Question about Belkin (F5D8235-4) Wireless Router
Router now works intermittently, will disconnect from internet and i have to unplug it and plug it back.reloaded software, try to update firmware but i get a .bin file and all i can do save it what else can i do
Well I have to say this was broken the first time I looked at it customer brought it in broken.
Posted on May 12, 2012
  • 60 Answers
Try resetting the router. If it does not work then you will have to update the firmware of the router. To do that you have to download the firmware file of the router ( it will have an extension of .bin). Save the file in your pc and go to the router's page and update it. It will look for a .bin file. Browse to the location where you downloaded the firmware and update.
Posted on Apr 07, 2011
What to do when security light is orange?
Reboot
  • The most basic way to attempt to fix a router problem is to reboot the device. This is accomplished by unplugging the powericon1.png cord, waiting for a minute and then plugging the power connector back in. If the orange light continues to blink, you will have to update its firmware.
Download New Firmware
  • Even though the wireless router is malfunctioning, downloading new firmware is possible by disconnecting the malfunctioning Linksys device from the Internet connection in the wall, then using that jack to plug your machine directly to the Internet. If this is not possible, use another computericon1.png that can connect to the Internet. You can download a firmware update directly from Linksys (see Resources).
Install New Firmware
  • Once you have the firmware update available on the computer affected by the malfunctioning router, open the file and follow the instructions to upgrade the devices firmware.
May 11, 2014 | Linksys Wireless-N WRT150N Router
Tip
Internet keeps disconnecting - Internet disconnect
Having intermittent internet disconnects? There could be a couple of causes for this issue. Your internet could be degraded when it gets to your house causing disconnects. You will have to contact your Internet Service Provider in order to have them resolve this issue. Normally, they will replace splitters and may even replace lines outside of your house. You could also be having problems with the modem directly. The may replace this. If you have a modem that you bought that was not provided by your ISP, you can try to update the firmware on the modem.
If using a modem
I recommend you unplug the router, plug the computer directly in the modem and see if you still have the problem. If you still have the problem then you know it is just the modem. If the problem resolves itself then you know the most likely culprit is the router.
I would also recommend that you update your router firmware as well. Do a google search for the brand name of the router and go to the companies website, look in the support/downloads section for updated software.
--If possible, try a different Ethernet port on your router. You may have a bad port.
--Take out and reinsert all Ethernet cables on your network. Loose cables can cause disconnects.
--If possible, replace the Ethernet cables. Bad cables can cause this.
Lastly, you could be having an issue with the Network card(NIC) on your computer. Network cards are either built into the modem or external(a card you insert into the motherboard). Using the process of elimination and the steps above, you can hopefully narrow down the problem to one specific component of your network.
Regards,
G33k
Keywords
Internet disconnecting, internet keeps disconnecting, internet disconnects, internet not staying on, internet shuts off, internet keeps shutting off
on Jun 14, 2011 | Computers & Internet
Router kicks me off the internet after 50 minutes.
1.Ensure your router is secure if not you will want to secure your router in case someone else is stealing your internet to do that copy and paste link inside your browser.
http://vectrosecurity.com/content/view/49/26/
2.Powercycle your equipment ( Unplug power wait 15 seconds then plug back in)
3.Update Firmware to do that open your browser in the address bar type 192.168.1.1 then hit enter
find Firmware Update and update your Firmware.
4.Tether your connection (Plug Ethernet Cord directly into computer bypass router)Ensure that it is the router that is disconnecting you.If internet disconnects after being tethered it is an issue with your network adapter and you will need to take your computer to manufacture or local tech.
5.If known router issue reset your router to do that you will need to press and hold the reset button located on the back of the router for 15 seconds or until router resets, "Remember by resetting your router will reset to default settings you will want to secure your router again copy and paste web address and follow on screen instructions. Good Luck
Feb 19, 2011 | Linksys Wireless-G WRT54G Router
Every evening when i get ready to go onto the internet it says that its not connected and to get it to connect i have to unplug the router wait for a little while and plug it back in then it will connect?
The problem which your are experiencing is an intermittent connection , for this you can try updating the firmware on the router and observe the connection. Still if the problem persists then its obvious that the router has gone bad.
Please let me know the model number of the router to send the firmware version of it.
Thanks in Advance!
With Regards,
Prema.
Jan 11, 2011 | ASUS (wl500g) Wireless Router
Losing internet access every few minutes. Time Warner says problem is not theirs. I disconnected router for 30 seconds and plugged it back in but problem persists.
Try to upgrade the firmware of the router. Firmware is the software of the router.
Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router.
Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router.
On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in.
Now you will need to reconfigure the router according to the Internet service provider.
Click here for step by step instructions.
Oct 01, 2010 | Linksys Wireless-G WRT54G Router
Continually disconnects internet at random
You have WR160N router. This router has issues with the firmware.
Apr 27, 2010 | Linksys WRT160N Wireless Router
Intermittent internet ... constantly have to unplug - plug back in to restore.
follow the link below and download the appropriate version of firmware....
http://en-us-support.belkin.com/app/answers/detail/a_id/301/p/387
download the firmware from the above link and save it in harddisk...
open internet explorer and type 192.168.2.1 in address bar and hit enter...
you will be on the belkin router setup page now...
on the left side you will find an option called firmware update...click that..if it asks for the password, leave it blank and click submit...
click "browse" and locate the downloaded file in harddisk...and click update....
after doing update successfully, do a soft reset by clicking on "reset factory defaults" in the router setup page...
your problem will not occur again...
pls rate is its useful...
Apr 03, 2010 | Belkin F5D7234-4 Router
Router keeps going off
Try to hard reset the router and re-flash or update the firmware of the device. Make sure to know all the internet settings before resetting the router so you can recongure it again.
You can ask your router manufacturer on where to download firmware.
Hope it will hel you.
Oct 08, 2008 | D-Link Vonage-enabled Wireless Router...
Connection disconnect
This is a firmware problem on your router , you can go to this link and download the latest firmware/software for your router http://www.belkin.com/support/article/?lid=en&pid=F5D9230-4&aid=8593&scid=0
This is the link for the steps on how to update the firmware of your router http://www.belkin.com/support/article/?lid=en&pid=F5D9230-4&aid=5947&scid=0
Hope that helps.............
Oct 05, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Router software updates
"Update your router software(firmware)" is a common solution that is suggested for fixing router problems...whether there is a good reason to do it or not. It is possible that your router has a software problem...so it won't hurt anything to upgrade it...and it might help! This Belkin web site has instructions and downloadable firmware files.
Jan 21, 2008 | Belkin (F5D5231-4) Router
Belkin (F5D8235-4) Wireless Router Logo
175 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
