Every now and then, the machine refused to start. We noticed that if we banged the door shut, it would start. Then it refused to start at all. We then realised that if we held the door shut for several minutes until it started, it would go OK. Now, even if we hold it, it refuses to go. Could it be the door sensor? Anyone know how big a job it is to fix and how much a door sensor would cost?
    Guru:
  • 500 Answers
Not a terribly difficult job, just remove the Top Panel (usually 2 screws locking it at the back, depending on your make & model), then you can reach it from the top. As a temporary (and cost-less) solution, you could always bridge the wires connected to it. This will allow the machine to work, but you will have to be sure to keep the door shut when it is operating (Mishaps do happen)
I am unable to give you an indication of price of the Door Lock because I have no real idea which Make or Model you are referring to.
Kind Regards
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Posted on Apr 06, 2011
Why does my front loader make a banging noise while spinning?
Ive checked thru the top and back cant notice anythin brohen but when i do spin tbe tub the banging noice is coming from in tbe drum and its pretty wobbley
Aug 28, 2015 | Washing Machines
Banging noise
I'll need a lot more than banging noise to help you.
What is the make and model of the sewing machine. When did the banging start?
Oct 16, 2013 | Sewing Machines
Electrolux Washer dryer EWW 1273 banging
I think a sensor is being faulty when you load and go to use the unit. Also might want someone to check out the timer on the unit just in case it is going out on you.
Aug 08, 2012 | Washing Machines
Whirlpool awm 6145/3 washing machine. Door shuts cycle starts but within about 5 seconds it stops and door open light comes on.
your door safety switch may be to blame,, if its faulty the machine gets a notice that something is wrong and stops,, to check that try this link http://www.partselect.com/Virtual-Repairman.htm
May 31, 2011 | Washing Machines
Dishwasher was on...while on I noticed a small banging noise..then it seemed the door wasnt shut tightly so I pushed it in...the washer stopped ..it wont restart and I cant open the door
Most door catches also incorporate a switch that stops the machine when you open the door. In "over closing" the door you may have "gone past" the switch which would likely make the controler think that the door was open. Try giving the door a firm but steady pull to release the mechanism.
Dec 23, 2010 | Dishwashers
Hi I put some laundry in the washing machine (j845) and the door won't lock. It keeps saying error de although the door is very much closed.
de stands for door error.  electronics not sensing door open or shut.  could be bad control pcb or bad door switch ( solenoid ) or wiring harness...
Jul 08, 2010 | Washing Machines
My hotpoint aquarius front loader has power but wont work.
Most likely the Door interlock is faulty or has fallen apart (through the banging of the door)
Aug 21, 2009 | Washing Machines
Hotpoint WMA62 door will not lock
Sounds like the door lock switch has failed,normally they go bang when fail,they start the machines cycle so are important,when door is shut it should click,this engages a timer which keeps door locked switch is live at mains potential,cant be tested have to be replaced about 12 pounds cost,best for a tech unless you feel competent
Dec 13, 2008 | Hotpoint WMA64 Front Load Washer
Power Surge and WD16BA
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Sep 18, 2006 | Smeg WD16BA Front Load Washer / Dryer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
