt the fax reception at a different time when telephone line conditions have improved.
421 - Reattempt the fax reception at a different time when telephone line conditions have improved.
233 - A communication failure has occurred between the two machines (OR) The user at the remote machine might have pressed the Stop button. (OR) Sometime Call waiting service might cause this error code.
  • Turn OFF the Error Correction mode(ECM).Steps to do. Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to Error Correction mode(ECM) and highlight -> press ok/Enter->Select turn OFF-> press ok/Enter.At Last Press Cancel to quit the menu.
  • Decrease the Fax speed.Steps to do.Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to" Fax speed"-> press ok/Enter-> Choose "Medium speed or slow speed ->press ok/Enter. At Last Press Cancel to quit the menu.
Thank You
Feb 08, 2008 | HP Officejet 9110 All-In-One InkJet...
Error message
Or try to disable the ECM on yuor printer, to do that to these steps:
Press SETUP
Press DOWN until you ADVANCE FAX SETUP displays
Press OK
Press DOWN until ERROR CORRECTION MODE displays
Press OK
Press RIGHT ARROW to turn it off
Press OK
Then try to send new fax. If this does not resolved your issue pls try to go to your phone provider. Thanks
Oct 26, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
3,623 people viewed this question
Ben Johnson
