Question about Stanley Bostitch Nail Gun
The driver on my Stanley 18 ga. finish nailer( SB- 1664FN ) is not retracting sufficiently ( or at all )to cycle another nail forward. I have tried to keep the gun lubricated. I have gently pushed the driver up to allow a nail to come into the firing position. This nail will fire, but then the problem reoccurs. I was hoping it was a one time problem, but it isn't. Is this a repair I can do?
  • 1388 Answers
SOURCE: Nails won't shoot
18 guage nailer has a very thin driver and plastic cylinder which bends or breaks easily. Remove the head noting all the parts in the head and remove the piston which should be at the top of the cylinder. Check for broken or bent shaft. Most likely broken and jammed in cylinder. Parts are not expensive. Check WWW.toolpartsdirect.com for diagram and parts
Posted on Nov 25, 2008
  • 52 Answers
SOURCE: 5/8 flooring nailer
TJ
The flooring is it engineered or solid? Specific engineered can be nailed with this gun. Using hte white plate that came in the bag, Its a thicker plate than the gun, and a BOSTITCH 108771, metal shim that installs inside the gun. This will allow 5/8" thick, Owens, Aswaha bay, etc 5/8" thick, with a heavy wearlayer to be installed with this nailer. Any thinner wear layer will become a problem
Posted on Mar 02, 2009
mrhappyface
  • 205 Answers
SOURCE: craftsman 16 guage finish nailer. shoots 2 nails at a time. what
wrong gauge nails or wrong head type nails check that the magazine is not loose
Posted on May 29, 2009
rowdy45176
  • 2176 Answers
SOURCE: I borrowed a stanley bostich (mfn 2006)floor
go to Bostitch.com and it sounds like the driver broke. you will need the exact model number for the replacement part. Let me know if you need more help
Posted on Jan 28, 2010
CaptAdams35
  • 28 Answers
SOURCE: how do you load nails in stanley tr250 staple and
The magazine on the TR250 has a recess on one side as well as a relief at the top where the driver pushes them through the opening. Load the brads/nails on that side of the magazine and it should operate properly. AS A REMINDER: ALWAYS REMOVE NAILS/STAPLES/BRADS WHEN NOT IN USE AS THIS WILL WEAKEN THE SPRING AND CAUSE FEED PROBLEMS IN THE FUTURE.
Posted on Mar 09, 2010
How do i fix my nailer from jamming
Parts are piston driver replace the point has a problem replace driver AND important use the right nails i think the nails are the nails are not big enough 40% chance this is the problem but when you have shoot on a hard surface the point of the driver will get 2 nails at a time and control part 52 that its not dirty or kinked. and the transport is clean.
Oct 21, 2014 | Air Tools & Compressors
How do u get trigger assembly out
Before you remove the trigger, try lubricating all the parts in the head with white grease. If the trigger valve was bad, it would be leaking air as soon as you connect the air supply. Most likely just lack of lubrication or worn parts in the head causing problem. Good luck.
Jan 26, 2014 | Stanley Air Tools & Compressors
BOSTITCH 1664FN 16 Gauge is spitting out 2 nails, stuck together, at once. I cleared a Jam by opening the nose door. I thought there was a piece of metal strip in there. Now it's not there. Is this...
There is not enough room in the nose of the gun for two 16 gauge nails. Most likely 18 gauge nails are the problem (thinner). If nails are correct, tip of driver must be damaged allowing the driver to hit part of the next nail. The driver should be slightly tapered on the side that faces the rails so that the driver will hit first nail head and gently shove the rest of the nails back into the rails out of the way. I dont believe that you have any missing pieces. If nails are correct, remove head and pull out the driver and check for damage. Hold the tip of the driver against nail head, should be slightly thinner than head of nail.If the driver is not tapered slightly on the side that faces the nails, maybe you should sand it a little so the driver will not hit the second nail. Goodluck
Sep 25, 2011 | Stanley Bostitch SB1664FN 16 Gauge...
Stanley Bostitch SB-1664FN will not activate at all when ptrigger is pulled. Air supply is OK- Plunges but will not fire :-o ??
Sounds like a safety mechanism not activating the trigger. If you have the manual look for the breakdown diagram and check that everything is in place on the gun. If not go here and you can get manual.
http://servicenet.bostitch.com/Products/Detail?productNumber=SB-1664FN
May 27, 2011 | Stanley Bostitch SB1664FN 16 Gauge...
I inherited a Bosch T31 bradder and stapler. Couldn't get any help at Home Depot chosinga nails. Bought Porter Cable 16 Ga. 1" finish nails (PFN16100-1). Released arm and slid the nail carrier...
BOSTITCH T31-1 stapler & T31-2 STAPLER and NAILER. Both use 18 gauge (very fine gauge wire). Try using 18 gauge Bostitch staples (used in BT model bostitch staplers). Good Luck
Feb 03, 2011 | Stanley Bostitch N80CB Coil Framing Nailer
The driver on my Bostitch nail gun won't retract
This is usually caused by either a lack of lubrication or a defect in one of the seals. If hte nailgun has been uised a lot, purchase an O-Ring kit and replace all of the O-rings. That should resolve the problem. I believe that these kits are available for around $20-$30.
Dan
Apr 12, 2010 | Stanley Air Tools & Compressors
My Bostitch SB 2in1 nailer will only on occation nail all the way into the wood. For the most part the nail will bend over before it goes in, which damages the wood. I spend more time tying to pull out...
I ran into this problem many times. Don`t use the Bostitch brand nails. Use the generic or other name brand. You`ll notice the generic one`s heads are just a little bigger and the driver blade won`t run down the side of the nail!
Thanks,
Jeff
Jan 05, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
My bostitch 1664fn finish nail gun blows lots of air out exaust
Open the front and clear any jammed nails that are there. Oil the gun, push the drive pin back in if it didn't go back in when the front was off and try again. If there are repeated nail jam issues, try genuine Bostich nails.
Dec 03, 2009 | Tools & Hardware - Others
Stanley Bostitch Nail Gun Logo
184 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
