Question about Dell (Inspiron 531) PC Desktop
Wen I turn on PC using Windows Vista I get the warning no boot device available. What does this mean?
    Guru:
  • 868 Answers
Hi britchel07,
I see that you are having issue booting into windows on your system.
I can help you with your concern, we can first try to boot into the Hard drive manually, follow the steps below,
1. Power your computer ON then keep on tapping the F12 key on top the keyboard until you get the Boot Menu screen,
2. On the Boot Menu screen select the Hard drive it maybe listed as SATA or HDD, but if it is not listed then we may need to try a different option, on the Boot Menu the Hard Drive should be the first one on the list.
3. Highlight the Hard Drive on the list then press Enter to make your computer boot into the Hard Drive.
if this does not work then your Hard Drive may not be detected by the machine, why I really can't tell there are many possible causes, but we can try other options to see if this can be rectified.
I believe that you have a Desktop machine, we will need to open up the tower to check if there are lose cables inside from the Hard Drive to your systems Motherboard, inside you should see a Flat Orange like red colored cable sometimes Blue that should be your SATA cable going to your Hard Drive from the Motherboard, try reseating the SATA cable to make sure it is properly connected and also check the SATA power cable just to be surem it should also be a black flat cable connected to the Hard drive just right nest to the SATA cable, after reseating the two cables try turning the computer ON again and see if the system will boot into Windows.
If still you get the Error no boot device found then you may need to get a new Hard Drive for your system.
I hope that this will be helpful with your concern, Have a nice day.
Posted on Apr 06, 2011
    Genius:
  • 1,189 Answers
Hello britchel07, a "No Boot Device" means that the device that hold the
[Master Boot Record], is not available because, "the device hasn't been selected to boot the computer?"
If you want the computer to "Boot into Vista;" then you have to choose the device that has the
Boot File.
The device can be the "Hard Disk Drive / HDD, Optical Drive / CD or DVD Drive.
It can even be a Flash Disk Drive / USB."
I'm assuming that you now have a Dual Boot OS.
If this is the case, then you need to "set-up Vista to boot from the correct device."
To "Boot into the "Vista OS."
Reboot / restart the Computer
Choose Vista, to load from the list.
! Before the loading begins, press the [F2] button.
You will open the Boot Menu / Boot Sequence window.
A list of devices will be listed: Optical Drive, and Hard-Disk Drive...
Put the drives in boot-up order, the one you want to boot from; at the top!
Use the Arrow keys to move the devices.
Try the (Hard Disk Drive) first!
After you have made the changes.
"Press the [F10] button to save it.
Reboot / restart the computer, select to boot into Vista from the list.
If everything is set-up correctly.
Then the computer should boot into Vista.
"Let me know if you need more help, if it didn't fix the problem.
Post a "Comment" to get more help.
"If it did help, I would appreciate it if you let me know."
Best Regards, PC Petey
Is it possible to install windows xp 2 when there is already windows 7 is installed.i want to install both os running in my dell vostro 1015 laptop,
Yes you will have to format your drive and remove partitions, then create new partitions and add a boot up option menu. Then when you power on your computer it will ask if you want to boot Windows 7, or Windows XP. You will have to have both copies of Windows also your restore partition can't do this.
Aug 12, 2011 | Dell Vostro 1510 Laptop
Tip
How to install Windows Vista/7 using bootable USB storage device
How to install Windows Vista/7 using bootable USB storage device Requires:
- Windows Vista/7 DVD 0r installation source (setup backup files)
- A 4GB USB 2.0 Storage device (Its recommeded to use USB 2.0 device for optimal performance)
  • Plug your USB storage device.
  • Run CMD and execute the following commands one by one.
  • Diskpart
Run Disk parition utility
  • List disk
To get disk index that is used to pefrom disk paritioning.
  • Select disk 1
Selects disk to pefrom disk paritioning.
  • Clean
Flush your existing all USB drive's partitions.
  • Create parition primary
Creates a parition as primary parition.
  • Format recommeded
Format your USB drive w/ recommeded parameters. (No need to worry about file system format)
  • Active
Set the parition as active to hold bootmgr.
  • Exit
To quit Diskpart utlity
Now copy all Windows Vista/7 files to USB storage device... thats all.
  • Boot your PC w/ it, you can install Windows Vista/7 via bootable USB storage device.
Note: If you face any trouble to boot w/ it or unable to boot, try this
FIX.
I:\Boot\Bootsect.exe /NT60 I: Where I: is the drive letter of USB storage device
on Aug 29, 2010 | Computers & Internet
I have a Dell desktop running Windows Vista. I cannot boot up to Windows. I have a black screen with cursor error message saying: boot device available, ta 0 installed, ta 1 installed, ta 2 none, ta 3...
That message says that the hard disk was found but nothing on it can be used - Vista is completely corrupted. You will have to reinstall it using the recovery cd that came with it when you bought it.
Feb 02, 2011 | Dell Inspiron 531s Desktop Computer
Dell inspiron 531 with vista home premium, sata DVD/hdd, wont boot past bios screen, blinking cursor in top left corner. with nothing hooked up, says no boot devices available. i have tried each one solo,...
That blinking cursor is the way in which the BIOS is telling you that Windows or any other OS is missing . Since you are getting it without even an hdd connected it means that the southbridge is defective. Which means that the motherboard is dead, replace it.
Oct 19, 2010 | Dell Inspiron 531s Desktop Computer
When i turn my computer on i get strike f1 to reboot or f2 for setup utility my computer froze and when i turned it back on after powering it down i can't get any wheres
Hi! you are actually having a no boot problem with your computer. it means your computer cant locate a bootable device( your harddrive) where the operating system is installed.you need to reseat the haerd drive cable that is connected to your motherboard and hard drive(do this if you know how if not ask somebody else to do this for you) this should fix your problem else you need to use an operating system disc(windows os / XP/Vista/windows 7) to boot from and to reinstall your operating system to your computer. warning: doing this will going to delete everything of what you have inside your harddrive.
Jun 04, 2010 | Dell Dimension 8250 PC Desktop
Wen i start my pc on windows vista i reveive
get Win Vista CD, boot from cd and click on repair my computer, here the system will try and fix it, if it does'nt then use the same process to restore the system to a particular time (mind you not COMPLETE RESTORE), you won't loose any save files. good luck
Jun 09, 2009 | Microsoft Windows Vista Ultimate Edition
When I boot into Windows Vista Premium nothing on screen
In Safe Mode, your monitor will not be listed as it is using a generic device driver for basic display. Go into your video settings and reset it to the lowest resolution available. Reboot the computer into Vista again and your display should be working. If you check Device Manager now, you should see your monitor listed. If it isn't, you will need to load the Vista drivers for it. You can then modify your display settings to suit your preferences.
Mar 28, 2009 | ViewSonic VX2035WM LCD Monitor
ACER TRAVEL/MATE 4150 Turned on computer this morning and all I got was: BOOT DEVICE . FLOPPY HARDDISK CD-ROM PXE ENTER UP DOWN UP DOWN THE COMPUTER SAYS NOTHING ELSE, NO START KEY, NOTHING. I HAVE NO IDEA...
1st chose harddisk and hit enter
2nd chose the boot order put the 1st device harddisk, if that will not solve your problem start the laptop in SAFE MODE and restore at a previos stage wen was working ok .
to start in SAFE MODE press F8 at the boot time.and chose SAFE MODE with windows.
Feb 19, 2009 | Computers & Internet
WINDOWS EXPLORER VISTA
then tey and use window Xp cd to boot your systems from the setup and it is ok for using xp than vista ok then before then you can backup your document so that you can format your systems before loading or installing any device ok post to me what else .
Sep 01, 2008 | Sony VAIO VGN-S460 Notebook
Dell (Inspiron 531) PC Desktop Logo
154 people viewed this question
Alun Cox
