Have had panasonic re 12kr split airconditioner installed today and the installer didnt know how to wire the indoor unit to the outdoor unit.Because there is an extra cord on the indoor unit?
  • Roger Jelinek Apr 06, 2011
    Normally "common" and "y" on the terminal board. Please give us the designations you are looking at on the terminal board. What does the extra cord hook to? Thank you. Roger
  • 27 Answers
The power is supplied by wiring directly to the outdoor unit. The extra cord is not needed (just an extra they put in with the package).
Hope this helps(the installer) James
Posted on Apr 07, 2011
36VDC Indoor split in a 240VAC country
if you use the correct inverter and transformers
best if you just get new units designed to run in that country
Jun 23, 2017 | Heating & Cooling
I have a panasonic split system in the kids bedroom its an ECONAVI indoor unit is CS-E9NKR we have not used this A/C since last summer, now the compressor will not start, only the indoor unit operates
Typically on a mini split the outdoor unit is powered and the indoor unit gets its power from the outdoor unit. If the unit is a year old you might have lost your charge. Look at the connections at the indoor unit and outdoor unit. You will typically see oil or a dirty area on your copper were there is a leak.
Nov 16, 2013 | Panasonic Heating & Cooling
Control cable wires crossed
I would not do anything just yet It might be more prudent to call Panasonic help line, and explain your findings I feel that the system will not have suffered any damage if the control cables have been simply wired incorrectly if that is the problem, try and find a call number from your installation paperwork, good luck.
Jun 08, 2009 | Heating & Cooling
Ch 5 error code
ch5 error code, means that there is a
communication error (serial comunication) between the outdoor and the indoor unit.
Only for LG-airconditioners.
Jan 02, 2009 | LG Art Cool LA121HNP Split System Air...
Panasonic cs-pw9gke i need wiring diagram
Split A/C-Cold:
You need four wires(two #10 and two #12) to the outdoor unit, leaving you house, and three wires(#10) coming from the breaker to tye indoor unit inside your house.
Split A/C-Cold and Hot:
You need five wires(two #10 and three #12) to the outdoor unit, leaving your house, and thee wires(#10) coming from the breaker to your indoor unit inside your house.
This ypical arrangment(all of them use three wires fro the breaker), yet there are other units which may require 6-7 wires connected to the the outdoor unit depends on the added features to the unit.
Regards,
Gulftecheng
Dec 05, 2008 | GE Quiet-Aire Ductless Split System Air...
Unit does not work
all the mitsubishies had auto diagnosis,you must set up with the remote control to see the code and how many times blinking the button to the indoor unit.
Oct 09, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Split AC install
1. mind it - its a very simple installation
2. connect suction (or big cu. dia tube) connection to cond. unit (outdoor unit) big valve.
3. same way - liquid conn.(less dia tube) to small valve (liquid valve) in outdoor unit.
tight flare nut properly
4 provide power to indoor & run the same wire to cond. unit , you must hv got the ins. kit with wires and cu. tubes.
5. or read wiring diagram given of units for wire.
connect as per wiring dig. provided.
ravi
Jan 30, 2008 | Samsung AS18A6RB Air Conditioner
Heating & Cooling Logo
56 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
