Washing Machines Logo
Posted on Apr 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F14 fault on Bosch Maxx 7 I have low water power, could this be the problem? Machine bleeped at me then stopped. I have turned my machine off, but the washing cycle had not finished.
Anonymous
Level 3:
Genius:
  • Master 1,400 Answers
  • Posted on Apr 06, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1400
Questions
Helped
392880
Points
4210
Hello
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error.
You may need to restart wash cycle.
Bosch maxx 6 machine wont start at all the light will only stay on rinse. Its like theres no power
Water censor could be blocked preventing the machine from advancing,turn off machine and blow into the water outlet pipe the exit may be blocked preventing the censor from restting eric992
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
I have a bosch washing machine Maxx WF1200.The machines fills with water than stops. Nothing happens. Also does not spin to release the water. What is the problem?
If the machine heats the water and finishes the cycle without the drum turning it is most likely your motor or what controls it.
Bosch maxx 7 varioperfect
On the bottom front there is a panel, that panel is the 'sump' area. Make sure that is cleaned out so that all water can eject during rinse cycle.
3helpful
3answers
Can't get a Bosch MAXX 5 WAA24161GB to start. Changed fuse and socket, but machine still won't work?
hello, have you checked the glass fuse inside the washer make sure you use the same rated fuse the value will be on the end of the fuse hope it helps
regards
shaun
Washes until before rinsing and stops.
I think the problem was a bad waterfill value. removethe water from the base
RINSE/DRY = Water filling fault (over or under filling)
regards
balisonu79
27helpful
3answers
Bosch Maxx Instruction Manual
F:16 - Doors are not properly closed. Check the doors are closed with no obstacles.
F:17 - Water is not running. Check the tap, hose and filters. Also water pressure can be low.
F:18 - Too much water remaining. Stop the drying program and start Spin program. Otherwise something is bolcking the water exit from the machine.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
