Question about Sony Reader Pocket PRS-300
I'm trying to charge my unit, it shows the usher connection but is not charging. I only have the AC electric charger. What am I doing wrong? Thanks.
  • pinksixnine Apr 06, 2011
    It sounds acceptable to me. Thanks, I'll try it and see what happens.
  • Sony Master
  • 19,396 Answers
Hi.
You aren't doing anything wrong. When it is like that either battery, charger, or pocket reader DC connection is defective.
The charger can be tested using a volt meter or a multi-meter to check DC voltage. The power value must differ of no more than half volt from specifications. Here a replacement charger: AA Battery Pack Charger.
The most common failure giving the problem that you describe is defective rechargeable batteries. If the Reader sees the charger, the unit works with new fresh batteries, and the charger has voltage, then the problem are usually the rechargeable batteries. Replace them.
If the unit does not charge with new rechargeable batteries and a good charger, then the connector on the reader, or the internal power circuit is broken. In that case the Reader must be disassembled and fixed. If this is the case call first Sony support number listed in the manual.
Regards.
Ginko.
Posted on Apr 06, 2011
I have a pnlc1001ya can I get a replacement charging unit as the rabbit has chewed the cord
You want the AC adapter, not the charging unit. If there is sufficient undamaged cord, you can splice both the wires together and use the AC adapter.
Carefully identify the wires - one will have a raised rib or line printed on it. Strip 1/2 inch of insulation off each end of all wires. Matching the wire pairs, twist the stripped wires together. Fold the stripped wire back in line, and wrap the spliced wire connection with electrical tape. Do this for the other wire. Inspect you work to ensure the spliced wires are completely covered and do not touch each other. Wrap the entire spliced section in electrical tape and hook it up to the charging base.
Ebay has a selection of replacement ac chargers. Look on the back of the charging unit for the model number, and observe the voltage and current ratings.
Mar 17, 2015 | Panasonic Lands Phones
Not charging
Laptop batteries power a laptop when it is not connected to an electrical outlet. If the laptop battery fails to charge when the laptop is plugged into an electrical outlet, the battery is likely dead and needs to be replaced. Unfortunately there is no way to fix a dead battery. However, while a dead battery is the likely cause, it is not the only cause. The AC adapter may be broken, in which case the battery won't charge, or the battery contacts may be dirty and need cleaning. Prior to replacing the battery, perform simple tasks to ensure a dead battery is the cause of the problems.
1. Power down the laptop. Gently pull the AC adapter from the side of the laptop for removal.
2. Place the laptop in front of you, bottom side up. Locate the battery release mechanism. This can be a button that slides or needs to be pushed to unlock or release the laptop battery from the housing unit. Press or slide the mechanism. Slide or lift the battery from the battery bay for removal.
3. Insert the AC adapter into the side of the laptop. Power on the laptop. If the laptop does not power on, ensure the AC adapter is securely plugged into a working electrical outlet. If the electrical outlet is working and the laptop won't power on, the AC adapter is not properly working and needs to be replaced. Remove the AC adapter.
4. Dip a cotton swab in a small amount of rubbing alcohol. The cotton swab should be damp, not dripping wet. Lightly rub the dampened cotton swab onto the battery contacts and battery bay contacts to remove dust, buildup and grime. Allow the contacts to air dry.
5. Align the battery over the battery bay. Either press or slide into place. A clicking or snapping noise produced from the locking mechanism will confirm the laptop battery is securely locked into place.
6. Install the AC adapter. Allow the AC adapter to fully charge the battery for 8 hours.
7. Remove the AC adapter. Power on the laptop. If the laptop does not power on, the battery needs to be replaced.
I hope you find it very helpful.
Thank you. Please rate me.
Aug 10, 2011 | HP Pavilion dv6000z Notebook
Toshiba battery charger pa3468u-1aca for satellite L305-s5944 is beeping and the unit is not charging, what is wrong?
Probably a failed AC adapter. Please try to charge the laptop with a good, working AC adapter & see if the problem disappears.
Jun 12, 2011 | Toshiba LAPTOP AC Adapter Power Charger...
Jump and start unit is dead,how do I recharge this unit ? I have tried to recharge by plugging unit in at the ac plug and let it charge for several hours, what am I doing wrong ? How do I know when unit...
These units have a meter on them that shows if it is full or dead. If it will not charge from an AC wall socket, the unit is probably no good. Check the charger that it comes with to make sure that it doesn't need to be reset. If it has no reset button, you may need to return it for an exchange.
Oct 06, 2010 | JUMP START SYSTEM
230 chauffeur doesn't charge. Batteries new and
hi, ok you mentioned nothing about the charger, is it built in ? or stand alone charger, can you try another charger ??
If you have a Electrical meter tester check that the charging socket pins do actually connect to the batteries if not check the charging socket,
of the three charging pins two are the positive & negative so should show 24 volts the odd one out the one in the middle just below the other two is the inhibit , that is normally grounded otherwords negative.
Sound like a loose connection so please check all connections if you are sure the charger is ok.
Regards
GeWiz.
Dec 10, 2009 | Electric Mobility Mobility Electric Power...
My gps system does not charge when install dash board mount
does it charge via an AC charger? As most GPS units do better on an initial AC charge prior to being hooked up to DC.
Your charge circuit is possibly faulty, or the internal battery has collapsed and needs changing
Jun 22, 2009 | Pioneer AVIC-F500BT Multiumedia GPS...
Charge light orang on for a second and turn off unit not charged.
This kind of problem is usually caused by either of this 3 things: Either the problem is the battery not being able to charge anymore(bettery would need to be replaced), or the charger does not give any charge to the batter(recommend try another charger), or last would be the console charger port( would need to replace console, or repair charger por,not recommended)
Mar 10, 2009 | Nintendo DS Console
WILL NOT TURN ON
Hello LUCKYPURPLE,
The problem could be either with the charger, the battery inside of the GPS, or could be a more serious hardware failure.
You don't mention what method you are using to charge the GPS. Most GPS units can be charged three different ways: connection to the cigarette lighter / accessory jack in your automobile, connection to your computer via a USB cable, or from an electrical outlet using an AC adapter. To determine if the charger is at fault, try charging the unit using a different method. For example, if the GPS turns on after charging in your vehicle but not after connection to your computer, the problem likely lies with the USB cable or port.
If the unit does not turn on regardless of what method you use to charge it, then you likely either need to replace the internal battery or have the unit serviced by a knowledgeable technician.
Best regards,
Ken
Go Ahead. Use Us.
May 14, 2008 | Tomtom One Europe v2 GPS Receiver
Won't charge up, won't run
uh...the charger's supposed to have a DC output
Feb 12, 2008 | Norelco Advantage 6705 X Electric Shaver
Blinking and Whining
I had this happen, and I solved it by connecting it to the car charger for a while, then bringing it in and connecting it DIRECTLY to the AC charger for a full charge. (This assumes the battery is not just kaput.)
Here's what I think happens: The AC charger doesn't have enough current capability to run the unit by itself AND keepp the battery charged (bad design), so, if left continuously ON, the battery will eventually drain. In this state, if you shut it off, the unit senses a low-battery condition and will try to charge, but the charging circuit tries to draw too much from the AC charger and the voltage droops (causing the whine) to the cutoff point (causing it to stop charging, another case of bad design). The car charger has more current capability, so it gets the battery charged enough to use the AC charger again.
Nov 28, 2006 | Delphi MyFi SA10113 XM Radio Receiver with...
Sony Reader Pocket PRS-300 Logo
472 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
