Question about GE GSL25JFPBS Side by Side Refrigerator
I have a GE refrigerator modelGSL25JFPHBS and I think I have a defrosting problem because the evaporator was a solid blck of ice. Can you tell me how to check this to see if it is working, is there a way to jump the mother board out. thanks emile
    President:
  • 2,468 Answers
You can jumper the board where the line cord enters the board,it will say comp/defrost/neutral in the center,jumper between the center terminal and the outer one that says defrost,if it still doesnt defrost you need to disconnect the defrost heater and check for continuity,then do the same with the defrost thermostat,but the thermostat needs to be below freezing to test it or it will show open(bad) the heater will show some resistance to be good
Posted on Apr 06, 2011
  • 3 Answers
Sells clothing,footwear,handbags,Sunglasses
Online Store,Get Name Brand Fashion From 12USD Now!
Our Website: ===== Http://www.voguecatch.com ====
Our main product list is as follows:
Posted on Apr 07, 2011
Refrigerator whirlpool wbm 501
Problem is defrost thermostat, defrost heating element or defrost timer and or low gas in the system. Remove the back panel in the freezer and look to see if the evaporator coils are frozen solid with ice. If so the problem is no defrost cycle. If no ice then the unit is low on gas and it has a leak. If the refrigerator is old... recycle it and go buy a new refrigerator from Whirlpool.
Feb 07, 2014 | Refrigerators
Why is my ge refriderator "frost-free" freezer frosting up?
most likely the defrost heater behind the panel thats frosted up is burned out so it cant defrost the unit,g.e. is notorious for this,remove this panel inside the freezer and remove 2 screws at the bottom of the evaporator coil holding the heater to the evaporator and unplug it the new part number is g.e. WR51X10055
Jul 23, 2012 | GE GSH25JFT
I have a GE Model #TBX18NI- 18.2cuft top freezer/refrigerator, and the freezer part is working great, but the refrigerator part seems to be getting warmer and warmer. I've tried adjusting the temp...
The frig has a defrost timer which activates an electric element which cyclially defrosts the evaporator in the freezer.If either the heating element or the defrost thermostat are faulty the freezer evaporator will freeze solid not allowing cold air circulation to the rest of the frig.
At a suiteable time empty fridge contents into insulated containers and turn fridge off at powerpoint and allow to fully defrost leaving doors open.The evaporator coil in frostfree is normally located behind the rear panel of the freezer.If you do not have defrost heater it will take 3-4 hrs for complete defrost.
After defrost turn fridge back on and make sure items to be returned to freezer are free from moisture and ice and keep freezer open for minimum of time as moisture will start building up onthe evapoator.
If the fridge works ok for a couple of days and the the original problem returns the problem is with defrost thermostat or defrost heater
Apr 29, 2011 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
GE Profile PSS26PSTA SS freezer problem
Forget the warranty - it is only for the compressor and that is usually five years. Did you check for freezer temp - wet cubes indicates too warm up there. Water dispenser lines may be clogged.
If low temps you may have low refrigerant or a defrost mechanism not working - if not working there should be ice buildup on line entering the evaporator in back of compartment.
Jun 16, 2017 | GE Profile PSS26NGS Side by Side...
No ice through door, but icemaker is working
Only 4 things control defrosting . 1) main board control ....2) arced defrost bimetal....3) #4 thermistor (located on top of the evaporator)...4) #5 thermistor (licated by the drain at bottom of freezer) .
Jul 28, 2009 | GE GSL25JFPBS Side by Side Refrigerator
The entire backwall of the unit is solid ice. 2
OK first defrost the refrigerator. Unplug and remove the back panel covering the evaporator and lets look at the defrost element and defrost thermostat. If they are OK we may need to have a look at mother board mounted on back of fridg. Let me know when you are ready, Sea Breeze
Apr 22, 2009 | GE Profile PDS22SCRL Stainless Steel...
I have a GE side by side refrigerator and I just replaced the defrost heater last week because it would cool and than freeze up and I would have to turn in off and defrost it myself. Now it cools and stays...
Icemaker solid:
This could be a problem with the icemaker not dumping the ice or with the water valve in back not shuting off completely.
Water in the floor:
This may be related to the icemaker but first check the drain under the evaporator coils.
Dec 15, 2008 | Maytag MSD2656G Side by Side Refrigerator
GE Refrigerator forms and Ice dam which stops the evaporator fan from turning.
is it defrosting theres a glass tube which is the defroster bar,there known to have these fail
Jul 07, 2008 | GE GDS20SBS Stainless Steel Bottom Freezer...
GE side By Side GSS22JEMDWW
Maybe but there is also a thermister in the defrost system that might be bad. The thermister is a small, white, barrell shape and is as big around as a pencil, It has 2 wires going in it and is attached to the top of the coils in the freezer.
Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side Refrig. with evaporator iced up solid.
Yes ill be glad to help John. Your refrigerant level is fine. Remove the motherboard axcess panel on rear of refrig. Locate 3 wire blue plastic connector on bottom of board. Wires are labeled Comp, Line, Def. Jump Line to Def and see if heater gets hot. If nothing happens than replace the heater. Let me know what happens.
Dec 04, 2007 | Kenmore 91365 Compact Refrigerator
GE GSL25JFPBS Side by Side Refrigerator Logo
361 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
rodney bartholomew
Level 1 Expert
