Question about Mass Multimedia Computers & Internet
I have Mass Multimedia c-18 c18 LCD dual monitors..... the cable from the monitor has 5 prongs at the top and 1 at the bottom (6 prong)... can you help me find 2 low price power adapters?
SOURCE: Samsung Monitor 510N LCD BLINKING like Tubelight.
Dear ,
let me know this problem you fecing in other C.P.U.?
also if you are not cheked another C.P.U.and give me feedback to me i will help you .
Posted on Jun 14, 2008
bammbammfran
  • 159 Answers
SOURCE: LOOSE CABLE IN FRONT AREA OF MONITOR
The two vx900 s I have here have more of a rectangular plug for the power. Inside it is three large prongs and on the backside should be 3 wires. Two of which go to a smaller plug that connects to the power board.
The power cord is the same as found in many desktop computers.
If this is what you are referring to. Then the plug should be connected inside and it snaps into place onto the meatl part inside the monitor.
You may have to disassemble the unit to get it back together.
Sorry for delay in reply, I never was notified that you had replied.
Fran
Posted on Oct 13, 2008
SOURCE: Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Posted on Mar 12, 2009
  • 19 Answers
SOURCE: AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Posted on Oct 05, 2009
budmrtn
  • 11361 Answers
SOURCE: Xerox XG-19D LCD monitor goes black in 5 seconds
You may also have to check the IC/Transistors Inverter transfomer drivers, also should Ohm out the resistance of the transformers.
Posted on Mar 19, 2010
Hi my LG L1718S monitor wont start from energy saving mode
I had the same problem with my monitor, the problem was that one of the "pins" or "prongs" was bent and mashed flat on the monitor's port plug in cable (the cord from the monitor that plugs into the computer's monitor port). I carefully pried up the prong and straightened it out the best I could and that fixed the problem for me.
Mar 12, 2011 | LG Flatron L1718S LCD Monitor
My monitor is shivering due to magnetic field tell me solution
Solution for many "jittery" or "shaky" or "shivering" monitor problems...
Be sure there are no power AC cords in direct contact with or very close to the monitor cable anywhere along its entire length. If no help, be sure the monitor and monitor cable are not very close to a wall that may have an AC power lines running in it. Also, be sure that you are using a "grounded" (3 prong) power cord, that is is not plugged into a "2 prong" adapter that eliminates the ground ("earth") prong, and be sure that your power circuit that you are plugged in to is properly grounded.
Dec 08, 2010 | Gateway HD2201 22" LCD Monitor
My viewsonic screen started to buzz. i bought it about a year ago. what is the problem??
well if uses a 3 prong plug to plug it in it may be a ground loop.
try this, goto a harware store and get and adapter to change a 3 prong plug to a 2 prong plug and then plug the monitor cable into that then into the wall.
diagram: power>|'.'|<power
ground
cut off the ground plug and that would also work!
Jan 17, 2010 | ViewSonic VX900 19" LCD Monitor
Hp monitor 18" LCD color d5063
Turn the monitor upside down and turn on the lights in the room.
Then you will see a location for a power cord, remember three wires/prongs. Good luck.
Jun 21, 2008 | HP Pavilion F1703 17" LCD Monitor
Menu keeps popping up!
I had this same problem with the Main Menu coming up on my Dell Monitor E171FPb and I thought I would tell you what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back cover.
At the bottom of the monitor case, there is a small circuit board the holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence while holding the switch with a pair of needle nose pliers. I had to rotate this process from one prong to the other while all the time applying slight pulling pressure on the switch pulling it away from the circuit board.
8. Once the switch was removed, I put the cover back on and tightened up the five screws.
9. Then I slid the base back in the slot it came from and tightened the four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so very happy.
May 25, 2008 | Philips 42PF9431D/37 TV
Brightness pops up
it may just be stuck , if you push the button does it click like the others, a little wd40 around the button , lightly, may unstick it.
or you have to take the bezel off and see if the positioning is the issue.
Apr 25, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
Problem on hp monitor
I have a Dell E171FPB monitor that had the same problem with the Main Menu coming up and I thought I would tell you what I did to fix the problem.
Dec 17, 2007 | HP vs15 15"LCD Flat Panel Monitor
Main menu / positioning /
Sounds like a button is sticking. Does it seem too sensitive? It should give a little resistance when pressed and have about 0.1" of travel. Try gently prying outward on the offending button with a pin or needle. If you're comfortable taking the monitor apart, do so and check the alignment of the menu buttons.
Oct 03, 2007 | Dell E151FP 15" Flat Panel LCD Monitor
The Menu always shows
May 19, 2007 | Relisys TL 766 Monitor
Computers & Internet Logo
221 people viewed this question
Top Mass Multimedia Computers & Internet Experts
David Payne
David Payne
Are you a Mass Multimedia Computer and Internet Expert? Answer questions, earn points and help others
