Question about Toshiba TDP-S8 Multimedia Projector
Lamp life is there any indicator in the projector menu indicating how many hours are still left till the things you said begins to happen? tnx
  • 446 Answers
Most projector doesnt have value or indicator, so there is no real approximate whether you have reach the time limit.
it was just a rough estimate, sorry about that but thats how it works
Posted on Aug 06, 2008
SOURCE:
HOW RESET THE TIME OF LIFE HRS TO THE LAMP INSHARP ANC55LP PROJRCTOR
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Feb 08, 2013 | Sharp ANC55LP Projector Replacement Lamp
I have replace the lamp but any how i am not getting any response from projector. As after replacing the lamp projector was ok. It shows all the thing but second time. No response. pl suggest
hi,
you didn't mentioned any thing about the indications. is there is any indication on the projector. if projector have some problem it will show the indication for the same using its self diagnosing system.
just do one thing check the power cable and the power at the socket to which you have connected the projector. if these are ok and the projector have no indications on its panel, then the smps power supply in side the projector have some problem. if so it is difficult repair the smps by the user. need good knowledge of electronics servicing, because there is harmful high voltage points.
Is there is any indication on its panel, then if you discribe the same will provide you the exact solution .
Also try to check the inserted new lamp , lamp cover is it properly closed etc.
if the projector starts try to reset the lamp hour
1. Go to its menu select option2
2. From the option 2 menu select lamp runtime
3. Press and hold the enter button for approximately 3 seconds
4. After resting just power off your projector and turn it on again.
Also check one more thing
The "CONTROL KEY" may be set to "OFF". In order to set the "CONTROL KEY" to "ON"
without using the remote control unit, keep holding down the ENTER button on the projector and press the MENU button for more than 2 seconds.
ok
Apr 04, 2011 | Panasonic Videoprojector PT-LM1E...
The display projected is very faint. The lamp light is not blinking to indicate a problem. Is this an issue with the settings?
Check the bulb hours remaining through the menu. The bulb gets dimmer with age, so it could be close to life expectancy (2000 hrs regular, 3000 hrs Eco) and failing. The indicator light is based on hours only and will shut down the projector after (2100 or 3100 hours of bulb use), so it could still be the lamp failing or a power supply issue, especially if it's dim right from start up. Hope this helps.
Feb 08, 2011 | NEC VT695 LCD Projector
Canon LV-S3 how to check hours on the lamp? do I have to have unit hooked up to an input source?
Lamp Replace Counter
Be sure to reset the lamp replace counter after Lamp Assembly is replaced. When the lamp replace counter is reset, the LAMP REPLACE Indicator stops lighting.
Note : Do not reset the Lamp Replace Counter until after the projection lamp is replaced.
1. Turn projector on, press MENU button to display the On-Screen Menu. Press Point left or right button(s) to move the red frame pointer to the Setting Menu icon.
2. Press Point down button to move the red frame pointer to "Lamp counter reset" and then press SET button. The message " Lamp replace counter reset? " is displayed.
Move the pointer to [Yes] and then press SET button.
3. Another confirmation dialog box appears and select [Yes] to
reset the lamp replace counter.
This projector uses a high-pressure lamp which must be handled carefully and properly. Improper handling may result in accidents, injury, or create a fire hazard.
 Lamp life may differ from lamp to lamp and according to the environment of use. There is no guarantee of the same lifetime for each lamp. Some lamps may fail or terminate their life in a shorter period of time than other similar lamps.
 If the projector indicates that the lamp should be replaced, i.e., if the LAMP REPLACE INDICATOR lights up, replace the lamp with a new one IMMEDIATELY after the projector has cooled down.
( Follow carefully the instructions in the LAMP REPLACEMENT section of this manual. ) Continuous use of the lamp with the LAMP REPLACE INDICATOR lighted may increase the risk of lamp explosion.
 A Lamp may explode as a result of vibration, shock or degradation as a result of hours of use as its lifetime draws to an end. Risk of explosion may differ according to the environment or conditions in which the projector and
lamp are being used.
IF A LAMP EXPLODES, THE FOLLOWING SAFETY PRECAUTIONS SHOULD BE TAKEN.
If a lamp explodes, disconnect the projector's AC plug from the AC outlet immediately. Contact an authorized service station for a checkup of the unit and replacement of the lamp. Additionally, check carefully to ensure that
there are no broken shards or pieces of glass around the projector or coming out from the cooling air circulation holes. Any broken shards found should be cleaned up carefully. No one should check the inside of the projector
except those who are authorized trained technicians and who are familiar with projector service. Inappropriate attempts to service the unit by anyone, especially those who are not appropriately trained to do so, may result in an
accident or injury caused by pieces of broken glass.
Dec 24, 2010 | Canon LV S3 Lamp
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    Lamp life indicator reset
    Click Sanyo Support to download Instruction Manual copy and check page 39 for details about Lamp Reset procedure.
    Apr 30, 2009 | Sanyo PLC-XT16 Multimedia Projector
    How to check for lamp life of my mitsubishi multimedia Projector xd 450u (DLP)
    This should work:
    How to reset the operation time meter
    Plug in the power cord, switch on the projector, and
    reset lamp time by pressing the (left and right arrow) and POWER buttons on the control panel simultaneously.
    Important:
    • If the 3 buttons was not pressed at the same time,
    the lamp time may not be reset.
    • Please confirm the TEMP indicator illuminates
    about 2 seconds and the lamp time has been
    reset.
    • The projector will not turn on if you do not secure
    the lamp lid.
    • You must reset the operation time meter after you
    replace the lamp.
    • Do not reset the operation time meter unless the
    lamp has been replaced.
    Jul 14, 2008 | Office Equipment & Supplies
    RESET LAMP HOURS
    Hi Greg147
    The resetting is not done in the menu.
    Plug in your power cable - Machine is now in standby mode.
    Then Hold down the left and right arrow keys on the Projector and press the power button. You'll see a indicator light on top of the Projector flashing twice - Lamp hours is now reset.
    Hope this is of help.
    Apr 01, 2008 | Mitsubishi ColorView XL30U Multimedia...
    Lamp replacement
    Hi there
    You need to reset the lamp timer.
    Mar 11, 2008 | 3M (EP7640ILK) Projector Lamp for MP7640
    Toshiba TDP-S8 Multimedia Projector Logo
    Top Toshiba Office Equipment & Supplies Experts
    didi2005
    jasbo
    jasbo
    digivisionm
    Level 1 Expert
    Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
