Question about Sram X7 Mountain Bike Rear Derailleur
New Trek Fuel Ex7, gears are slipping out, how do I tighten the cable? Thanks
    Brigadier General:
  • 8,546 Answers
If you mean the chain is switching between the gears maybe you just need to adjust the indexing so it is precisely aligned with one gear at a time. If it is skipping over the teeth in certain gears like the one(s) you use most, look for worn teeth front or back or 'stretched' chain.
http://www.parktool.com/blog/repair-help/categories/derailleur-systems
If you have either, replace the whole drivetrain as new parts will not match up with worn ones.
http://sheldonbrown.com/chains.html
Posted on Apr 06, 2011
2005 holden rodeo RA DX 2.4L ute recent power loss when driving, over revs when changing gears would i need a new clutch installed or cable tightened?
is this a stick shifted car?
the clutch slip is easy to detect, (m/t) the rpm rises, and speed not. (ive burned up many a clutch racing, so know them, and fixed them all self)
yes, adjust the clutch free play , if cable system it gets way off
as you drive, tighter and can cause slip as free play passes ZERO.
Jan 09, 2015 | Holden Cars & Trucks
How do i tighten the shifter
Gears slip because gear cable has slack in it. Take it to local bike shop for correct repairs
Aug 03, 2014 | Roadmaster Granite Peak 26" Mens Mountain...
Need to adjust front brake pads
There is an adjuster where cable enters brake caliper
Also you could loosen mounting bolt. Realign and tighten.
Apr 09, 2014 | Trek 3700
I put the cliche in new. And now it wount go in 1st gear. It stals out every time
tighten your clutch cable up so you get the max pull and cluth seperation,then it should slip into gear
Apr 24, 2011 | Yamaha Royal Star Venture Motorcycles
How do I adjust the gears, which have been slipping?
If you mean that your gears are slipping by means of the chain improperly engaging or riding along the walls of the cassettes outer gears, you can adjust the rear derailleur by means of a few tools. You can control how far in and out the derailleur moves by adjusting the two limit screws with either a proper fitting allen wrench or a small phillips head screwdriver. This won't have any affect on the inside gears but if it slips on the outer-most gear, it may help. You can then adjust the cable pull by hand on the adjusting knarp if present on the derailleur. It is the little (sometimes plastic shrouded) adjusting mechanism which the cable housing seats itself in. It is found directly on the derailleur and commonly on the shifter being used with the derailleur. You can rotate the knarp clockwise to loosen the cable or counter-clockwise to tighten. If the knarp has been threaded all the way in or too far out, you can return it to its original position and tighten or loosen the shifter cable manually using either a 5mm allen wrench, a 9mm box end wrench, or a specialty tool. Depending on the positioning of the derailleur and its design, tightening or loosening the cable will affect the position at which it is placed for each related gear. With a little bit of time and examining, you can hopefully figure out the most effective setting which would hopefully allow the derailleur to engage each individual gear without hesitation. To tell wether you adjusted it properly, follow these guidelines. 1, Make sure each gear being engaged is reflected on the position of the shifter. 2, When shifting gears by hand, the chain should not drop below the selected gear nor should it hesitate to move into the selected gear from its previous gear. 3, Check the limit screws position on the derailleur and make sure it is adjusted so your low and high gears are engaged without the chain slipping past the low or high gear, and slipping of the cassette. 4, When tuning the rear derailleur, make sure you account for the change in the chains travel path due to front chainwheel shifts.
- If the derailleur is not an issue, and you attempted to adjust it with similar results afterwards, look over the drivetrain of the bike closely while it is in motion and try to see the exact component that seems to be the source of the problem. I will be happy to dig deeper into this problem if you wish to ask another question regarding this issue. Good luck.
Mar 03, 2011 | Dahon Speed D7
Belt seems to be slipping
good evening. I would suggest checking the tine bearings as well alignment. I had (have) a 2003 mtd rear tine which blew the entire bearing box for the second time. The times should have little to no flex when push or pulled. Fortunately, MTD came good for the first rebuild even though my warranty had expired...they covered the parts and labour was all mine. If the tines seem properly working, possibly try out this website to get the 100% correct belt....hope this helps.
http://www.milacalawn.com/parts.asp
Apr 17, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
How do i set up my shimano 21 gears . just had new cables and ive lost some gears. theres also small screws on the drailiures, and ive messed with them and maybe thats my problem?can u help me on how to...
okay start with the deraileur in the smallest gear if it wont loosen cable and screw with the letter h by it if you cant see letter just loosen the one that lets it move out only go until its in high gear then making sure its shifted to high gear tighten cable slowly shift to low gear when it reaches low tighten small screw you havent adjusted yet to keep deraileur from going into spokes
Apr 07, 2009 | Cycling
20 Year Old Craftsman Lawn Tractor Steering Gear Slips
check top of sector gear mounting plate for waer this is the gear that hooks to you steering gear . the plate that it mounts to will ware down causing it to be loos and slip . the only way i know to fix it is to pull the cross member out and take it to a welding shop and have it built back up.if the bolt is as tight as itcan go .
Mar 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sram X7 Mountain Bike Rear Derailleur Logo
288 people viewed this question
Top Sram Cycling Experts
Michial Gueffroy
hgpilot
John Egan
John Egan
Are you a Sram Cycling Expert? Answer questions, earn points and help others
