I HAVE A DELL 3110CN LASER PRINTER THAT HAS THE CODE 077-901 ON THE DISPLAY. I UNDERSTAND THIS MEANS THERE IS A PAPER JAM. BUT I HAVE REMOVED ALL PAPER AND THE CODE IS STILL THERE. HOW DO I RESET THE CODE OR FIX THE PROBLEM?
  • 2,574 Answers
The 077-901 error indicates the registration sensor detects paper or an obstruction in that area. The registration sensor is the first sensor in the paper path that the printer uses to detect if the paper is moving thru the machine as it should. The machine knows how fast the paper should move thru this area and measures the time it takes from when the paper activates the sensor to when the paper leaves the sensor. The time difference represents the length of the paper. If the sensor is activated all the time, or after power off/on, an 077-901 error is the result.
To test the registration sensor, you need to enter Customer Diagnosis mode on the printer.
1. Power off the printer
2. Press and hold the UP and DN arrow keys while powering on the printer; the buttons may be released when the LCD indicates "Diagnosing".
3. LCD should indicate "Customer Mode" and "ESS Diag" (or something similar).
4. Press the DN arrow to display "IOT Diag"; press the ENTER button.
5. LCD should indicate "IOT Diag" and "Digital Input"; press the ENTER button.
6. Press the UP/DN buttons until the desired DI-xx is shown, then press the ENTER button to execute the test.
The test we want to run is the Regi-Sensor test -- DI-3. Press the up arrow until the LCD indicates "DI-3 OFF" then press the enter button. The LCD should now indicate "DI-3 L 0". If it indicates "DI-3 H 0", then there is indeed some paper jamming the regi-sensor area.
Posted on Apr 06, 2011
I have a paper jam and I can't locate the problem. I accidently loaded the printer with paper not knowing that several sheets had been stapled together. I removed the jammed paper but it still keeps...
  1. Turn the printer off and unplug the printer from the A/C outlet.
  2. Open the printer and check the paper path for a paper jam or misfeed.
  3. When the paper appears as crumpled or waded up, carefully remove all the jammed paper.
  4. When the paper appears to be angled incorrectly, it may be misfeeding through the printer, remove the sheet of paper.
    • Remove the paper stock and reinsert the paper, make sure the paper guides are adjusted correctly.
  5. Close the printer cover(s).
  6. Plug the printer into the A/C outlet.
  7. Turn the printer back on.
  8. Resend the print job.
  9. In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Dell Printer Support
Feb 26, 2014 | Dell 3110cn Laser Printer
Display on Dell 3110cn says "belt unit close to life". what does that mean?
It means that some internal components needs to be replaced soon. I strongly suggest to hand this printer to repair service or local IT technician
Aug 19, 2011 | Dell 3110cn Laser Printer
I have a 006-370 code on my dell 3110cn color laser. What is my solution?
that error means there may be moisture condensation inside the printer. Turn off the printer, move it into a warm dry room for a couple of hours and try again. If that does not help, you'll need to call a service tech.
Jun 13, 2011 | Dell 3110cn Laser Printer
I can't get the Dell 3110cn laser printer to print A5 size (5.5 x 8) paper even though I loaded it in the tray. The printer asks me to load paper tray. I'm using Word 2003 on a Windows XP machine.
Go to the control panel and open tyour printer folder.
Right-click default printer and select properties.
sleect the paper tab and configure the printer to print on a size A5 paper.
Then click apply.
^_^
Jun 08, 2010 | Dell 3110cn Laser Printer
Trying to find the answer to this problem.....Help!@! --can't print 4x6 picture on dell 3110cn
First question:
Does this printer support a paper size of 4x6?
Are you using a 8x10 sheet that you want several images placed on it?
How does the failure manifest itself? For example, do you see an error code on the printer?
Don
Jan 22, 2010 | Dell 3110cn Laser Printer
Dell printer 3110CN keeps saying paper jam everytime we try to print.
you probably have a paper jam. Check all the places the paper goes to find it. Front cover using the button on the side, the back, the fuser, where the cartridges go. Check everything.
Good luck
Nov 26, 2009 | Dell 3110cn Laser Printer
Dell 3110cn - Load MPF 024-969 letter plain error msg
dell mfp laser 3115cn giving me 024-969 no paper detected
Oct 26, 2009 | Dell 3110cn Laser Printer
Printer Repeatedly Prints exactly 6 pages then reports a jam.
It is problem Fuser unite thermostater is not properly install or or toner dust
May 29, 2009 | Dell 3110cn Laser Printer
Dell 3110cn Laser Printer No paper detected 024 965
remove papaer tray and look for a small black arm which should swing freely it most likely hangs down from the base of the machine or it may be jammed up into the slot it enters to activate the papaer detect switch
LUV
JAFDEE
Jan 29, 2009 | Dell 3110cn Laser Printer
520 people viewed this question
k24674
jasbo
jasbo
