Question about Sansui VHF6010 VHS VCR
What does SAP stand for on the VCR and how do I remove it?
    Top Expert:
  • Sansui Master
  • 74,377 Answers
Hello
SAP stands for [Second Audio Programme]. In some tapes, audio will be recorded more than one language, where the listener can select his option. It can be removed from entering into its menu, according to its manual. There will be options for that. Refer to its operatin manual, go to the sound adjustment section, and find the option; set it to OFF. OK.
Posted on Apr 06, 2011
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
How do I turn off SAP on a Toshiba TV/VCR/DVD combo
The SAP usually is selected as part of setup so returning to the setup routine should allow you to disable it
Oct 13, 2012 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
The vcr writing on the tv screen says "SAP" and the sound won't play. How do I turn SAP off?
Hello
SAP means Secondary Audio Programme. To cancel this, you have to get into the Minu of your TV, and surf through to get the SAP display window. There you have to set the SAP of OFF. For more details go to the user manual of your TV. OK.
Apr 29, 2011 | Samsung CXM2785TP 27 in. TV/VCR/DVD Combo
Sylvania MTS/SAP tv/vcr/dvd combo turning itself off
could be that either the dvd or the vcr are malfunctioning, usually it is the vcr that creates the problem. If you turn tv on and set vol to low see if you can hear the noise of the motor loading or trying to load,with out a tape inside. It may be a good idea to have a qualified tech repair it, these units are difficult to work on and further problems may come up if you are not familiar with the tv.
Dec 31, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
Want to stop VCR from using Spanish language on programs it records
Use SAP (or SAP/HI-FI) button on remote to cycle through the choices until you get to English or OFF.  Or use Setup Menu to select English language.
May 30, 2009 | Panasonic PV-V4525 VHS VCR
I am unable to figure out how to remove SAP from 2 of my stations when I run the VCR through the Zenith TV. This is a relatively new problem. All the other channels I record are okay. I downloaded...
LEAVE TV UNPLUGGED OVERNIGHT TO RESET ITSELF. IT SHOULD BE BACK TO NORMAL AFTER POWER DRAINS FROM POWER SUPPLY. THAN GO INTO YOUR MENU SETTINGS AND TURN SAP OFF
Apr 19, 2009 | Samsung Televison & Video
I recently install a cable line for my lxi tv and installed a vcr/dvd player. Now, I have no picture or a few channels are snowy. I do not have a remote and must use the hard buttons. I did notice that...
Hi Chara77,
There maybe a couple issues that could be causing your problems.
a) Check your cable lines to make sure there are no cable breaks, or loose connectors. Tightening down connectors will sometimes assist with that as well.
b) Depending on how you change the channels there maybe an issue with the television not receiving the full signal from the vcr/dvd player and you may need to change channels only from it.
P.S. SAP stands or "Second Audio Programing" it usually allows secondary audio tracks such as bilingual programing. It should not affect your picture.
Cordially
Jon
Go Ahead. Use Us.
Apr 21, 2008 | Televison & Video
VCR Help
SP means Standard Play. Generally that is the Normal speed at which a VCR Records or Plays back a tape. SP is automatic, as it is the Standard setting. If you wish to record more picture than the normal 120 mins on a tape, then you choose LP (Lond Play) oe EP (Extended Play).
Nov 20, 2007 | Sansui VHF6010 VHS VCR
Vcr spanish language
You may have your SAP settings turned on in your VCR. Check your setup menu and turn SAP off SAP stands for Secondary Audio Program, it allows for bilingual sound if the station is transmitting a SAP signal. Thank you,
Aug 27, 2007 | Sanyo VWM-900 VHS VCR
Sansui VHF6010 VHS VCR Logo
409 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
